SL_SensorsConfiguration Struct Reference
Data Fields
unsigned int firmware_version
struct SL_Vector4 camera_ium_rotation
struct SL_Vector3 camera_imu_translation
struct SL_Vector4 ium_magnetometer_rotation
struct SL_Vector3 ium_magnetometer_translation
struct SL_SensorParameters accelerometer_parameters
struct SL_SensorParameters gyroscope_parameters
struct SL_SensorParameters magnetometer_parameters
struct SL_SensorParameters barometer_parameters
Structure containing information about all the sensors available in the current device.
Field Documentation
◆ firmware_version
unsigned int SL_SensorsConfiguration::firmware_version
The firmware version of the sensor module, 0 if no sensors are available (ZED camera model).
◆ camera_ium_rotation
struct SL_Vector4 SL_SensorsConfiguration::camera_ium_rotation
IMU to Left camera rotation (quaternion).
◆ camera_imu_translation
struct SL_Vector3 SL_SensorsConfiguration::camera_imu_translation
IMU to Left camera translation (SL_float3).
◆ ium_magnetometer_rotation
struct SL_Vector4 SL_SensorsConfiguration::ium_magnetometer_rotation
Magnetometer to IMU rotation. That contains rotation between IMU frame and magnetometer frame.
◆ ium_magnetometer_translation
struct SL_Vector3 SL_SensorsConfiguration::ium_magnetometer_translation
Magnetometer to IMU translation. That contains translation between IMU frame and magnetometer frame.
◆ accelerometer_parameters
struct SL_SensorParameters SL_SensorsConfiguration::accelerometer_parameters
Configuration of the accelerometer device
◆ gyroscope_parameters
struct SL_SensorParameters SL_SensorsConfiguration::gyroscope_parameters
Configuration of the gyroscope device
◆ magnetometer_parameters
struct SL_SensorParameters SL_SensorsConfiguration::magnetometer_parameters
Configuration of the magnetometer device
◆ barometer_parameters
struct SL_SensorParameters SL_SensorsConfiguration::barometer_parameters
Configuration of the barometer device
