types_c.h File Reference
Go to the source code of this file.
Data Structures
struct  SL_Quaternion
 Quaternion. More...
struct  SL_Vector2
 Vector2. More...
struct  SL_Vector3
 Vector3. More...
struct  SL_Vector4
 Vector4. More...
struct  SL_Uchar2
 uchar2 More...
struct  SL_Uchar3
 uchar3 More...
struct  SL_Uchar4
 uchar4 More...
struct  SL_Matrix4f
 Matric4x4. More...
struct  SL_Matrix3f
 Matrix3x3. More...
struct  SL_PoseData
struct  SL_PlaneData
struct  SL_IMUData
 IMU Data structure. More...
struct  SL_BarometerData
 Barometer Data structure. More...
struct  SL_MagnetometerData
 Magnometer Data structure. More...
struct  SL_TemperatureData
 Temperature Data structure. More...
struct  SL_SensorData
 Sensor Data structure. More...
struct  USB_product
struct  SL_Resolution
 Resolution. More...
struct  SL_InitParameters
struct  SL_RuntimeParameters
struct  SL_DeviceProperties
struct  SL_CameraParameters
struct  SL_CalibrationParameters
struct  SL_SensorParameters
 Structure containing information about a single sensor available in the current device. More...
struct  SL_CameraConfiguration
 Structure containing information about the camera sensor. More...
struct  SL_SensorsConfiguration
struct  SL_CameraInformation
 Structure containing information of a single camera (serial number, model, input type, etc.) More...
struct  SL_PositionalTrackingParameters
struct  SL_RecordingStatus
 Recording structure that contains information about SVO. More...
struct  SL_RecordingParameters
 Sets the recording parameters. More...
struct  SL_StreamingParameters
 Sets the streaming parameters. More...
struct  SL_StreamingProperties
struct  SL_SpatialMappingParameters
struct  SL_BatchParameters
struct  SL_AI_Model_status
 contains AI model status. More...
struct  SL_ObjectDetectionParameters
struct  SL_ObjectDetectionRuntimeParameters
struct  SL_ObjectData
struct  SL_CustomBoxObjectData
 Container to store the externally detected objects. The objects can be ingested using sl_ingest_custom_box_objects() functions to extract 3D information and tracking over time. More...
struct  SL_Objects
struct  SL_ObjectsBatch
 Objects batch structure. More...
struct  SL_Rect
Macros
#define WITH_OBJECT_DETECTION   1
#define MAX_CAMERA_PLUGIN   4
#define MAX_SUBMESH   1000
#define MAX_NUMBER_OBJECT   75
#define MAX_TRAJECTORY_SIZE   200
Enumerations
enum  UNITY_PLAN_TYPE
enum  SL_HEADING_STATE
 Heading state enum. More...
enum  USB_DEVICE
enum  SL_ERROR_CODE
 Lists error codes in the ZED SDK. More...
enum  SL_RESOLUTION
 Represents the available resolution defined in the cameraResolution list. More...
enum  SL_UNIT
 Lists available unit for measures. More...
enum  SL_COORDINATE_SYSTEM
 Lists available coordinates systems for positional tracking and 3D measures. More...
enum  SL_CAMERA_STATE
 List of possible camera state. More...
enum  SL_MODEL
 Lists compatible ZED Camera model. More...
enum  SL_MEM
 List available memory type. More...
enum  SL_SENSOR_TYPE
 List of the available onboard sensors. More...
enum  SL_SENSORS_UNIT
 List of the available onboard sensors measurement units. More...
enum  SL_SIDE
enum  SL_INPUT_TYPE
enum  SL_REFERENCE_FRAME
 Defines which type of position matrix is used to store camera path and pose. More...
enum  SL_SENSOR_WORLD
 Lists different World frame available
More...
enum  SL_TIME_REFERENCE
 Lists specific and particular timestamps. More...
enum  SL_STREAMING_CODEC
 List of codec. More...
enum  SL_VIDEO_SETTINGS
 Lists available camera settings for the ZED camera (contrast, hue, saturation, gain...). More...
enum  SL_MEASURE
 Lists retrievable measures. More...
enum  SL_VIEW
 Lists available views. More...
enum  SL_OBJECT_TRACKING_STATE
 Lists available object tracking state. More...
enum  SL_POSITIONAL_TRACKING_STATE
 Lists the different states of positional tracking. More...
enum  SL_AREA_EXPORTING_STATE
 Lists the different states of spatial memory area export. More...
enum  SL_SPATIAL_MAPPING_STATE
 Gives the spatial mapping state. More...
enum  SL_SPATIAL_MAP_TYPE
 Lists the types of spatial maps that can be created. More...
enum  SL_MESH_FILTER
 Lists available mesh filtering intensity. More...
enum  SL_MESH_FILE_FORMAT
 Lists available mesh file formats. More...
enum  SL_SENSING_MODE
 Lists available depth sensing modes. More...
enum  SL_DEPTH_MODE
 Lists available depth computation modes. More...
enum  SL_FLIP_MODE
 Gives the camera flip mode. More...
enum  SL_COPY_TYPE
 List available copy operation on Mat. More...
enum  SL_SVO_COMPRESSION_MODE
 Lists available compression modes for SVO recording. More...
enum  SL_MAT_TYPE
 List available Mat formats. More...
enum  SL_OBJECT_SUBCLASS
 Available object subclass, given as hint, when using object tracking an object can change of OBJECT_SUBCLASS while keeping the same OBJECT_CLASS and id (i.e: frame M: MOTORBIKE, frame N:BICYCLE) More...
enum  SL_OBJECT_ACTION_STATE
 Lists available object action state. More...
enum  SL_DETECTION_MODEL
 List available models for detection. More...
enum  SL_AI_MODELS
 Lists available AI moles.
enum  SL_OBJECT_FILTERING_MODE
 Lists of supported bounding box preprocessing. More...
enum  SL_BODY_FORMAT
 Lists of supported skeleton body model. More...
enum  SL_BODY_PARTS_POSE_18
 semantic of human body parts and order of ObjectData::keypoint.
enum  SL_BODY_PARTS_POSE_34
 semantic of human body parts and order of ObjectData::keypoint for BODY_FORMAT::POSE_34.
enum  SL_OBJECT_CLASS
 Lists available object class. More...
Variables
const int SL_VIDEO_SETTINGS_VALUE_AUTO = -1
◆ SL_HEADING_STATE
Heading state enum.
Enumerator
SL_HEADING_STATE_GOOD
The heading is reliable and not affected by iron interferences.
SL_HEADING_STATE_OK
The heading is reliable, but affected by slight iron interferences.
SL_HEADING_STATE_NOT_GOOD
The heading is not reliable because affected by strong iron interferences.
SL_HEADING_STATE_NOT_CALIBRATED
The magnetometer has not been calibrated.
SL_HEADING_STATE_MAG_NOT_AVAILABLE
The magnetomer sensor is not available.
◆ SL_ERROR_CODE
Enumerator
SL_ERROR_CODE_SUCCESS
Standard code for successful behavior.
SL_ERROR_CODE_FAILURE
Standard code for unsuccessful behavior.
SL_ERROR_CODE_NO_GPU_COMPATIBLE
No GPU found or CUDA capability of the device is not supported.
SL_ERROR_CODE_NOT_ENOUGH_GPU_MEMORY
Not enough GPU memory for this depth mode, try a different mode (such as PERFORMANCE), or increase the minimum depth value (see InitParameters::depth_minimum_distance).
SL_ERROR_CODE_CAMERA_NOT_DETECTED
The ZED camera is not plugged or detected.
SL_ERROR_CODE_SENSORS_NOT_INITIALIZED
The MCU that controls the sensors module has an invalid Serial Number. You can try to recover it launching the 'ZED Diagnostic' tool from the command line with the option '-r'.
SL_ERROR_CODE_SENSORS_NOT_AVAILABLE
a ZED-M or ZED2/2i camera is detected but the sensors (imu,barometer...) cannot be opened. Only for ZED-M or ZED2/2i devices. Unplug/replug is required
SL_ERROR_CODE_INVALID_RESOLUTION
In case of invalid resolution parameter, such as a upsize beyond the original image size in Camera::retrieveImage
SL_ERROR_CODE_LOW_USB_BANDWIDTH
This issue can occurs when you use multiple ZED or a USB 2.0 port (bandwidth issue).
SL_ERROR_CODE_CALIBRATION_FILE_NOT_AVAILABLE
ZED calibration file is not found on the host machine. Use ZED Explorer or ZED Calibration to get one.
SL_ERROR_CODE_INVALID_CALIBRATION_FILE
ZED calibration file is not valid, try to download the factory one or recalibrate your camera using 'ZED Calibration'.
SL_ERROR_CODE_INVALID_SVO_FILE
The provided SVO file is not valid.
SL_ERROR_CODE_SVO_RECORDING_ERROR
An recorder related error occurred (not enough free storage, invalid file).
SL_ERROR_CODE_SVO_UNSUPPORTED_COMPRESSION
An SVO related error when NVIDIA based compression cannot be loaded.
SL_ERROR_CODE_END_OF_SVOFILE_REACHED
SVO end of file has been reached, and no frame will be available until the SVO position is reset.
SL_ERROR_CODE_INVALID_COORDINATE_SYSTEM
The requested coordinate system is not available.
SL_ERROR_CODE_INVALID_FIRMWARE
The firmware of the ZED is out of date. Update to the latest version.
SL_ERROR_CODE_INVALID_FUNCTION_PARAMETERS
An invalid parameter has been set for the function.
SL_ERROR_CODE_CUDA_ERROR
In grab() or retrieveXXX() only, a CUDA error has been detected in the process. Activate verbose in SL_Camera::open for more info.
SL_ERROR_CODE_CAMERA_NOT_INITIALIZED
In grab() only, ZED SDK is not initialized. Probably a missing call to SL_Camera::open.
SL_ERROR_CODE_NVIDIA_DRIVER_OUT_OF_DATE
Your NVIDIA driver is too old and not compatible with your current CUDA version.
SL_ERROR_CODE_INVALID_FUNCTION_CALL
The call of the function is not valid in the current context. Could be a missing call of SL_Camera::open.
SL_ERROR_CODE_CORRUPTED_SDK_INSTALLATION
The SDK wasn't able to load its dependencies or somes assets are missing, the installer should be launched.
SL_ERROR_CODE_INCOMPATIBLE_SDK_VERSION
The installed SDK is incompatible SDK used to compile the program.
SL_ERROR_CODE_INVALID_AREA_FILE
The given area file does not exist, check the path.
SL_ERROR_CODE_INCOMPATIBLE_AREA_FILE
The area file does not contain enought data to be used or the SL_DEPTH_MODE used during the creation of the area file is different from the one currently set.
SL_ERROR_CODE_CAMERA_FAILED_TO_SETUP
Failed to open the camera at the proper resolution. Try another resolution or make sure that the UVC driver is properly installed.
SL_ERROR_CODE_CAMERA_DETECTION_ISSUE
Your ZED can not be opened, try replugging it to another USB port or flipping the USB-C connector.
SL_ERROR_CODE_CANNOT_START_CAMERA_STREAM
Cannot start camera stream. Make sure your camera is not already used by another process or blocked by firewall or antivirus.
SL_ERROR_CODE_NO_GPU_DETECTED
No GPU found, CUDA is unable to list it. Can be a driver/reboot issue.
SL_ERROR_CODE_PLANE_NOT_FOUND
Plane not found, either no plane is detected in the scene, at the location or corresponding to the floor, or the floor plane doesn't match the prior given
SL_ERROR_CODE_MODULE_NOT_COMPATIBLE_WITH_CAMERA
The Object detection module is only compatible with the ZED 2
SL_ERROR_CODE_MOTION_SENSORS_REQUIRED
The module needs the sensors to be enabled (see InitParameters::disable_sensors)
SL_ERROR_CODE_MODULE_NOT_COMPATIBLE_WITH_CUDA_VERSION
The module needs a newer version of CUDA
◆ SL_RESOLUTION
Note
The VGA resolution does not respect the 640*480 standard to better fit the camera sensor (672*376 is used).
Enumerator
SL_RESOLUTION_HD2K
2208*1242, available framerates: 15 fps.
SL_RESOLUTION_HD1080
1920*1080, available framerates: 15, 30 fps.
SL_RESOLUTION_HD720
1280*720, available framerates: 15, 30, 60 fps.
SL_RESOLUTION_VGA
672*376, available framerates: 15, 30, 60, 100 fps.
◆ SL_UNIT
enum SL_UNIT
Enumerator
SL_UNIT_MILLIMETER
International System, 1/1000 METER.
SL_UNIT_CENTIMETER
International System, 1/100 METER.
SL_UNIT_METER
International System, 1 METER
SL_UNIT_INCH
Imperial Unit, 1/12 FOOT
SL_UNIT_FOOT
Imperial Unit, 1 FOOT
◆ SL_COORDINATE_SYSTEM
Enumerator
SL_COORDINATE_SYSTEM_IMAGE
Standard coordinates system in computer vision. Used in OpenCV : see here : http://docs.opencv.org/2.4/modules/calib3d/doc/camera_calibration_and_3d_reconstruction.html
SL_COORDINATE_SYSTEM_LEFT_HANDED_Y_UP
Left-Handed with Y up and Z forward. Used in Unity with DirectX.
SL_COORDINATE_SYSTEM_RIGHT_HANDED_Y_UP
Right-Handed with Y pointing up and Z backward. Used in OpenGL.
SL_COORDINATE_SYSTEM_RIGHT_HANDED_Z_UP
Right-Handed with Z pointing up and Y forward. Used in 3DSMax.
SL_COORDINATE_SYSTEM_LEFT_HANDED_Z_UP
Left-Handed with Z axis pointing up and X forward. Used in Unreal Engine.
SL_COORDINATE_SYSTEM_RIGHT_HANDED_Z_UP_X_FWD
Right-Handed with Z pointing up and X forward. Used in ROS (REP 103).
◆ SL_CAMERA_STATE
Enumerator
SL_CAMERA_STATE_AVAILABLE
Defines if the camera can be opened by the SDK
SL_CAMERA_STATE_NOT_AVAILABLE
Defines if the camera is already opened and unavailable
◆ SL_MODEL
enum SL_MODEL
Enumerator
SL_MODEL_ZED
Defines ZED Camera model
SL_MODEL_ZED_M
Defines ZED Mini (ZED-M) Camera model
SL_MODEL_ZED2
Defines ZED 2 Camera model
SL_MODEL_ZED2i
Defines ZED 2i Camera model
◆ SL_MEM
enum SL_MEM
Enumerator
SL_MEM_CPU
CPU Memory (Processor side).
SL_MEM_GPU
GPU Memory (Graphic card side).
◆ SL_SENSOR_TYPE
Enumerator
SL_SENSOR_TYPE_ACCELEROMETER
Three axis Accelerometer sensor to measure the inertial accelerations.
SL_SENSOR_TYPE_GYROSCOPE
Three axis Gyroscope sensor to measure the angular velocitiers.
SL_SENSOR_TYPE_MAGNETOMETER
Three axis Magnetometer sensor to measure the orientation of the device respect to the earth magnetic field.
SL_SENSOR_TYPE_BAROMETER
Barometer sensor to measure the atmospheric pressure.
◆ SL_SENSORS_UNIT
Enumerator
SL_SENSORS_UNIT_M_SEC_2
Acceleration [m/s²].
SL_SENSORS_UNIT_DEG_SEC
Angular velocity [deg/s].
SL_SENSORS_UNIT_U_T
MAgnetic Fiels [uT].
SL_SENSORS_UNIT_HPA
Atmospheric pressure [hPa].
SL_SENSORS_UNIT_CELSIUS
Temperature [°C].
SL_SENSORS_UNIT_HERTZ
Frequency [Hz].
◆ SL_SIDE
enum SL_SIDE
Enumerator
SL_SIDE_LEFT
Left side only.
SL_SIDE_RIGHT
Right side only.
SL_SIDE_BOTH
Left and Right side.
◆ SL_REFERENCE_FRAME
Enumerator
SL_REFERENCE_FRAME_WORLD
The transform of SL_Pose will contains the motion with reference to the world frame (previously called PATH).
SL_REFERENCE_FRAME_CAMERA
The transform of SL_Pose will contains the motion with reference to the previous camera frame (previously called POSE).
◆ SL_SENSOR_WORLD
Enumerator
SL_SENSOR_WORLD_OFF
default behavior.
SL_SENSOR_WORLD_IMU_GRAVITY
align world to imu gravity measurement. keep the yaw from the user
◆ SL_TIME_REFERENCE
Enumerator
SL_TIME_REFERENCE_CURRENT
Defines the timestamp at the time the frame has been extracted from USB stream.
◆ SL_STREAMING_CODEC
List of codec.
Enumerator
SL_STREAMING_CODEC_H264
AVCHD/H264 encoding used in image streaming.
SL_STREAMING_CODEC_H265
HEVC/H265 encoding used in image streaming.
◆ SL_VIDEO_SETTINGS
Warning
GAIN and EXPOSURE are linked in auto/default mode (see SL_Camera::setCameraSettings).
Enumerator
SL_VIDEO_SETTINGS_BRIGHTNESS
Defines the brightness control. Affected value should be between 0 and 8.
SL_VIDEO_SETTINGS_CONTRAST
Defines the contrast control. Affected value should be between 0 and 8.
SL_VIDEO_SETTINGS_HUE
Defines the hue control. Affected value should be between 0 and 11.
SL_VIDEO_SETTINGS_SATURATION
Defines the saturation control. Affected value should be between 0 and 8.
SL_VIDEO_SETTINGS_SHARPNESS
Defines the digital sharpening control. Affected value should be between 0 and 8.
SL_VIDEO_SETTINGS_GAMMA
Defines the ISP gamma control. Affected value should be between 1 and 9.
SL_VIDEO_SETTINGS_GAIN
Defines the gain control. Affected value should be between 0 and 100 for manual control.
SL_VIDEO_SETTINGS_EXPOSURE
Defines the exposure control. Affected value should be between 0 and 100 for manual control.
The exposition is mapped linearly in a percentage of the following max values. Special case for the setExposure(0) that corresponds to 0.17072ms.
The conversion to milliseconds depends on the framerate:
  • 15fps setExposure(100) -> 19.97ms
  • 30fps setExposure(100) -> 19.97ms
  • 60fps setExposure(100) -> 10.84072ms
  • 100fps setExposure(100) -> 10.106624ms
SL_VIDEO_SETTINGS_AEC_AGC
Defines if the Gain and Exposure are in automatic mode or not. Setting a Gain or Exposure through @GAIN or @EXPOSURE values will automatically set this value to 0.
SL_VIDEO_SETTINGS_AEC_AGC_ROI
Defines the region of interest for automatic exposure/gain computation. To be used with overloaded @setCameraSettings/@getCameraSettings functions.
SL_VIDEO_SETTINGS_WHITEBALANCE_TEMPERATURE
Defines the color temperature value. Setting a value will automatically set @WHITEBALANCE_AUTO to 0. Affected value should be between 2800 and 6500 with a step of 100.
SL_VIDEO_SETTINGS_WHITEBALANCE_AUTO
Defines if the White balance is in automatic mode or not
SL_VIDEO_SETTINGS_LED_STATUS
Defines the status of the camera front LED. Set to 0 to disable the light, 1 to enable the light. Default value is on. Requires Camera FW 1523 at least.
◆ SL_MEASURE
enum SL_MEASURE
Enumerator
SL_MEASURE_DEPTH
Disparity map. Each pixel contains 1 float. SL_MAT_TYPE_F32_C1.
SL_MEASURE_CONFIDENCE
Depth map. In SL_UNIT defined in SL_InitParameters. Each pixel contains 1 float. SL_MAT_TYPE_F32_C1.
SL_MEASURE_XYZ
Certainty/confidence of the depth map. Each pixel contains 1 float. SL_MAT_TYPE_F32_C1.
SL_MEASURE_XYZRGBA
Point cloud. Each pixel contains 4 float (X, Y, Z, not used). SL_MAT_TYPE_F32_C4.
SL_MEASURE_XYZBGRA
Colored point cloud. Each pixel contains 4 float (X, Y, Z, color). The color need to be read as an unsigned char[4] representing the RGBA color. SL_MAT_TYPE_F32_C4.
SL_MEASURE_XYZARGB
Colored point cloud. Each pixel contains 4 float (X, Y, Z, color). The color need to be read as an unsigned char[4] representing the BGRA color. SL_MAT_TYPE_F32_C4.
SL_MEASURE_XYZABGR
Colored point cloud. Each pixel contains 4 float (X, Y, Z, color). The color need to be read as an unsigned char[4] representing the ARGB color. SL_MAT_TYPE_F32_C4.
SL_MEASURE_NORMALS
Colored point cloud. Each pixel contains 4 float (X, Y, Z, color). The color need to be read as an unsigned char[4] representing the ABGR color. SL_MAT_TYPE_F32_C4.
SL_MEASURE_DISPARITY_RIGHT
Normals vector. Each pixel contains 4 float (X, Y, Z, 0). SL_MAT_TYPE_F32_C4. Disparity map for right sensor. Each pixel contains 1 float. SL_MAT_TYPE_F32_C1.
SL_MEASURE_XYZ_RIGHT
Depth map for right sensor. Each pixel contains 1 float. SL_MAT_TYPE_F32_C1.
SL_MEASURE_XYZRGBA_RIGHT
Point cloud for right sensor. Each pixel contains 4 float (X, Y, Z, not used). SL_MAT_TYPE_F32_C4.
SL_MEASURE_XYZBGRA_RIGHT
Colored point cloud for right sensor. Each pixel contains 4 float (X, Y, Z, color). The color need to be read as an unsigned char[4] representing the RGBA color. SL_MAT_TYPE_F32_C4.
SL_MEASURE_XYZARGB_RIGHT
Colored point cloud for right sensor. Each pixel contains 4 float (X, Y, Z, color). The color need to be read as an unsigned char[4] representing the BGRA color. SL_MAT_TYPE_F32_C4.
SL_MEASURE_XYZABGR_RIGHT
Colored point cloud for right sensor. Each pixel contains 4 float (X, Y, Z, color). The color need to be read as an unsigned char[4] representing the ARGB color. SL_MAT_TYPE_F32_C4.
SL_MEASURE_NORMALS_RIGHT
Colored point cloud for right sensor. Each pixel contains 4 float (X, Y, Z, color). The color need to be read as an unsigned char[4] representing the ABGR color. SL_MAT_TYPE_F32_C4.
SL_MEASURE_DEPTH_U16_MM
Normals vector for right view. Each pixel contains 4 float (X, Y, Z, 0). SL_MAT_TYPE_F32_C4.
SL_MEASURE_DEPTH_U16_MM_RIGHT
Depth map in millimeter whatever the SL_UNIT defined in SL_InitParameters. Invalid values are set to 0, depth values are clamped at 65000. Each pixel contains 1 unsigned short. SL_MAT_TYPE_U16_C1. Depth map in millimeter for right sensor. Each pixel contains 1 unsigned short. SL_MAT_TYPE_U16_C1.
◆ SL_VIEW
enum SL_VIEW
Enumerator
SL_VIEW_RIGHT
Left BGRA image. Each pixel contains 4 unsigned char (B,G,R,A). SL_MAT_TYPE_U8_C4.
SL_VIEW_LEFT_GRAY
Right BGRA image. Each pixel contains 4 unsigned char (B,G,R,A). SL_MAT_TYPE_U8_C4.
SL_VIEW_RIGHT_GRAY
Left GRAY image. Each pixel contains 1 unsigned char. SL_MAT_TYPE_U8_C1.
SL_VIEW_LEFT_UNRECTIFIED
Right GRAY image. Each pixel contains 1 unsigned char. SL_MAT_TYPE_U8_C1.
SL_VIEW_RIGHT_UNRECTIFIED
Left BGRA unrectified image. Each pixel contains 4 unsigned char (B,G,R,A). SL_MAT_TYPE_U8_C4.
SL_VIEW_LEFT_UNRECTIFIED_GRAY
Right BGRA unrectified image. Each pixel contains 4 unsigned char (B,G,R,A). SL_MAT_TYPE_U8_C4.
SL_VIEW_RIGHT_UNRECTIFIED_GRAY
Left GRAY unrectified image. Each pixel contains 1 unsigned char. SL_MAT_TYPE_U8_C1.
SL_VIEW_SIDE_BY_SIDE
Right GRAY unrectified image. Each pixel contains 1 unsigned char. SL_MAT_TYPE_U8_C1.
SL_VIEW_DEPTH
Left and right image (the image width is therefore doubled). Each pixel contains 4 unsigned char (B,G,R,A). SL_MAT_TYPE_U8_C4.
SL_VIEW_CONFIDENCE
Color rendering of the depth. Each pixel contains 4 unsigned char (B,G,R,A). SL_MAT_TYPE_U8_C4. Use MEASURE_DEPTH with Camera.retrieveMeasure() to get depth values.
SL_VIEW_NORMALS
Color rendering of the depth confidence. Each pixel contains 4 unsigned char (B,G,R,A). SL_MAT_TYPE_U8_C4.
SL_VIEW_DEPTH_RIGHT
Color rendering of the normals. Each pixel contains 4 unsigned char (B,G,R,A). SL_MAT_TYPE_U8_C4.
SL_VIEW_NORMALS_RIGHT
Color rendering of the right depth mapped on right sensor. Each pixel contains 4 unsigned char (B,G,R,A). SL_MAT_TYPE_U8_C4. Color rendering of the normals mapped on right sensor. Each pixel contains 4 unsigned char (B,G,R,A). SL_MAT_TYPE_U8_C4.
◆ SL_OBJECT_TRACKING_STATE
Enumerator
SL_OBJECT_TRACKING_STATE_OFF
The tracking is not yet initialized, the object ID is not usable
SL_OBJECT_TRACKING_STATE_OK
The object is tracked
SL_OBJECT_TRACKING_STATE_SEARCHING
The object couldn't be detected in the image and is potentially occluded, the trajectory is estimated
SL_OBJECT_TRACKING_STATE_TERMINATE
This is the last searching state of the track, the track will be deleted in the next retreiveObject
◆ SL_POSITIONAL_TRACKING_STATE
Enumerator
SL_POSITIONAL_TRACKING_STATE_OK
The camera is searching for a previously known position to locate itself.
SL_POSITIONAL_TRACKING_STATE_OFF
Positional tracking is working normally.
SL_POSITIONAL_TRACKING_STATE_FPS_TOO_LOW
Positional tracking is not enabled.
SL_POSITIONAL_TRACKING_STATE_SEARCHING_FLOOR_PLANE
Effective FPS is too low to give proper results for motion tracking. Consider using PERFORMANCES parameters (DEPTH_MODE_PERFORMANCE, low camera resolution (VGA,HD720)) The camera is searching for the floor plane to locate itself related to it, the REFERENCE_FRAME::WORLD will be set afterward.
◆ SL_AREA_EXPORTING_STATE
Enumerator
SL_AREA_EXPORTING_STATE_SUCCESS
The spatial memory file has been successfully created.
SL_AREA_EXPORTING_STATE_RUNNING
The spatial memory is currently written.
SL_AREA_EXPORTING_STATE_NOT_STARTED
The spatial memory file exportation has not been called.
SL_AREA_EXPORTING_STATE_FILE_EMPTY
The spatial memory contains no data, the file is empty.
SL_AREA_EXPORTING_STATE_FILE_ERROR
The spatial memory file has not been written because of a wrong file name.
SL_AREA_EXPORTING_STATE_SPATIAL_MEMORY_DISABLED
The spatial memory learning is disable, no file can be created.
◆ SL_SPATIAL_MAPPING_STATE
Enumerator
SL_SPATIAL_MAPPING_STATE_OK
The spatial mapping is initializing.
SL_SPATIAL_MAPPING_STATE_NOT_ENOUGH_MEMORY
The depth and tracking data were correctly integrated in the fusion algorithm.
SL_SPATIAL_MAPPING_STATE_NOT_ENABLED
The maximum memory dedicated to the scanning has been reach, the mesh will no longer be updated.
SL_SPATIAL_MAPPING_STATE_FPS_TOO_LOW
Camera::enableSpatialMapping() wasn't called (or the scanning was stopped and not relaunched).
◆ SL_SPATIAL_MAP_TYPE
Enumerator
SL_SPATIAL_MAP_TYPE_MESH
Represents a surface with faces, 3D points are linked by edges, no color information.
SL_SPATIAL_MAP_TYPE_FUSED_POINT_CLOUD
Geometry is represented by a set of 3D colored points.
◆ SL_MESH_FILTER
Enumerator
SL_MESH_FILTER_LOW
Clean the mesh by closing small holes and removing isolated faces.
SL_MESH_FILTER_MEDIUM
Soft decimation and smoothing.
SL_MESH_FILTER_HIGH
Decimate the number of triangles and apply a soft smooth.
◆ SL_MESH_FILE_FORMAT
Enumerator
SL_MESH_FILE_FORMAT_PLY
Contains only vertices and faces.
SL_MESH_FILE_FORMAT_PLY_BIN
Contains only vertices and faces, encoded in binary.
SL_MESH_FILE_FORMAT_OBJ
Contains vertices, normals, faces and textures informations if possible.
◆ SL_SENSING_MODE
Enumerator
SL_SENSING_MODE_STANDARD
This mode outputs ZED standard depth map that preserves edges and depth accuracy. Applications example: Obstacle detection, Automated navigation, People detection, 3D reconstruction, measurements.
SL_SENSING_MODE_FILL
This mode outputs a smooth and fully dense depth map. Applications example: AR/VR, Mixed-reality capture, Image post-processing.
◆ SL_DEPTH_MODE
Enumerator
SL_DEPTH_MODE_PERFORMANCE
This mode does not compute any depth map. Only rectified stereo images will be available.
SL_DEPTH_MODE_QUALITY
Computation mode optimized for speed.
SL_DEPTH_MODE_ULTRA
Computation mode designed for challenging areas with untextured surfaces.
SL_DEPTH_MODE_NEURAL
Computation mode favorising edges and sharpness. Requires more GPU memory and computation power. End to End Neural disparity estimation, requires AI module
◆ SL_FLIP_MODE
Enumerator
SL_FLIP_MODE_ON
default behavior.
SL_FLIP_MODE_AUTO
Images and camera sensors data are flipped useful when your camera is mounted upside down.
◆ SL_COPY_TYPE
Enumerator
SL_COPY_TYPE_CPU_CPU
copy data from CPU to CPU.
SL_COPY_TYPE_CPU_GPU
copy data from CPU to GPU.
SL_COPY_TYPE_GPU_GPU
copy data from GPU to GPU.
SL_COPY_TYPE_GPU_CPU
copy data from GPU to CPU.
◆ SL_SVO_COMPRESSION_MODE
SL_SVO_COMPRESSION_MODE_LOSSLESS is an improvement of previous lossless compression (used in ZED Explorer), even if size may be bigger, compression time is much faster.
Enumerator
PNG/ZSTD (lossless) CPU based compression : avg size = 42% (of RAW).
SL_SVO_COMPRESSION_MODE_H264
H264(AVCHD) GPU based compression : avg size = 1% (of RAW). Requires a NVIDIA GPU
SL_SVO_COMPRESSION_MODE_H265
H265(HEVC) GPU based compression: avg size = 1% (of RAW). Requires a NVIDIA GPU, Pascal architecture or newer
SL_SVO_COMPRESSION_MODE_H264_LOSSLESS
H264 Lossless GPU/Hardware based compression: avg size = 25% (of RAW). Provides a SSIM/PSNR result (vs RAW) >= 99.9%. Requires a NVIDIA GPU
SL_SVO_COMPRESSION_MODE_H265_LOSSLESS
H265 Lossless GPU/Hardware based compression: avg size = 25% (of RAW). Provides a SSIM/PSNR result (vs RAW) >= 99.9%. Requires a NVIDIA GPU
◆ SL_MAT_TYPE
Enumerator
SL_MAT_TYPE_F32_C1
float 1 channel.
SL_MAT_TYPE_F32_C2
float 2 channels.
SL_MAT_TYPE_F32_C3
float 3 channels.
SL_MAT_TYPE_F32_C4
float 4 channels.
SL_MAT_TYPE_U8_C1
unsigned char 1 channel.
SL_MAT_TYPE_U8_C2
unsigned char 2 channels.
SL_MAT_TYPE_U8_C3
unsigned char 3 channels.
SL_MAT_TYPE_U8_C4
unsigned char 4 channels.
SL_MAT_TYPE_U16_C1
unsigned short 1 channel.
SL_MAT_TYPE_S8_C4
◆ SL_OBJECT_SUBCLASS
Enumerator
SL_OBJECT_SUBCLASS_PERSON
PERSON / PERSON_BODY
SL_OBJECT_SUBCLASS_BICYCLE
VEHICLE
SL_OBJECT_SUBCLASS_CAR
VEHICLE
SL_OBJECT_SUBCLASS_MOTORBIKE
VEHICLE
SL_OBJECT_SUBCLASS_BUS
VEHICLE
SL_OBJECT_SUBCLASS_TRUCK
VEHICLE
SL_OBJECT_SUBCLASS_BOAT
VEHICLE
SL_OBJECT_SUBCLASS_BACKPACK
BAG
SL_OBJECT_SUBCLASS_HANDBAG
BAG
SL_OBJECT_SUBCLASS_SUITCASE
BAG
SL_OBJECT_SUBCLASS_BIRD
ANIMAL
SL_OBJECT_SUBCLASS_CAT
ANIMAL
SL_OBJECT_SUBCLASS_DOG
ANIMAL
SL_OBJECT_SUBCLASS_HORSE
ANIMAL
SL_OBJECT_SUBCLASS_SHEEP
ANIMAL
SL_OBJECT_SUBCLASS_COW
ANIMAL
SL_OBJECT_SUBCLASS_CELLPHONE
ELECTRONIC
SL_OBJECT_SUBCLASS_LAPTOP
ELECTRONIC
SL_OBJECT_SUBCLASS_BANANA
FRUIT/VEGETABLE
SL_OBJECT_SUBCLASS_APPLE
FRUIT/VEGETABLE
SL_OBJECT_SUBCLASS_ORANGE
FRUIT/VEGETABLE
SL_OBJECT_SUBCLASS_CARROT
FRUIT/VEGETABLE
SL_OBJECT_SUBCLASS_PERSON_HEAD
PERSON
SL_OBJEC_SUBCLASS_SPORTSBALL
SPORTSBALL >
◆ SL_OBJECT_ACTION_STATE
Enumerator
SL_OBJECT_ACTION_STATE_IDLE
The object is staying static.
SL_OBJECT_ACTION_STATE_MOVING
The object is moving.
◆ SL_DETECTION_MODEL
Enumerator
SL_DETECTION_MODEL_MULTI_CLASS_BOX
Any objects, bounding box based
SL_DETECTION_MODEL_MULTI_CLASS_BOX_ACCURATE
Any objects, bounding box based, more accurate but slower than the base model
SL_DETECTION_MODEL_HUMAN_BODY_FAST
Keypoints based, specific to human skeleton, real time performance even on Jetson or low end GPU cards
SL_DETECTION_MODEL_HUMAN_BODY_ACCURATE
Keypoints based, specific to human skeleton, state of the art accuracy, requires powerful GPU
SL_DETECTION_MODEL_MULTI_CLASS_BOX_MEDIUM
Any objects, bounding box based, compromise between accuracy and speed
SL_DETECTION_MODEL_HUMAN_BODY_MEDIUM
Keypoints based, specific to human skeleton, compromise between accuracy and speed
SL_DETECTION_MODEL_PERSON_HEAD_BOX
Bounding Box detector specialized in person heads, particulary well suited for crowded environement, the person localization is also improved
SL_DETECTION_MODEL_PERSON_HEAD_BOX_ACCURATE
Bounding Box detector specialized in person heads, particulary well suited for crowded environments, the person localization is also improved, state of the art accuracy
SL_DETECTION_MODEL_CUSTOM_BOX_OBJECTS
For external inference, using your own custom model and/or frameworks. This mode disable the internal inference engine, the 2D bounding box detection must be provided
◆ SL_OBJECT_FILTERING_MODE
Enumerator
SL_OBJECT_FILTERING_MODE_NONE
SDK will not apply any preprocessing to the detected objects.
SL_OBJECT_FILTERING_MODE_NMS_3D
SDK will remove objects that are in the same 3D position as an already tracked object (independant of class ID)
SL_OBJECT_FILTERING_MODE_NMS_3D_PER_CLASS
SDK will remove objects that are in the same 3D position as an already tracked object of the same class ID.
◆ SL_BODY_FORMAT
Enumerator
SL_BODY_FORMAT_POSE_18
18 keypoint model of COCO 18.
Note
local keypoint angle and position are not available with this format
SL_BODY_FORMAT_POSE_34
34 keypoint model.
Note
local keypoint angle and position are available
Warning
The SDK will automatically enable fitting.
◆ SL_OBJECT_CLASS
Enumerator
SL_OBJECT_CLASS_PERSON
For people detection
SL_OBJECT_CLASS_VEHICLE
For vehicle detection. It can be cars, trucks, buses, motorcycles etc
SL_OBJECT_CLASS_BAG
For bag detection (backpack, handbag, suitcase)
SL_OBJECT_CLASS_ANIMAL
For animal detection (cow, sheep, horse, dog, cat, bird, etc)
SL_OBJECT_CLASS_ELECTRONICS
For electronic device detection (cellphone, laptop, etc)
SL_OBJECT_CLASS_FRUIT_VEGETABLE
For fruit and vegetable detection (banana, apple, orange, carrot, etc)
SL_OBJECT_CLASS_SPORT
For sport related objects (sports ball etc)
