Container for information about the current SVO recording process. More...
Attributes | |
| bool | is_recording |
| Recorder status, true if enabled. More... | |
| bool | is_paused |
| Recorder status, true if the pause is enabled. More... | |
| bool | status |
| Status of the current frame. True if recording was successful, false if frame could not be written. More... | |
| double | current_compression_time |
| Compression time for the current frame in milliseconds. More... | |
| double | current_compression_ratio |
| Compression ratio (% of raw size) for the current frame. More... | |
| double | average_compression_time |
| Average compression time in millisecond since beginning of recording. More... | |
| double | average_compression_ratio |
| Compression ratio (% of raw size) since recording was started. More... | |
Mirrors RecordingStatus in the ZED C++ SDK. For more info, visit: https://www.stereolabs.com/docs/api_3.X/structsl_1_1RecordingStatus.html
| bool is_recording |
| bool is_paused |
| bool status |
| double current_compression_time |
| double current_compression_ratio |
| double average_compression_time |
| double average_compression_ratio |
