Spatial Mapping Module
Classes
class  SpatialMappingParameters
 Sets the spatial mapping parameters. More...
class  Mesh
 A mesh contains the geometric (and optionally texture) data of the scene captured by spatial mapping. More...
struct  Chunk
 Represents a sub-mesh, it contains local vertices and triangles. More...
Enumerations
enum class  MAPPING_RESOLUTION
 Spatial mapping depth resolution presets. More...
enum class  MAPPING_RANGE
 Spatial mapping depth range presets. More...
enum class  SPATIAL_MAP_TYPE
 Spatial Mapping type (default is mesh) More...
enum class  MESH_FILE_FORMAT
 Mesh formats that can be saved/loaded with spatial mapping. More...
enum class  MESH_FILTER
 Presets for filtering meshes scannedw ith spatial mapping. Higher values reduce total face count by more. More...
enum class  SPATIAL_MAPPING_STATE
 Possible states of the ZED's Spatial Mapping system. More...
enum class  PLANE_TYPE
 Type of the plane, determined by its orientation and whether detected by ZEDPlaneDetectionManager's DetectFloorPlane() or DetectPlaneAtHit(). More...
enum class  AREA_EXPORT_STATE
 Possible states of the ZED's spatial memory area export, for saving 3D features used by the tracking system to relocalize the camera. This is used when saving a mesh generated by spatial mapping when Save Mesh is enabled - a .area file is saved as well. More...
◆ MAPPING_RESOLUTION
enum MAPPING_RESOLUTION
strong
Enumerator
HIGH
Create detailed geometry. Requires lots of memory.
MEDIUM
Small variations in the geometry will disappear. Useful for large objects.
LOW
Keeps only large variations of the geometry. Useful for outdoors.
◆ MAPPING_RANGE
enum MAPPING_RANGE
strong
Enumerator
NEAR
Geometry within 3.5 meters of the camera will be mapped.
MEDIUM
Geometry within 5 meters of the camera will be mapped.
FAR
Objects as far as 10 meters away are mapped. Useful for outdoors.
◆ SPATIAL_MAP_TYPE
enum SPATIAL_MAP_TYPE
strong
m
Enumerator
MESH
Represent a surface with faces, 3D points are linked by edges, no color information
FUSED_POINT_CLOUD
Geometry is represented by a set of 3D colored points.
◆ MESH_FILE_FORMAT
enum MESH_FILE_FORMAT
strong
Enumerator
PLY
Contains only vertices and faces.
BIN
Contains only vertices and faces, encoded in binary.
OBJ
Contains vertices, normals, faces, and texture information (if possible).
◆ MESH_FILTER
enum MESH_FILTER
strong
Enumerator
LOW
Soft decimation and smoothing.
MEDIUM
Decimate the number of faces and apply a soft smooth.
HIGH
Drastically reduce the number of faces.
◆ SPATIAL_MAPPING_STATE
enum SPATIAL_MAPPING_STATE
strong
Enumerator
INITIALIZING
Spatial mapping is initializing.
OK
Depth and tracking data were correctly integrated into the fusion algorithm.
NOT_ENOUGH_MEMORY
Maximum memory dedicated to scanning has been reached; the mesh will no longer be updated.
NOT_ENABLED
EnableSpatialMapping() wasn't called (or the scanning was stopped and not relaunched).
FPS_TOO_LOW
Effective FPS is too low to give proper results for spatial mapping. Consider using performance-friendly parameters (DEPTH_MODE_PERFORMANCE, VGA or HD720 camera resolution, and LOW spatial mapping resolution).
◆ PLANE_TYPE
enum PLANE_TYPE
strong
Enumerator
FLOOR
Floor plane of a scene. Retrieved by ZEDPlaneDetectionManager.DetectFloorPlane().
HIT_HORIZONTAL
Horizontal plane, such as a tabletop, floor, etc. Detected with DetectPlaneAtHit() using screen-space coordinates.
HIT_VERTICAL
Vertical plane, such as a wall. Detected with DetectPlaneAtHit() using screen-space coordinates.
HIT_UNKNOWN
Plane at an angle neither parallel nor perpendicular to the floor. Detected with DetectPlaneAtHit() using screen-space coordinates.
◆ AREA_EXPORT_STATE
enum AREA_EXPORT_STATE
strong
Enumerator
AREA_EXPORT_STATE_SUCCESS
Spatial memory file has been successfully created.
AREA_EXPORT_STATE_RUNNING
Spatial memory file is currently being written to.
AREA_EXPORT_STATE_NOT_STARTED
Spatial memory file export has not been called.
AREA_EXPORT_STATE_FILE_EMPTY
Spatial memory contains no data; the file is empty.
AREA_EXPORT_STATE_FILE_ERROR
Spatial memory file has not been written to because of a bad file name.
AREA_EXPORT_STATE_SPATIAL_MEMORY_DISABLED
Spatial memory has been disabled, so no file can be created.
