SpatialMappingParameters Class Reference
Sets the spatial mapping parameters. More...
 SpatialMappingParameters (float resolutionMeter=0.05f, float rangeMeter=0.0f, bool saveTexture=false, SPATIAL_MAP_TYPE map_type=SPATIAL_MAP_TYPE.MESH, bool useChunkOnly=false, int maxMemoryUsage=2048, bool reverseVertexOrder=false)
 Constructor More...
void set (MAPPING_RESOLUTION mappingResolution=MAPPING_RESOLUTION.MEDIUM)
 Sets the resolution corresponding to the given MAPPING_RESOLUTION preset. More...
void set (MAPPING_RANGE mappingRange=MAPPING_RANGE.MEDIUM)
 Sets the maximum value of the depth corresponding to the given MAPPING_RANGE preset. More...
Static Functions
static float get (MAPPING_RESOLUTION mappingResolution=MAPPING_RESOLUTION.MEDIUM)
 Returns the resolution corresponding to the given MAPPING_RESOLUTION preset. More...
static float get (MAPPING_RANGE mappingRange=MAPPING_RANGE.MEDIUM)
 Returns the resolution corresponding to the given MAPPING_RANGE preset. More...
Attributes
 Spatial mapping resolution in meters. More...
float rangeMeter
 Depth range in meters. More...
bool saveTexture = false
 Set to true if you want to be able to apply the texture to your mesh after its creation. More...
bool useChunkOnly = false
 Set to false if you want to ensure consistency between the mesh and its inner chunk data (default is false). More...
int maxMemoryUsage = 2048
bool reverseVertexOrder = false
 Specify if the order of the vertices of the triangles needs to be inverted. If your display process does not handle front and back face culling, you can use this to correct it. More...
 The type of spatial map to be created. This dictates the format that will be used for the mapping(e.g. mesh, point cloud). See SPATIAL_MAP_TYPE More...
Constructor and Destructor
◆ SpatialMappingParameters()
SpatialMappingParameters ( float  resolutionMeter = 0.05f,
float  rangeMeter = 0.0f,
bool  saveTexture = false,
SPATIAL_MAP_TYPE  map_type = SPATIAL_MAP_TYPE.MESH,
bool  useChunkOnly = false,
int  maxMemoryUsage = 2048,
inline
Constructor
◆ get() [1/2]
static float get ( MAPPING_RESOLUTION  mappingResolution = MAPPING_RESOLUTION.MEDIUM)
inlinestatic
Parameters
mappingResolutionThe desired MAPPING_RESOLUTION.
Returns
The resolution in meters.
◆ get() [2/2]
static float get ( MAPPING_RANGE  mappingRange = MAPPING_RANGE.MEDIUM)
inlinestatic
Parameters
mappingRangeThe desired MAPPING_RANGE. Default: MAPPING_RANGE::MEDIUM.
Returns
The range in meters.
◆ set() [1/2]
void set ( MAPPING_RESOLUTION  mappingResolution = MAPPING_RESOLUTION.MEDIUM)
inline
Parameters
◆ set() [2/2]
void set ( MAPPING_RANGE  mappingRange = MAPPING_RANGE.MEDIUM)
inline
Parameters
Variables
◆ resolutionMeter
◆ rangeMeter
float rangeMeter
◆ saveTexture
Referenced by SpatialMappingParameters.SpatialMappingParameters().
◆ useChunkOnly
◆ maxMemoryUsage
◆ reverseVertexOrder
◆ map_type
