RuntimeParameters Class Reference
Runtime parameters used by the ZEDCamera.Grab() function, and its Camera::grab() counterpart in the SDK. More...
 RuntimeParameters (sl.SENSING_MODE smode=SENSING_MODE.STANDARD, REFERENCE_FRAME reframe=REFERENCE_FRAME.CAMERA, bool depth=true, int cnf_threshold=100, int txt_cnf_threshold=100, bool removeSaturatedAreas_=true)
 Constructor More...
Attributes
sl.SENSING_MODE sensingMode
 Defines the algorithm used for depth map computation, more info : SENSING_MODE definition. More...
sl.REFERENCE_FRAME measure3DReferenceFrame
 Provides 3D measures (point cloud and normals) in the desired reference frame (default is REFERENCE_FRAME_CAMERA). More...
bool enableDepth
 Defines whether the depth map should be computed. More...
int confidenceThreshold
 Defines the confidence threshold for the depth. Based on stereo matching score. More...
int textureConfidenceThreshold
 Defines texture confidence threshold for the depth. Based on textureness confidence. More...
 Defines if the saturated area (Luminance>=255) must be removed from depth map estimation More...
Constructor and Destructor
◆ RuntimeParameters()
RuntimeParameters ( sl.SENSING_MODE  smode = SENSING_MODE.STANDARD,
REFERENCE_FRAME  reframe = REFERENCE_FRAME.CAMERA,
bool  depth = true,
int  cnf_threshold = 100,
int  txt_cnf_threshold = 100,
bool  removeSaturatedAreas_ = true
inline
Constructor
Variables
◆ sensingMode
Referenced by Camera.GetRuntimeParameters(), and RuntimeParameters.RuntimeParameters().
◆ measure3DReferenceFrame
Referenced by RuntimeParameters.RuntimeParameters().
◆ enableDepth
bool enableDepth
◆ confidenceThreshold
◆ textureConfidenceThreshold
◆ removeSaturatedAreas
