CalibrationParameters Struct Reference
Holds calibration information about the current ZED's hardware, including per-sensor calibration and offsets between the two sensors. More...
Attributes
CameraParameters leftCam
 Parameters of the left sensor. More...
CameraParameters rightCam
 Parameters of the right sensor. More...
Quaternion Rot
 Rotation (using Rodrigues' transformation) between the two sensors. Defined as 'tilt', 'convergence' and 'roll'. More...
Vector3 Trans
 Translation between the two sensors. T[0] is the distance between the two cameras in meters. More...
For more info, see: https://www.stereolabs.com/docs/api_3.X/structsl_1_1CalibrationParameters.html
Variables
◆ leftCam
Referenced by Camera.GetFOV().
◆ rightCam
◆ Rot
Quaternion Rot
◆ Trans
Vector3 Trans
