Classes | |
class | RuntimeParameters |
Runtime parameters used by the ZEDCamera.Grab() function, and its Camera::grab() counterpart in the SDK. More... | |
struct | CameraParameters |
Calibration information for an individual sensor on the ZED (left or right). More... | |
struct | CalibrationParameters |
Holds calibration information about the current ZED's hardware, including per-sensor calibration and offsets between the two sensors. More... | |
Enumerations | |
enum class | DEPTH_MODE |
Lists available depth computation modes. Each mode offers better accuracy than the mode before it, but at a performance cost. More... | |
enum class | SENSING_MODE |
Lists available sensing modes - whether to produce the original depth map (STANDARD) or one with smoothing and other effects added to fill gaps and roughness (FILL). More... | |
enum class | MEASURE |
Lists available measure types retrieved from the camera, used for creating precise measurement maps (Measure-type textures). Based on the MEASURE enum in the ZED C++ SDK. For more info, see: https://www.stereolabs.com/docs/api_3.X/group__Depth__group.html#ga798a8eed10c573d759ef7e5a5bcd545d More... | |
strong |
Mirrors DEPTH_MODE in the ZED C++ SDK. For more info, see: https://www.stereolabs.com/docs/api_3.X/group__Depth__group.html#ga8d542017c9b012a19a15d46be9b7fa43
strong |
strong |
Enumerator | |
DISPARITY | Disparity map. As a ZEDMat, MAT_TYPE is set to MAT_32F_C1. |
DEPTH | Depth map. As a ZEDMat, MAT_TYPE is set to MAT_32F_C1. |
CONFIDENCE | Certainty/confidence of the disparity map. As a ZEDMat, MAT_TYPE is set to MAT_32F_C1. |
XYZ | 3D coordinates of the image points. Used for point clouds in ZEDPointCloudManager. As a ZEDMat, MAT_TYPE is set to MAT_32F_C4. The 4th channel may contain the colors. |
XYZRGBA | 3D coordinates and color of the image. As a ZEDMat, MAT_TYPE is set to MAT_32F_C4. The 4th channel encodes 4 UCHARs for colors in R-G-B-A order. |
XYZBGRA | 3D coordinates and color of the image. As a ZEDMat, MAT_TYPE is set to MAT_32F_C4. The 4th channel encode 4 UCHARs for colors in B-G-R-A order. |
XYZARGB | 3D coordinates and color of the image. As a ZEDMat, MAT_TYPE is set to MAT_32F_C4. The 4th channel encodes 4 UCHARs for color in A-R-G-B order. |
XYZABGR | 3D coordinates and color of the image. As a ZEDMat, MAT_TYPE is set to MAT_32F_C4. Channel 4 contains color in A-B-G-R order. |
NORMALS | 3D coordinates and color of the image. As a ZEDMat, MAT_TYPE is set to MAT_32F_C4. The 4th channel encode 4 UCHARs for color in A-B-G-R order. |
DISPARITY_RIGHT | Disparity map for the right sensor. As a ZEDMat, MAT_TYPE is set to MAT_32F_C1. |
DEPTH_RIGHT | Depth map for right sensor. As a ZEDMat, MAT_TYPE is set to MAT_32F_C1. |
XYZ_RIGHT | Point cloud for right sensor. As a ZEDMat, MAT_TYPE is set to MAT_32F_C4. Channel 4 is empty. |
XYZRGBA_RIGHT | Colored point cloud for right sensor. As a ZEDMat, MAT_TYPE is set to MAT_32F_C4. Channel 4 contains colors in R-G-B-A order. |
XYZBGRA_RIGHT | Colored point cloud for right sensor. As a ZEDMat, MAT_TYPE is set to MAT_32F_C4. Channel 4 contains colors in B-G-R-A order. |
XYZARGB_RIGHT | Colored point cloud for right sensor. As a ZEDMat, MAT_TYPE is set to MAT_32F_C4. Channel 4 contains colors in A-R-G-B order. |
XYZABGR_RIGHT | Colored point cloud for right sensor. As a ZEDMat, MAT_TYPE is set to MAT_32F_C4. Channel 4 contains colors in A-B-G-R order. |
NORMALS_RIGHT | Normals vector for right view. As a ZEDMat, MAT_TYPE is set to MAT_32F_C4. Channel 4 is empty (set to 0). |
DEPTH_U16_MM | Depth map in millimeter. Each pixel contains 1 unsigned short. As a Mat, MAT_TYPE is set to MAT_U16_C1. |
DEPTH_U16_MM_RIGHT | Depth map in millimeter for right sensor. Each pixel contains 1 unsigned short. As a Mat, MAT_TYPE is set to MAT_U16_C1. |
