Mesh Class Reference
A mesh contains the geometric (and optionally texture) data of the scene captured by spatial mapping. More...
Attributes
int[] nbVerticesInSubmesh = new int[(int)Constant.MAX_SUBMESH]
 Total vertices in each chunk/submesh. More...
int[] nbTrianglesInSubmesh = new int[(int)Constant.MAX_SUBMESH]
 Total triangles in each chunk/submesh. More...
int[] updatedIndices = new int[(int)Constant.MAX_SUBMESH]
 Total indices per chunk/submesh. More...
int nbVertices = 0
 Vertex count in current submesh. More...
int nbTriangles = 0
 Triangle point counds in current submesh. (Every three values are the indexes of the three vertexes that make up one triangle) More...
int nbUpdatedSubmesh = 0
 How many submeshes were updated. More...
Vector3[] vertices = new Vector3[(int)Constant.MAX_SUBMESH]
 Vertices of the mesh. More...
int[] triangles = new int[(int)Constant.MAX_SUBMESH]
 Contains the index of the vertices. More...
Vector2[] uvs = null
 UVs defines the 2D projection of each vertices onto the Texture. Values are normalized [0;1], starting from the bottom left corner of the texture (as requested by opengl). In order to display a textured mesh you need to bind the Texture and then draw each triangles by picking its uv values. More...
IntPtr textures = IntPtr.Zero
 Texture of the mesh More...
int[] texturesSize = new int[2]
 Width and height of the mesh texture, if any. More...
Dictionary< int, Chunk > chunks = new Dictionary<int, Chunk>((int)Constant.MAX_SUBMESH)
 Dictionary of all existing chunks. More...
Variables
◆ nbVerticesInSubmesh
int [] nbVerticesInSubmesh = new int[(int)Constant.MAX_SUBMESH]
◆ nbTrianglesInSubmesh
int [] nbTrianglesInSubmesh = new int[(int)Constant.MAX_SUBMESH]
◆ updatedIndices
int [] updatedIndices = new int[(int)Constant.MAX_SUBMESH]
◆ nbVertices
int nbVertices = 0
◆ nbTriangles
int nbTriangles = 0
◆ nbUpdatedSubmesh
◆ vertices
Vector3 [] vertices = new Vector3[(int)Constant.MAX_SUBMESH]
◆ triangles
int [] triangles = new int[(int)Constant.MAX_SUBMESH]
◆ uvs
Vector2 [] uvs = null
◆ textures
Texture of the mesh
◆ texturesSize
int [] texturesSize = new int[2]
◆ chunks
Dictionary<int, Chunk> chunks = new Dictionary<int, Chunk>((int)Constant.MAX_SUBMESH)
