SL_CameraConfiguration Struct Reference
Structure containing information about the camera sensor. More...
Data Fields
struct SL_CalibrationParameters calibration_parameters
struct SL_CalibrationParameters calibration_parameters_raw
unsigned int firmware_version
float fps
struct SL_Resolution resolution
Note
This object is meant to be used as a read-only container, editing any of its field won't impact the SDK.
Warning
CalibrationParameters are returned in SL_COORDINATE_SYSTEM_IMAGE, they are not impacted by the InitParameters::coordinate_system
Field Documentation
◆ calibration_parameters
struct SL_CalibrationParameters SL_CameraConfiguration::calibration_parameters
< Intrinsic and Extrinsic stereo parameters for rectified/undistorded images (default).
Intrinsic and Extrinsic stereo parameters for original images (unrectified/distorded).
◆ calibration_parameters_raw
struct SL_CalibrationParameters SL_CameraConfiguration::calibration_parameters_raw
The internal firmware version of the camera.
◆ firmware_version
unsigned int SL_CameraConfiguration::firmware_version
The camera capture FPS
◆ fps
float SL_CameraConfiguration::fps
The camera resolution
