Pose structure with data on timing and validity in addition to position and rotation. More...
Attributes | |
bool | valid |
boolean that indicates if tracking is activated or not. You should check that first if something wrong. More... | |
ulong | timestamp |
Timestamp of the pose. This timestamp should be compared with the camera timestamp for synchronization. More... | |
Quaternion | rotation |
orientation from the pose. More... | |
Vector3 | translation |
translation from the pose. More... | |
int | pose_confidence |
Confidence/Quality of the pose estimation for the target frame. A confidence metric of the tracking[0 - 100], 0 means that the tracking is lost, 100 means that the tracking can be fully trusted. More... | |
float[] | pose_covariance |
6x6 Pose covariance of translation (the first 3 values) and rotation in so3 (the last 3 values) More... | |
float[] | twist |
Twist of the camera available in reference camera, this expresses velocity in free space, broken into its linear and angular parts. More... | |
float[] | twist_covariance |
Row-major representation of the 6x6 twist covariance matrix of the camera, this expresses the uncertainty of the twist. More... | |
bool valid |
ulong timestamp |
Quaternion rotation |
Vector3 translation |
int pose_confidence |
float [] pose_covariance |
float [] twist |
float [] twist_covariance |
