Core Module
Classes
struct  Matrix3x3
 Holds a 3x3 matrix that can be marshaled between the wrapper and C# scripts. More...
struct  Resolution
 Holds a camera resolution as two pointers (for height and width) for easy passing back and forth to the ZED wrapper. More...
struct  Rect
 Rect structure to define a rectangle or a ROI in pixels Use to set ROI target for AEC/AGC More...
struct  CameraConfiguration
 Structure containing information about the camera sensor More...
struct  CameraInformation
 Structure containing information of a single camera (serial number, model, input type, etc.) More...
class  Mat
 Mirrors the sl::Mat class used in the ZED C++ SDK to store images. Can be used to retrieve individual images from GPU or CPU memory: see Camera.RetrieveImage() and Camera.RetrieveMeasure(). More...
Enumerations
enum class  ERROR_CODE
 List of error codes in the ZED SDK. More...
enum class  COORDINATE_SYSTEM
 List of available coordinate systems. More...
enum class  UNIT
 Units used by the SDK for measurements and tracking. More...
enum class  MAT_TYPE
 Type of mat, indicating the data type and the number of channels it holds. Proper mat type depends on the image type. See sl.VIEW and sl.MEASURE (in ZEDCommon.cs) More...
enum class  COPY_TYPE
 Categories for copying data within or between the CPU (processor) memory and GPU (graphics card) memory. More...
enum class  MEM
 Which memory to store an image/mat: CPU/processor memory or GPU (graphics card) memory. More...
◆ ERROR_CODE
enum ERROR_CODE
strong
Mirrors ERROR_CODE in the ZED C++ SDK. For more info, read: https://www.stereolabs.com/docs/api_3.X/group__Core__group.html#ga4db9ee29f2ff83c71567c12f6bfbf28c
Enumerator
SUCCESS
Operation was successful.
FAILURE
Standard, generic code for unsuccessful behavior when no other code is more appropriate.
NO_GPU_COMPATIBLE
No GPU found, or CUDA capability of the device is not supported.
NOT_ENOUGH_GPUMEM
Not enough GPU memory for this depth mode. Try a different mode (such as PERFORMANCE).
CAMERA_NOT_DETECTED
The ZED camera is not plugged in or detected.
SENSORS_NOT_INITIALIZED
The MCU that controls the sensors module has an invalid Serial Number. You can try to recover it launching the 'ZED Diagnostic' tool from the command line with the option '-r'.
SENSOR_NOT_DETECTED
a ZED Mini is detected but the inertial sensor cannot be opened. (Never called for original ZED)
INVALID_RESOLUTION
For Nvidia Jetson X1 only - resolution not yet supported (USB3.0 bandwidth).
LOW_USB_BANDWIDTH
USB communication issues. Occurs when the camera FPS cannot be reached, due to a lot of corrupted frames. Try changing the USB port.
CALIBRATION_FILE_NOT_AVAILABLE
ZED calibration file is not found on the host machine. Use ZED Explorer or ZED Calibration to get one.
INVALID_CALIBRATION_FILE
ZED calibration file is not valid. Try downloading the factory one or recalibrating using the ZED Calibration tool.
INVALID_SVO_FILE
The provided SVO file is not valid.
SVO_RECORDING_ERROR
An SVO recorder-related error occurred (such as not enough free storage or an invalid file path).
SVO_UNSUPPORTED_COMPRESSION
An SVO related error when NVIDIA based compression cannot be loaded
INVALID_COORDINATE_SYSTEM
The requested coordinate system is not available.
INVALID_FIRMWARE
The firmware of the ZED is out of date. Update to the latest version.
INVALID_FUNCTION_PARAMETERS
An invalid parameter has been set for the function.
NOT_A_NEW_FRAME
In grab() only, the current call return the same frame as last call. Not a new frame.
CUDA_ERROR
In grab() only, a CUDA error has been detected in the process. Activate wrapperVerbose in ZEDManager.cs for more info.
CAMERA_NOT_INITIALIZED
In grab() only, ZED SDK is not initialized. Probably a missing call to sl::Camera::open.
NVIDIA_DRIVER_OUT_OF_DATE
Your NVIDIA driver is too old and not compatible with your current CUDA version.
INVALID_FUNCTION_CALL
The function call is not valid in the current context. Could be a missing a call to sl::Camera::open.
CORRUPTED_SDK_INSTALLATION
The SDK wasn't able to load its dependencies, the installer should be launched.
INCOMPATIBLE_SDK_VERSION
The installed SDK is not the SDK used to compile the program.
INVALID_AREA_FILE
The given area file does not exist. Check the file path.
INCOMPATIBLE_AREA_FILE
The area file does not contain enough data to be used ,or the sl::DEPTH_MODE used during the creation of the area file is different from the one currently set.
CAMERA_FAILED_TO_SETUP
Camera failed to set up.
CAMERA_DETECTION_ISSUE
Your ZED cannot be opened. Try replugging it to another USB port or flipping the USB-C connector (if using ZED Mini).
CAMERA_ALREADY_IN_USE
The Camera is already in use by another process.
NO_GPU_DETECTED
No GPU found or CUDA is unable to list it. Can be a driver/reboot issue.
PLANE_NOT_FOUND
Plane not found. Either no plane is detected in the scene, at the location or corresponding to the floor, or the floor plane doesn't match the prior given.
MODULE_NOT_COMPATIBLE_WITH_CAMERA
The Object detection module is only compatible with the ZED 2
MOTION_SENSORS_REQUIRED
The module needs the sensors to be enabled (see InitParameters::sensors_required)
MODULE_NOT_COMPATIBLE_WITH_CUDA_VERSION
The module needs a newer version of CUDA
ERROR_CODE_LAST
End of ERROR_CODE
◆ COORDINATE_SYSTEM
enum COORDINATE_SYSTEM
strong
Enumerator
Standard coordinates system used in computer vision. Used in OpenCV. See: http://docs.opencv.org/2.4/modules/calib3d/doc/camera_calibration_and_3d_reconstruction.html
LEFT_HANDED_Y_UP
Left-Handed with Y up and Z forward. Used in Unity3D with DirectX
RIGHT_HANDED_Y_UP
Right-Handed with Y pointing up and Z backward. Used in OpenGL.
RIGHT_HANDED_Z_UP
Right-Handed with Z pointing up and Y forward. Used in 3DSMax.
LEFT_HANDED_Z_UP
Left-Handed with Z axis pointing up and X forward. Used in Unreal Engine.
RIGHT_HANDED_Z_UP_X_FWD
Right-Handed with Z pointing up and X forward. Used in ROS (REP 103)
◆ UNIT
enum UNIT
strong
Enumerator
MILLIMETER
International System, 1/1000 meters.
CENTIMETER
International System, 1/100 meters.
METER
International System, 1/1 meters.
INCH
Imperial Unit, 1/12 feet.
FOOT
Imperial Unit, 1/1 feet.
◆ MAT_TYPE
enum MAT_TYPE
strong
Enumerator
MAT_32F_C1
Float, one channel. Used for depth and disparity Measure-type textures.
MAT_32F_C2
Float, two channels.
MAT_32F_C3
Float, three channels.
float 3 channels.
MAT_32F_C4
Float, four channels. Used for normals and XYZ (point cloud) measure-type textures
MAT_8U_C1
Unsigned char, one channel. Used for greyscale image-type textures like depth and confidence displays.
MAT_8U_C2
Unsigned char, two channels.
MAT_8U_C3
Unsigned char, three channels.
MAT_8U_C4
Unsigned char, four channels. Used for color images, like the main RGB image from each sensor.
MAT_16U_C1
Unsigned short 1 channel.
MAT_S8_C4
signed char 4 channels.
◆ COPY_TYPE
enum COPY_TYPE
strong
Enumerator
CPU_CPU
Copies data from one place in CPU memory to another.
copy data from CPU to CPU.
CPU_GPU
Copies data from CPU memory to GPU memory.
copy data from CPU to GPU.
GPU_GPU
Copies data from one place in GPU memory to another.
copy data from GPU to GPU.
GPU_CPU
Copies data from GPU memory to CPU memory.
copy data from GPU to CPU.
◆ MEM
enum MEM
strong
Enumerator
CPU
Store on memory accessible by the CPU.
GPU
Store on memory accessible by the GPU.
