All Classes Namespaces Functions Variables Enumerations Enumerator Properties Modules Pages
PositionalTrackingParameters
Parameters for positional tracking initialization. More...
Attributes
Quaternion initialWorldRotation = Quaternion.Identity
 Rotation of the camera in the world frame when the camera is started.By default, it should be identity. More...
Vector3 initialWorldPosition = Vector3.Zero
 Position of the camera in the world frame when the camera is started. By default, it should be zero. More...
bool enableAreaMemory = true
 This mode enables the camera to remember its surroundings. This helps correct positional tracking drift, and can be helpful for positioning different cameras relative to one other in space. More...
bool enablePoseSmothing = false
 This mode enables smooth pose correction for small drift correction. More...
bool setFloorAsOrigin = false
 This mode initializes the tracking to be aligned with the floor plane to better position the camera in space. More...
bool setAsStatic = false
 This setting allows you define the camera as static. If true, it will not move in the environment. This allows you to set its position using initial_world_transform. More...
bool enableIMUFusion = true
 This setting allows you to enable or disable IMU fusion. When set to false, only the optical odometry will be used. More...
float depthMinRange = -1f
 This setting allows you to change the minimum depth used by the SDK for Positional Tracking. More...
bool setGravityAsOrigin = true
string areaFilePath = ""
 Area localization file that describes the surroundings, saved from a previous tracking session. More...
Variables
◆ initialWorldRotation
◆ initialWorldPosition
◆ enableAreaMemory
◆ enablePoseSmothing
◆ setFloorAsOrigin
◆ setAsStatic
◆ enableIMUFusion
◆ depthMinRange
◆ setGravityAsOrigin
◆ areaFilePath
