This class is the main interface with the camera and the SDK features, such as: video, depth, tracking, mapping, and more. More...
Functions | |||
float | GetRequestedCameraFPS () | ||
Desired FPS from the ZED camera. This is the maximum FPS for the ZED's current resolution unless a lower setting was specified in Open(). Maximum values are bound by the ZED's output, not system performance. More... | |||
Camera (int id) | |||
Constructor that creates an empty Camera object; More... | |||
ERROR_CODE | Open (ref InitParameters initParameters) | ||
Checks if the ZED camera is plugged in and opens it. More... | |||
void | Close () | ||
Closes the camera. Once destroyed, you need to recreate a camera instance to restart again. More... | |||
sl.ERROR_CODE | Grab (ref sl.RuntimeParameters runtimeParameters) | ||
Grabs a new image, rectifies it, and computes the disparity map and (optionally) the depth map. The grabbing function is typically called in the main loop in a separate thread. More... | |||
sl.INPUT_TYPE | GetInputType () | ||
Return the INPUT_TYPE currently used More... | |||
CalibrationParameters | GetCalibrationParameters (bool raw=false) | ||
sl.MODEL | GetCameraModel () | ||
Gets the ZED camera model (ZED or ZED Mini). More... | |||
int | GetCameraFirmwareVersion () | ||
Gets the ZED's camera firmware version. More... | |||
int | GetSensorsFirmwareVersion () | ||
Gets the ZED's sensors firmware version. More... | |||
int | GetZEDSerialNumber () | ||
Gets the ZED's serial number. More... | |||
float | GetFOV () | ||
Returns the ZED's vertical field of view in radians. More... | |||
void | UpdateSelfCalibration () | ||
Perform a new self calibration process. In some cases, due to temperature changes or strong vibrations, the stereo calibration becomes less accurate. Use this function to update the self-calibration data and get more reliable depth values. More... | |||
uint | GetFrameDroppedCount () | ||
Gets the number of frames dropped since Grab() was called for the first time. Based on camera timestamps and an FPS comparison. More... | |||
sl.ERROR_CODE | findFloorPlane (ref PlaneData plane, out float playerHeight, Quaternion priorQuat, Vector3 priorTrans) | ||
Plane Detection ///. More... | |||
sl.ERROR_CODE | FindFloorPlane (ref PlaneData plane, out float playerHeight, Quaternion priorQuat, Vector3 priorTrans) | ||
Looks for a plane in the visible area that is likely to represent the floor. Use ZEDPlaneDetectionManager.DetectFloorPlane for a higher-level version that turns planes into GameObjects. More... | |||
int | convertFloorPlaneToMesh (Vector3[] vertices, int[] triangles, out int numVertices, out int numTriangles) | ||
Using data from a detected floor plane, updates supplied vertex and triangle arrays with data needed to make a mesh that represents it. These arrays are updated directly from the wrapper. More... | |||
int | ConvertFloorPlaneToMesh (Vector3[] vertices, int[] triangles, out int numVertices, out int numTriangles) | ||
sl.ERROR_CODE | findPlaneAtHit (ref PlaneData plane, Vector2 coord) | ||
Checks for a plane in the real world at given screen-space coordinates. More... | |||
sl.ERROR_CODE | FindPlaneAtHit (ref PlaneData plane, Vector2 coord) | ||
int | convertHitPlaneToMesh (Vector3[] vertices, int[] triangles, out int numVertices, out int numTriangles) | ||
Using data from a detected hit plane, updates supplied vertex and triangle arrays with data needed to make a mesh that represents it. These arrays are updated directly from the wrapper. More... | |||
int | ConvertHitPlaneToMesh (Vector3[] vertices, int[] triangles, out int numVertices, out int numTriangles) | ||
sl.ERROR_CODE | SaveCurrentImageInFile (sl.VIEW view, String filename) | ||
Save utils fct ///. More... | |||
sl.ERROR_CODE | SaveCurrentDepthInFile (SIDE side, String filename) | ||
Save the current depth in a file defined by filename. Supported formats are PNG,PFM and PGM More... | |||
sl.ERROR_CODE | SaveCurrentPointCloudInFile (SIDE side, String filename) | ||
Save the current point cloud in a file defined by filename. Supported formats are PLY,VTK,XYZ and PCD More... | |||
Depth Sensing | |||
sl.ERROR_CODE | RetrieveMeasure (sl.Mat mat, sl.MEASURE measure, sl.MEM mem=sl.MEM.CPU, sl.Resolution resolution=new sl.Resolution()) | ||
Retrieves a measure texture from the ZED SDK and loads it into a ZEDMat. Use this to get an individual texture from the last grabbed frame with measurements in every pixel - such as a depth map, confidence map, etc. Measure textures are not human-viewable but don't lose accuracy, unlike image textures. More... | |||
int | GetConfidenceThreshold () | ||
Gets the current confidence threshold value for the disparity map (and by extension the depth map). Values below the given threshold are removed from the depth map. More... | |||
float | GetDepthMinRangeValue () | ||
Gets the closest measurable distance by the camera, according to the camera type and depth map parameters. More... | |||
sl.ERROR_CODE | GetCurrentMixMaxDepth (ref float min, ref float max) | ||
Gets the current range of perceived depth. More... | |||
float | GetDepthMaxRangeValue () | ||
Returns the current maximum distance of depth/disparity estimation. More... | |||
Positional Tracking | |||
Initialize and Start the tracking functions
sl.ERROR_CODE | EnablePositionalTracking (ref PositionalTrackingParameters positionalTrackingParameters) | ||
void | DisablePositionalTracking (string path="") | ||
Stop the motion tracking, if you want to restart, call enableTracking(). More... | |||
bool | IsPositionalTrackingEnabled () | ||
Gets the current position of the camera and state of the tracking, with an optional offset to the tracking frame. More... | |||
ERROR_CODE | SaveAreaMap (string areaFilePath) | ||
Saves the current area learning file. The file will contain spatial memory data generated by the tracking. More... | |||
AREA_EXPORT_STATE | GetAreaExportState () | ||
Returns the state of the spatial memory export process. More... | |||
sl.ERROR_CODE | ResetPositionalTracking (Quaternion rotation, Vector3 translation) | ||
Reset tracking More... | |||
SensorsConfiguration | GetSensorsConfiguration () | ||
CameraInformation | GetCameraInformation (Resolution resolution=new Resolution()) | ||
Returns the calibration parameters, serial number and other information about the camera being used. More... | |||
POSITIONAL_TRACKING_STATE | GetPosition (ref Quaternion rotation, ref Vector3 position, REFERENCE_FRAME referenceType=REFERENCE_FRAME.WORLD) | ||
Gets the position of the camera and the current state of the ZED Tracking. More... | |||
POSITIONAL_TRACKING_STATE | GetPosition (ref Quaternion rotation, ref Vector3 translation, ref Quaternion targetQuaternion, ref Vector3 targetTranslation, REFERENCE_FRAME referenceFrame=REFERENCE_FRAME.WORLD) | ||
POSITIONAL_TRACKING_STATE | GetPosition (ref Quaternion rotation, ref Vector3 translation, TRACKING_FRAME trackingFrame, REFERENCE_FRAME referenceFrame=REFERENCE_FRAME.WORLD) | ||
Gets the current position of the camera and state of the tracking, with a defined tracking frame. A tracking frame defines what part of the ZED is its center for tracking purposes. See ZEDCommon.TRACKING_FRAME. More... | |||
POSITIONAL_TRACKING_STATE | GetPosition (ref Pose pose, REFERENCE_FRAME referenceType=REFERENCE_FRAME.WORLD) | ||
Gets the current position of the camera and state of the tracking, filling a Pose struct useful for AR pass-through. More... | |||
ERROR_CODE | SetIMUOrientationPrior (ref Quaternion rotation) | ||
Sets a prior to the IMU orientation (not for ZED1). Prior must come from a external IMU, such as the HMD orientation and should be in a time frame that's as close as possible to the camera. More... | |||
ERROR_CODE | GetIMUOrientation (ref Quaternion rotation, TIME_REFERENCE referenceTime=TIME_REFERENCE.IMAGE) | ||
Gets the rotation given by the ZED-M/ZED2 IMU. Return an error if using ZED (v1) which does not contains internal sensors More... | |||
ERROR_CODE | GetSensorsData (ref SensorsData data, TIME_REFERENCE referenceTime=TIME_REFERENCE.IMAGE) | ||
Gets the full Sensor data from the ZED-M or ZED2 . Return an error if using ZED (v1) which does not contains internal sensors More... | |||
ERROR_CODE | SetRegionOfInterest (sl.Mat roiMask) | ||
Defines a region of interest to focus on for all the SDK, discarding other parts. More... | |||
Recording | |||
ERROR_CODE | EnableRecording (string videoFileName, SVO_COMPRESSION_MODE compressionMode=SVO_COMPRESSION_MODE.H264_BASED, uint bitrate=0, int targetFPS=0, bool transcode=false) | ||
Creates a file for recording the ZED's output into a .SVO or .AVI video. More... | |||
ERROR_CODE | EnableRecording (RecordingParameters recordingParameters) | ||
sl.RecordingStatus | GetRecordingStatus () | ||
Get the recording information More... | |||
sl.RecordingParameters | GetRecordingParameters () | ||
Get the recording parameters More... | |||
void | PauseRecording (bool status) | ||
Pauses or resumes the recording. More... | |||
void | DisableRecording () | ||
Stops recording to an SVO/AVI, if applicable, and closes the file. More... | |||
Streaming | |||
ERROR_CODE | EnableStreaming (STREAMING_CODEC codec=STREAMING_CODEC.H264_BASED, uint bitrate=8000, ushort port=30000, int gopSize=-1, bool adaptativeBitrate=false, int chunkSize=32768, int targetFPS=0) | ||
Streaming Module ///. More... | |||
ERROR_CODE | EnableStreaming (ref StreamingParameters streamingParameters) | ||
Creates an streaming pipeline. More... | |||
bool | IsStreamingEnabled () | ||
Tells if streaming is running or not. More... | |||
void | DisableStreaming () | ||
Stops the streaming pipeline. More... | |||
sl.StreamingParameters | GetStreamingParameters () | ||
Get the streaming parameters More... | |||
Static Functions | |
static void | UnloadPlugin () |
static void | UnloadInstance (int id) |
static string | GenerateUniqueID () |
Generate a UUID like unique ID to help identify and track AI detections. More... | |
static string | GetSDKVersion () |
Gets the version of the currently installed ZED SDK. More... | |
static sl.ERROR_CODE | ConvertCoordinateSystem (ref Quaternion rotation, ref Vector3 translation, sl.COORDINATE_SYSTEM coordinateSystemSrc, sl.COORDINATE_SYSTEM coordinateSystemDest) |
Change the coordinate system of a transform matrix. More... | |
static void | GetSDKVersion (ref int major, ref int minor, ref int patch) |
static sl.DeviceProperties[] | GetDeviceList (out int nbDevices) |
List all the streaming devices with their associated information. This function lists all the cameras available and provides their serial number, models and other information. More... | |
static sl.StreamingProperties[] | GetStreamingDeviceList (out int nbDevices) |
List all the connected devices with their associated information. This function lists all the cameras available and provides their serial number, models and other information. More... | |
static sl.ERROR_CODE | Reboot (int serialNumber, bool fullReboot=true) |
Performs an hardware reset of the ZED 2. More... | |
static float | ConvertRangePreset (MAPPING_RANGE rangePreset) |
Updates the range to match the specified preset. More... | |
static float | ConvertResolutionPreset (MAPPING_RESOLUTION resolutionPreset) |
Updates the resolution to match the specified preset. More... | |
Attributes | |
int | CameraID = 0 |
Camera ID (for multiple cameras) More... | |
Properties | |
int | ImageWidth [get] |
Width of the images returned by the ZED in pixels. Corresponds to the ZED's current resolution setting. More... | |
int | ImageHeight [get] |
Height of the images returned by the ZED in pixels. Corresponds to the ZED's current resolution setting. More... | |
float | Baseline [get] |
Camera's stereo baseline (distance between the cameras). Extracted from calibration files. More... | |
float | HorizontalFieldOfView [get] |
ZED's current horizontal field of view in degrees. More... | |
float | VerticalFieldOfView [get] |
ZED's current vertical field of view in degrees. More... | |
SensorsConfiguration | SensorsConfiguration [get] |
CalibrationParameters | CalibrationParametersRaw [get] |
Stereo parameters for current ZED camera prior to rectification (distorted). More... | |
CalibrationParameters | CalibrationParametersRectified [get] |
Stereo parameters for current ZED camera after rectification (undistorted). More... | |
sl.MODEL | CameraModel [get] |
Camera model - ZED or ZED Mini. More... | |
bool | IsCameraReady [get] |
Whether the camera has been successfully initialized. More... | |
Video | |
sl.ERROR_CODE | RetrieveImage (sl.Mat mat, sl.VIEW view, sl.MEM mem=sl.MEM.CPU, sl.Resolution resolution=new sl.Resolution()) |
Retrieves an image texture from the ZED SDK and loads it into a ZEDMat. Use this to get an individual texture from the last grabbed frame in a human-viewable format. Image textures work for when you want the result to be visible, such as the direct RGB image from the camera, or a greyscale image of the depth. However it will lose accuracy if used to show measurements like depth or confidence, unlike measure textures. More... | |
InitParameters | GetInitParameters () |
Returns the init parameters used. Correspond to the structure send when the open() function was called. More... | |
RuntimeParameters | GetRuntimeParameters () |
Returns the runtime parameters used. Correspond to the structure send when the grab() function was called. More... | |
PositionalTrackingParameters | GetPositionalTrackingParameters () |
void | SetCameraSettings (VIDEO_SETTINGS settings, int value) |
Sets a value in the ZED's camera settings. More... | |
int | GetCameraSettings (VIDEO_SETTINGS settings) |
Gets the value of a given setting from the ZED camera. More... | |
int | SetCameraSettings (VIDEO_SETTINGS settings, SIDE side, Rect roi, bool reset=false) |
Overloaded function for CAMERA_SETTINGS.AEC_AGC_ROI (requires Rect as input) More... | |
int | GetCameraSettings (VIDEO_SETTINGS settings, SIDE side, ref Rect roi) |
void | ResetCameraSettings () |
Reset camera settings to default More... | |
ulong | GetCameraTimeStamp () |
Gets the timestamp at the time the latest grabbed frame was extracted from the USB stream. This is the closest timestamp you can get from when the image was taken. Must be called after calling grab(). More... | |
ulong | GetCurrentTimeStamp () |
Gets the current timestamp at the time the function is called. Can be compared to the camera timestamp for synchronization, since they have the same reference (the computer's start time). More... | |
int | GetSVOPosition () |
Get the current position of the SVO being recorded to. More... | |
int | GetSVONumberOfFrames () |
Gets the total number of frames in the loaded SVO file. More... | |
void | SetSVOPosition (int frame) |
Sets the position of the SVO file currently being read to a desired frame. More... | |
float | GetCameraFPS () |
Returns the current camera FPS. This is limited primarily by resolution but can also be lower due to setting a lower desired resolution in Open() or from USB connection/bandwidth issues. More... | |
bool | IsOpened () |
Reports if the camera has been successfully opened. More... | |
static sl.Resolution | GetResolution (RESOLUTION resolution) |
Get sl.Resolion from a RESOLUTION enum More... | |
Spatial Mapping | |
sl.ERROR_CODE | EnableSpatialMapping (ref SpatialMappingParameters spatialMappingParameters) |
Initializes and begins the spatial mapping processes. More... | |
sl.ERROR_CODE | EnableSpatialMapping (SPATIAL_MAP_TYPE type=SPATIAL_MAP_TYPE.MESH, MAPPING_RESOLUTION mappingResolution=MAPPING_RESOLUTION.MEDIUM, MAPPING_RANGE mappingRange=MAPPING_RANGE.MEDIUM, bool saveTexture=false) |
SpatialMappingParameters | GetSpatialMappingParameters () |
Returns the spatial mapping parameters used. Correspond to the structure send when the enableSpatialMapping() function was called. More... | |
void | DisableSpatialMapping () |
Disables the Spatial Mapping process. More... | |
sl.ERROR_CODE | UpdateMesh (int[] nbVerticesInSubmeshes, int[] nbTrianglesInSubmeshes, ref int nbUpdatedSubmesh, int[] updatedIndices, ref int nbVertices, ref int nbTriangles, int nbSubmeshMax) |
Updates the internal version of the mesh and returns the sizes of the meshes. More... | |
sl.ERROR_CODE | UpdateMesh (ref Mesh mesh) |
sl.ERROR_CODE | RetrieveMesh (Vector3[] vertices, int[] triangles, int nbSubmeshMax, Vector2[] uvs, IntPtr textures) |
Retrieves all chunks of the current generated mesh. Call UpdateMesh() before calling this. Vertex and triangle arrays must be at least of the sizes returned by UpdateMesh (nbVertices and nbTriangles). More... | |
sl.ERROR_CODE | RetrieveMesh (ref Mesh mesh) |
sl.ERROR_CODE | RetrieveChunks (ref Mesh mesh) |
Retrieve all chunks of the generated mesh.Call UpdateMesh() before calling this. Used for mesh vizualisation. More... | |
sl.ERROR_CODE | RetrieveSpatialMap (ref Mesh mesh) |
Retrieves the current generated mesh. More... | |
sl.ERROR_CODE | RetrieveSpatialMap (ref FusedPointCloud fusedPointCloud) |
Retrieves the current fused point cloud. More... | |
sl.ERROR_CODE | UpdateFusedPointCloud (ref int nbVertices) |
Updates the fused point cloud (if spatial map type was FUSED_POINT_CLOUD) More... | |
sl.ERROR_CODE | RetrieveFusedPointCloud (Vector4[] vertices) |
Retrieves all points of the fused point cloud. Call UpdateFusedPointCloud() before calling this. Vertex arrays must be at least of the sizes returned by UpdateFusedPointCloud More... | |
ERROR_CODE | ExtractWholeSpatialMap () |
void | RequestSpatialMap () |
Starts the mesh generation process in a thread that doesn't block the spatial mapping process. ZEDSpatialMappingHelper calls this each time it has finished applying the last mesh update. More... | |
void | PauseSpatialMapping (bool status) |
Sets the pause state of the data integration mechanism for the ZED's spatial mapping. More... | |
sl.ERROR_CODE | GetMeshRequestStatus () |
Returns the mesh generation status. Useful for knowing when to update and retrieve the mesh. More... | |
bool | SaveMesh (string filename, MESH_FILE_FORMAT format) |
Saves the scanned mesh in a specific file format. More... | |
bool | SavePointCloud (string filename, MESH_FILE_FORMAT format) |
Saves the scanned point cloud in a specific file format. More... | |
bool | LoadMesh (string filename, int[] nbVerticesInSubmeshes, int[] nbTrianglesInSubmeshes, ref int nbSubmeshes, int[] updatedIndices, ref int nbVertices, ref int nbTriangles, int nbSubmeshMax, int[] textureSize=null) |
Loads a saved mesh file. ZEDSpatialMapping then configures itself as if the loaded mesh was just scanned. More... | |
bool | FilterMesh (MESH_FILTER filterParameters, int[] nbVerticesInSubmeshes, int[] nbTrianglesInSubmeshes, ref int nbSubmeshes, int[] updatedIndices, ref int nbVertices, ref int nbTriangles, int nbSubmeshMax) |
Filters a mesh to remove triangles while still preserving its overall shape (though less accurate). More... | |
bool | FilterMesh (MESH_FILTER filterParameters, ref Mesh mesh) |
bool | ApplyTexture (int[] nbVerticesInSubmeshes, int[] nbTrianglesInSubmeshes, ref int nbSubmeshes, int[] updatedIndices, ref int nbVertices, ref int nbTriangles, int[] textureSize, int nbSubmeshMax) |
Applies the scanned texture onto the internal scanned mesh. More... | |
bool | ApplyTexture (ref Mesh mesh) |
SPATIAL_MAPPING_STATE | GetSpatialMappingState () |
Gets the current state of spatial mapping. More... | |
Vector3 | GetGravityEstimate () |
Gets a vector pointing toward the direction of gravity. This is estimated from a 3D scan of the environment, and as such, a scan must be started/finished for this value to be calculated. If using the ZED Mini, this isn't required thanks to its IMU. More... | |
void | MergeChunks (int numberFaces, int[] nbVerticesInSubmeshes, int[] nbTrianglesInSubmeshes, ref int nbSubmeshes, int[] updatedIndices, ref int nbVertices, ref int nbTriangles, int nbSubmesh) |
Consolidates the chunks from a scan. This is used to turn lots of small meshes (which are efficient for the scanning process) into several large meshes (which are more convenient to work with). More... | |
Object Detection | |
sl.ERROR_CODE | EnableObjectDetection (ref ObjectDetectionParameters od_params) |
Enable object detection module More... | |
void | DisableObjectDetection () |
Disable object detection module and release the resources. More... | |
sl.ObjectDetectionParameters | GetObjectDetectionParameters () |
Get the object detections parameters More... | |
void | PauseObjectDetection (bool status) |
Pause or Unpause the object detection More... | |
sl.ERROR_CODE | IngestCustomBoxObjects (List< CustomBoxObjectData > objects_in) |
sl.ERROR_CODE | RetrieveObjects (ref Objects objs, ref ObjectDetectionRuntimeParameters od_params) |
Retrieve object detection data More... | |
sl.ERROR_CODE | UpdateObjectsBatch (out int nbBatches) |
Update the batch trajectories and retrieve the number of batches. More... | |
sl.ERROR_CODE | GetObjectsBatch (int batch_index, ref ObjectsBatch objectsBatch) |
Retrieve a batch of objects. This function need to be called after RetrieveObjects, otherwise trajectories will be empty. If also needs to be called after UpdateOBjectsBatch in order to retrieve the number of batch trajectories. More... | |
static AI_Model_status | CheckAIModelStatus (AI_MODELS model, int gpu_id=0) |
Object detection ///. More... | |
static sl.ERROR_CODE | OptimizeAIModel (AI_MODELS model, int gpu_id=0) |
Optimize the requested model, possible download if the model is not present on the host. More... | |
inline |
inlinestatic |
inlinestatic |
inlinestatic |
inline |
initParameters | Class with all initialization settings. A newly-instantiated InitParameters will have recommended default values. |
inline |
inline |
For more info, read about the SDK function it calls: https://www.stereolabs.com/docs/api_3.X/classsl_1_1Camera.html#afa3678a18dd574e162977e97d7cbf67b
runtimeParameters | Struct holding all grab parameters. |
inline |
inline |
If you want to access the texture via script, you'll usually want to specify CPU memory. Then you can use Marshal.Copy to move them into a new byte array, which you can load into a Texture2D. Note that you may need to change the color space and/or flip the image. RetrieveMeasure() calls Camera::retrieveMeasure() in the C++ SDK. For more info, read: https://www.stereolabs.com/docs/api_3.X/classsl_1_1Camera.html#a01dce4f0af6f8959a9c974ffaca656b5
mat | ZEDMat to fill with the new texture. |
view | Image type (left RGB, right depth map, etc.) |
mem | Whether the image should be on CPU or GPU memory. |
resolution | Resolution of the texture. |
inline |
inline |
inline |
inlinestatic |
resolution |
inline |
settings | Setting to be changed (brightness, contrast, gain, exposure, etc.) |
value | New value. |
usedefault | True to set the settings to their default values. |
Referenced by Camera.ResetCameraSettings().
inline |
settings | Setting to be retrieved (brightness, contrast, gain, exposure, etc.) |
inline |
settings | Must be set to CAMERA_SETTINGS.AEC_AGC_ROI. Otherwise will return -1. |
side | defines left=0 or right=1 or both=2 sensor target |
roi | the roi defined as a sl.Rect |
reset | Defines if the target must be reset to full sensor |
inline |
side | defines left=0 or right=1 or both=2 sensor target. |
roi | Roi that will be filled. |
inline |
inline |
inline |
inline |
inline |
inline |
frame | Index of the desired frame to be decoded. |
inline |
inline |
inline |
Referenced by Camera.GetFOV(), and Camera.Open().
inline |
Referenced by Camera.Open().
inline |
inline |
inline |
inline |
inline |
The self calibration will occur at the next grab() call.
New values will then be available in getCameraInformation(), be sure to get them to still have consistent 2D - 3D conversion.
cameraID |
inline |
inlinestatic |
inlinestatic |
rotation | [In, Out] : rotation to transform |
translation | [In, Out] : translation to transform |
coordinateSystemSrc | The current coordinate system of the translation/rotation |
coordinateSystemDest | The destination coordinate system for the translation/rotation. |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
serialNumber | Serial number of the camera |
fullReboot | Perform a full reboot (Sensors and Video modules) |
inline |
If you want to access the texture via script, you'll usually want to specify CPU memory. Then you can use Marshal.Copy to move them into a new byte array, which you can load into a Texture2D. RetrieveMeasure() calls Camera::retrieveMeasure() in the C++ SDK. For more info, read: https://www.stereolabs.com/docs/api_3.X/classsl_1_1Camera.html#a9e0773c0c14ce5156c1fa2fde501c13e
measure | Measure type (depth, confidence, xyz, etc.) |
inline |
inline |
inline |
inline |
inline |
inline |
path | The path to save the area file |
inline |
inline |
path |
inline |
inline |
Reset tracking
rotation | |
translation |
inline |
inline |
inline |
rotation | Quaternion filled with the current rotation of the camera depending on its reference frame. |
position | Vector filled with the current position of the camera depending on its reference frame. |
referenceType | Reference frame for setting the rotation/position. CAMERA gives movement relative to the last pose. WORLD gives cumulative movements since tracking started. |
inline |
targetQuaternion | Rotational offset applied to the tracking frame. |
targetTranslation | Positional offset applied to the tracking frame. |
referenceFrame | Reference frame for setting the rotation/position. CAMERA gives movement relative to the last pose. WORLD gives cumulative movements since tracking started. |
inline |
trackingFrame | Center of the ZED for tracking purposes (left eye, center, right eye). |
inline |
pose | Current pose. |
inline |
rotation | Prior rotation. |
inline |
rotation | Rotation from the IMU. |
inline |
inline |
roiMask | the Mat defining the requested region of interest, all pixel set to 0 will be discard. If empty, set all pixels as valid, otherwise should fit the resolution of the current instance and its type should be U8_C1. |
inline |
spatialMappingParameters | Spatial mapping parameters. |
inline |
resolutionMeter | Spatial mapping resolution in meters. |
maxRangeMeter | Maximum scanning range in meters. |
saveTexture | True to scan surface textures in addition to geometry. |
inline |
inline |
inline |
nbVerticesInSubmeshes | Array of the number of vertices in each submesh. |
nbTrianglesInSubmeshes | Array of the number of triangles in each submesh. |
nbUpdatedSubmesh | Number of updated submeshes. |
updatedIndices | List of all submeshes updated since the last update. |
nbVertices | Total number of updated vertices in all submeshes. |
nbTriangles | Total number of updated triangles in all submeshes. |
nbSubmeshMax | Maximum number of submeshes that can be handled. |
Referenced by Camera.RetrieveSpatialMap(), and Camera.UpdateMesh().
inline |
mesh | The mesh to be filled with the generated spatial map. |
inline |
vertices | Vertices of the mesh. |
triangles | Triangles, formatted as the index of each triangle's three vertices in the vertices array. |
Referenced by Camera.RetrieveMesh(), and Camera.RetrieveSpatialMap().
inline |
inline |
inline |
inline |
fusedPointCloud | The Fused Point Cloud to be filled with the generated spatial map. |
inline |
Referenced by Camera.RetrieveSpatialMap().
inline |
vertices | Points of the fused point cloud. |
inline |
Extracts the current spatial map from the spatial mapping process. If the object to be filled already contains a previous version of the mesh, only changes will be updated, optimizing performance. return SUCCESS if the mesh is filled and available, otherwise ERROR_CODE.FAILURE. warning This is a blocking function.You should either call it in a thread or at the end of the mapping process.
inline |
inline |
status | If true, the integration is paused. If false, the spatial mapping is resumed. |
inline |
inline |
filename | Path and filename of the mesh. |
format | File format (extension). Can be .obj, .ply or .bin. |
inline |
filename | Path and filename of the point cloud. |
inline |
filename | Path and filename of the mesh. Should include the extension (.obj, .ply or .bin). |
nbSubmeshes | Number of submeshes. |
textureSize | Array containing the sizes of all the textures (width, height) if applicable. |
inline |
filterParameters | Filter level. Higher settings remove more triangles. |
inline |
inline |
textureSize | Vector containing the size of all the texture (width, height). |
inline |
inline |
inline |
inline |
numberFaces | |
inline |
plane | Data on the detected plane. |
playerHeight | Height of the camera from the newly-detected floor. |
priorQuat | Prior rotation. |
priorTrans | Prior position. |
inline |
inline |
vertices | Array to be filled with mesh vertices. |
triangles | Array to be filled with mesh triangles, stored as indexes of each triangle's points. |
numVertices | Total vertices in the mesh. |
numTriangles | Total triangle indexes (3x number of triangles). |
inline |
inline |
screenPos | Point on the ZED image to check for a plane. |
inline |
inline |
inline |
inlinestatic |
Referenced by Camera.EnableSpatialMapping().
inlinestatic |
inline |
An SVO is Stereolabs' own format designed for the ZED. It holds the video feed with timestamps as well as info about the camera used to record it.
videoFileName | Filename. Whether it ends with .svo or .avi defines its file type. |
compressionMode | How much compression to use |
bitrate | Override default bitrate with a custom bitrate (Kbits/s) |
target_fps | Use another fps than camera fps. Must respect camera_fpstarget_fps == 0 |
transcode | If input is in streaming mode, dump directly into SVO file (transcode=false) or decode/encode (transcode=true) |
inline |
inline |
inline |
inline |
status | if true, the recording is paused. If false, the recording is resumed. |
inline |
inline |
inline |
<params> Streaming parameters: See sl.StreamingParameters for more informations. </params>
inline |
inline |
inline |
inline |
Save utils fct ///.
Save current image (specified by view) in a file defined by filename Supported formats are jpeg and png. Filename must end with either .jpg or .png
inline |
side | defines left (0) or right (1) depth |
filename | filename must end with .png, .pfm or .pgm |
inline |
side | defines left (0) or right (1) point cloud |
filename | filename must end with .ply, .xyz , .vtk or .pcd |
inlinestatic |
Check if a corresponding optimized engine is found for the requested Model based on your rig configuration.
model | AI model to check. |
gpu_id | ID of the gpu. |
inlinestatic |
model | AI model to optimize. |
gpu_id | ID of the gpu to optimize on. |
inline |
inline |
inline |
inline |
status |
inline |
inline |
od_params | Object detection runtime parameters |
objFrame | ObjectsFrameSDK that contains all the detection data |
inline |
nbBatches | numbers of batches |
inline |
To retrieve all the objectsbatches, you need to iterate from 0 to nbBatches (retrieved from UpdateObjectBatches)
batch_index | index of the batch retrieved. |
objectsBatch | trajectory that will be filled by the batching queue process |
int CameraID = 0 |
Referenced by Camera.ApplyTexture(), Camera.Camera(), Camera.Close(), Camera.convertFloorPlaneToMesh(), Camera.ConvertFloorPlaneToMesh(), Camera.convertHitPlaneToMesh(), Camera.ConvertHitPlaneToMesh(), Camera.DisableObjectDetection(), Camera.DisablePositionalTracking(), Camera.DisableRecording(), Camera.DisableSpatialMapping(), Camera.DisableStreaming(), Camera.EnableObjectDetection(), Camera.EnablePositionalTracking(), Camera.EnableRecording(), Camera.EnableSpatialMapping(), Camera.EnableStreaming(), Camera.ExtractWholeSpatialMap(), Camera.FilterMesh(), Camera.findFloorPlane(), Camera.FindFloorPlane(), Camera.findPlaneAtHit(), Camera.FindPlaneAtHit(), Camera.GetAreaExportState(), Camera.GetCalibrationParameters(), Camera.GetCameraFirmwareVersion(), Camera.GetCameraFPS(), Camera.GetCameraInformation(), Camera.GetCameraModel(), Camera.GetCameraSettings(), Camera.GetCameraTimeStamp(), Camera.GetConfidenceThreshold(), Camera.GetCurrentMixMaxDepth(), Camera.GetCurrentTimeStamp(), Camera.GetDepthMaxRangeValue(), Camera.GetDepthMinRangeValue(), Camera.GetFrameDroppedCount(), Camera.GetGravityEstimate(), Camera.GetIMUOrientation(), Camera.GetInitParameters(), Camera.GetInputType(), Camera.GetMeshRequestStatus(), Camera.GetObjectDetectionParameters(), Camera.GetObjectsBatch(), Camera.GetPosition(), Camera.GetPositionalTrackingParameters(), Camera.GetRecordingParameters(), Camera.GetRecordingStatus(), Camera.GetRuntimeParameters(), Camera.GetSensorsConfiguration(), Camera.GetSensorsData(), Camera.GetSensorsFirmwareVersion(), Camera.GetSpatialMappingParameters(), Camera.GetSpatialMappingState(), Camera.GetStreamingParameters(), Camera.GetSVONumberOfFrames(), Camera.GetSVOPosition(), Camera.GetZEDSerialNumber(), Camera.Grab(), Camera.IngestCustomBoxObjects(), Camera.IsOpened(), Camera.IsPositionalTrackingEnabled(), Camera.IsStreamingEnabled(), Camera.LoadMesh(), Camera.MergeChunks(), Camera.Open(), Camera.PauseObjectDetection(), Camera.PauseRecording(), Camera.PauseSpatialMapping(), Camera.RequestSpatialMap(), Camera.ResetPositionalTracking(), Camera.RetrieveChunks(), Camera.RetrieveFusedPointCloud(), Camera.RetrieveImage(), Camera.RetrieveMeasure(), Camera.RetrieveMesh(), Camera.RetrieveObjects(), Camera.SaveAreaMap(), Camera.SaveCurrentDepthInFile(), Camera.SaveCurrentImageInFile(), Camera.SaveCurrentPointCloudInFile(), Camera.SaveMesh(), Camera.SavePointCloud(), Camera.SetCameraSettings(), Camera.SetIMUOrientationPrior(), Camera.SetRegionOfInterest(), Camera.SetSVOPosition(), Camera.UpdateFusedPointCloud(), Camera.UpdateMesh(), Camera.UpdateObjectsBatch(), and Camera.UpdateSelfCalibration().
get |
get |
get |
Referenced by Camera.GetPosition().
get |
get |
Referenced by Camera.GetSensorsConfiguration().
get |
get |
get |
