zed_interface.h File Reference
Go to the source code of this file.
INTERFACE_API void sl_unload_all_instances ()
 Forces unload of all instances.
INTERFACE_API void sl_unload_instance (int camera_id)
 Forces unload of one instance. More...
INTERFACE_API bool sl_find_usb_device (enum USB_DEVICE device)
 Checks usb devices connected. param device : type of device to find. More...
INTERFACE_API bool sl_create_camera (int camera_id)
 Creates a camera with resolution mode, fps and id for linux. More...
INTERFACE_API bool sl_is_opened (int camera_id)
 Reports if the camera has been successfully opened. More...
INTERFACE_API int sl_open_camera (int camera_id, struct SL_InitParameters *init_parameters, const char *path_svo, const char *ip, int stream_port, const char *output_file, const char *opt_settings_path, const char *opencv_calib_path)
 Opens the camera depending on the init parameters. More...
INTERFACE_API CUcontext sl_get_cuda_context (int camera_id)
 Gets the Camera-created CUDA context for sharing it with other CUDA-capable libraries. More...
INTERFACE_API struct SL_InitParameterssl_get_init_parameters (int camera_id)
 Returns the initparameters used to open the ZED camera. More...
INTERFACE_API struct SL_RuntimeParameterssl_get_runtime_parameters (int camera_id)
 Returns the Runtimeparameters used to open the ZED camera. More...
INTERFACE_API struct SL_PositionalTrackingParameterssl_get_positional_tracking_parameters (int camera_id)
 Returns the PositionalTrackingParameters. More...
INTERFACE_API void sl_close_camera (int camera_id)
 Destroys the camera and disable the textures. More...
INTERFACE_API int sl_set_region_of_interest (int camera_id, void *roi_mask)
 Defines a region of interest to focus on for all the SDK, discarding other parts. More...
INTERFACE_API int sl_grab (int camera_id, struct SL_RuntimeParameters *runtime)
 Grabs the lastest images from the camera. More...
INTERFACE_API void sl_get_device_list (struct SL_DeviceProperties device_list[MAX_CAMERA_PLUGIN], int *nb_devices)
 Lists all the connected devices with their associated information. More...
INTERFACE_API void sl_get_streaming_device_list (struct SL_StreamingProperties streaming_device_list[MAX_CAMERA_PLUGIN], int *nb_devices)
 List all the streaming devices with their associated information. More...
INTERFACE_API int sl_reboot (int sn, bool full_reboot)
 Performs an hardware reset of the ZED 2 / ZED 2i. More...
INTERFACE_API int sl_enable_recording (int camera_id, const char *filename, enum SL_SVO_COMPRESSION_MODE compression_mode, unsigned int bitrate, int target_fps, bool transcode)
 Creates a file for recording the ZED's output into a .SVO or .AVI video. An SVO is Stereolabs' own format designed for the ZED. It holds the video feed with timestamps as well as info about the camera used to record it. More...
INTERFACE_API struct SL_RecordingStatussl_get_recording_status (int camera_id)
 Get the recording information. More...
INTERFACE_API void sl_disable_recording (int camera_id)
 Disables the recording initiated by enableRecording() and closes the generated file. More...
INTERFACE_API struct SL_RecordingParameterssl_get_recording_parameters (int camera_id)
 Returns the recording parameters used. Correspond to the structure send when the sl_enable_recording() function was called. More...
INTERFACE_API void sl_pause_recording (int camera_id, bool status)
 Pauses or resumes the recording. More...
INTERFACE_API int sl_enable_positional_tracking (int camera_id, struct SL_PositionalTrackingParameters *tracking_param, const char *area_file_path)
 Initializes and starts the positional tracking processes. This function allows you to enable the position estimation of the SDK. It only has to be called once in the camera's lifetime. More...
INTERFACE_API void sl_disable_positional_tracking (int camera_id, const char *area_file_path)
INTERFACE_API int sl_save_area_map (int camera_id, const char *area_file_path)
 Saves the current area learning file. The file will contain spatial memory data generated by the tracking. More...
INTERFACE_API int sl_get_area_export_state (int camera_id)
 Returns the state of the spatial memory export process. More...
INTERFACE_API void sl_set_svo_position (int camera_id, int frame_number)
 Sets the playback cursor to the desired frame number in the SVO file. This function allows you to move around within a played-back SVO file. After calling, the next call to grab() will read the provided frame number. More...
INTERFACE_API float sl_get_camera_fps (int camera_id)
 Returns the camera FPS. More...
INTERFACE_API float sl_get_current_fps (int camera_id)
 Returns the current FPS. More...
int INTERFACE_API sl_get_width (int camera_id)
 Returns the width of the current image. More...
int INTERFACE_API sl_get_height (int camera_id)
 Returns the height of the current image. More...
INTERFACE_API int sl_get_confidence_threshold (int camera_id)
 Gets the current confidence threshold value for the disparity map (and by extension the depth map). More...
INTERFACE_API struct SL_CameraInformationsl_get_camera_information (int camera_id, int res_width, int res_height)
 Returns the calibration parameters, serial number and other information about the camera being used. More...
INTERFACE_API void sl_update_self_calibration (int camera_id)
 Performs a new self calibration process. In some cases, due to temperature changes or strong vibrations, the stereo calibration becomes less accurate. Use this function to update the self-calibration data and get more reliable depth values. More...
INTERFACE_API struct SL_CalibrationParameterssl_get_calibration_parameters (int camera_id, bool raw_params)
 Gets the Calibration Parameters. More...
INTERFACE_API struct SL_SensorsConfigurationsl_get_sensors_configuration (int camera_id)
 Gets the Sensors configuration. More...
INTERFACE_API void sl_get_camera_imu_transform (int camera_id, struct SL_Vector3 *translation, struct SL_Quaternion *rotation)
 Gets the IMU to Left camera transform matrix. More...
INTERFACE_API int sl_get_input_type (int camera_id)
 Gets the input type (see SL_INPUT_TYPE). More...
INTERFACE_API int sl_get_zed_serial (int camera_id)
 Gets the ZED Serial Number. More...
INTERFACE_API int sl_get_camera_firmware (int camera_id)
 Gets the ZED camera Current Firmware version. More...
INTERFACE_API int sl_get_sensors_firmware (int camera_id)
 Gets the ZED mcu Current Firmware version. More...
INTERFACE_API int sl_get_camera_model (int camera_id)
 Gets the ZED Camera model (see SL_MODEL). More...
INTERFACE_API unsigned long long sl_get_image_timestamp (int camera_id)
 Get the Timestamp at the time the frame has been extracted from USB stream. (should be called after a grab). More...
INTERFACE_API unsigned long long sl_get_current_timestamp (int camera_id)
 Get the current Timestamp at the time the function is called. Can be compared to the camera Timestamp for synchronization. More...
INTERFACE_API int sl_get_svo_number_of_frames (int camera_id)
 Gets the total number of frames in the loaded SVO file. More...
INTERFACE_API void sl_set_camera_settings (int camera_id, enum SL_VIDEO_SETTINGS mode, int value)
 Sets a value in the ZED's camera settings. More...
INTERFACE_API int sl_set_roi_for_aec_agc (int camera_id, enum SL_SIDE side, struct SL_Rect *roi, bool reset)
 Sets the region of interest for automatic exposure/gain computation. More...
INTERFACE_API int sl_get_camera_settings (int camera_id, enum SL_VIDEO_SETTINGS mode)
 Gets the value of a given setting from the ZED camera. More...
INTERFACE_API int sl_get_roi_for_aec_agc (int id, enum SL_SIDE side, struct SL_Rect *roi)
 Gets the region of interest for automatic exposure/gain computation. More...
INTERFACE_API float sl_get_depth_min_range_value (int camera_id)
 Gets the depth min value from InitParameters (see SL_InitParameters::depth_minimum_distance). More...
INTERFACE_API float sl_get_depth_max_range_value (int camera_id)
 Gets the depth max value from InitParameters (see SL_InitParameters::depth_maximum_distance). More...
INTERFACE_API int sl_get_current_min_max_depth (int camera_id, float *min, float *max)
 Gets the current range of perceived depth. More...
INTERFACE_API int sl_get_number_zed_connected ()
 Gets the number of zed connected. More...
INTERFACE_API char * sl_get_sdk_version ()
 Returns the version of the currently installed ZED SDK. More...
INTERFACE_API int sl_convert_coordinate_system (struct SL_Quaternion *rotation, struct SL_Vector3 *translation, enum SL_COORDINATE_SYSTEM coord_system_src, enum SL_COORDINATE_SYSTEM coord_system_dest)
 Change the coordinate system of a transform matrix. More...
INTERFACE_API int sl_get_svo_position (int camera_id)
INTERFACE_API unsigned int sl_get_frame_dropped_count (int camera_id)
 Gets the number of frames dropped since Grab() was called for the first time. Based on camera timestamps and an FPS comparison. More...
INTERFACE_API bool sl_is_positional_tracking_enabled (int camera_id)
 Gets the current position of the camera and state of the tracking, with an optional offset to the tracking frame. More...
INTERFACE_API int sl_get_position_at_target_frame (int camera_id, struct SL_Quaternion *rotation, struct SL_Vector3 *position, struct SL_Quaternion *target_quaternion, struct SL_Vector3 *target_translation, enum SL_REFERENCE_FRAME reference_frame)
INTERFACE_API int sl_get_position_data (int camera_id, struct SL_PoseData *poseData, enum SL_REFERENCE_FRAME reference_frame)
 Gets the current position of the camera and state of the tracking, filling a PoseData struck useful for AR pass-though. More...
INTERFACE_API int sl_get_position (int camera_id, struct SL_Quaternion *rotation, struct SL_Vector3 *position, enum SL_REFERENCE_FRAME reference_frame)
 Retrieves the estimated position and orientation of the camera in the specified reference frame. More...
INTERFACE_API int sl_get_position_array (int camera_id, float *pose, enum SL_REFERENCE_FRAME reference_frame)
 Gets the position of the camera and the current state of the ZED Tracking as a float array (4x4). More...
INTERFACE_API int sl_reset_positional_tracking (int camera_id, struct SL_Quaternion rotation, struct SL_Vector3 translation)
 Resets the tracking, and re-initializes the position with the given pose. More...
INTERFACE_API int sl_reset_positional_tracking_with_offset (int camera_id, struct SL_Quaternion rotation, struct SL_Vector3 translation, struct SL_Quaternion target_quaternion, struct SL_Vector3 target_translation)
 Resets the tracking with an offset. More...
INTERFACE_API int sl_set_imu_prior_orientation (int camera_id, struct SL_Quaternion rotation)
 Sets a prior to the IMU orientation (using a ZED-mini, ZED2 or ZED2i). Prior must come from a external IMU, such as the HMD orientation and should be in a time frame that's as close as possible to the camera. More...
INTERFACE_API int sl_get_imu_orientation (int camera_id, struct SL_Quaternion *quat, enum SL_TIME_REFERENCE time_reference)
 Gets the rotation given by the ZED-M/ZED2 IMU. Returns an error if using ZED (v1) which does not contains internal sensors. More...
INTERFACE_API int sl_get_sensors_data (int camera_id, struct SL_SensorData *data, enum SL_TIME_REFERENCE time_reference)
 Gets the full Sensor data from the ZED-M/ZED2/ZED2i. Returns an error is using ZED (v1) which does not contains internal sensors. More...
INTERFACE_API void sl_spatial_mapping_merge_chunks (int camera_id, int nb_faces, int *nb_vertices, int *nb_triangles, int *nb_updated_submeshes, int *updated_indices, int *nb_vertices_tot, int *nb_triangles_tot, const int max_submesh)
 Consolidates the chucks from a scan. This is used to turn a lots of small meshes (which are efficient for the scanning process) into several large meshes (which are more convenient to work with). More...
INTERFACE_API int sl_enable_spatial_mapping (int camera_id, struct SL_SpatialMappingParameters *mapping_param)
 Initializes and begins the spatial mapping processes. More...
INTERFACE_API void sl_disable_spatial_mapping (int camera_id)
 Disables the Spatial Mapping process. More...
INTERFACE_API struct SL_SpatialMappingParameterssl_get_spatial_mapping_parameters (int camera_id)
 Returns the spatial mapping parameters used. Correspond to the structure send when the enableSpatialMapping() function was called. More...
INTERFACE_API void sl_pause_spatial_mapping (int camera_id, bool status)
INTERFACE_API void sl_request_mesh_async (int camera_id)
 Starts the mesh generation process in a thread that doesn't block the spatial mapping process. More...
INTERFACE_API int sl_get_mesh_request_status_async (int camera_id)
 Returns the mesh generation status. Useful for knowing when to update and retrieve the mesh. More...
INTERFACE_API enum SL_SPATIAL_MAPPING_STATE sl_get_spatial_mapping_state (int camera_id)
 Gets the current state of spatial mapping. More...
INTERFACE_API int sl_update_mesh (int camera_id, int *nb_vertices_per_submesh, int *nb_triangles_per_submesh, int *nb_submeshes, int *updated_indices, int *nb_vertices_tot, int *nb_triangles_tot, const int max_submesh)
 Updates the internal version of the mesh and returns the sizes of the meshes. More...
INTERFACE_API int sl_retrieve_mesh (int camera_id, float *vertices, int *triangles, float *uvs, unsigned char *texture_ptr, const int max_submeshes)
 Retrieves all chunks of the current mesh. Call update_mesh before calling this. Vertex and triangles arrays must be at least of the sizes returned by update_mesh (nb_vertices and nb_triangles). More...
INTERFACE_API int sl_update_chunks (int camera_id, int *nb_vertices_per_submesh, int *nb_triangles_per_submesh, int *nb_submeshes, int *updated_indices, int *nb_vertices_tot, int *nb_triangles_tot, const int max_submesh)
INTERFACE_API int sl_retrieve_chunks (int camera_id, float *vertices, int *triangles, float *uvs, unsigned char *texture_ptr, const int max_submesh)
 Retrieves all chunks of the full mesh. Call update_mesh before calling this. Vertex and triangles arrays must be at least of the sizes returned by update_mesh (nbVertices and nbTriangles). More...
INTERFACE_API int sl_update_fused_point_cloud (int camera_id, int *nb_vertices_tot)
 Updates the fused point cloud (if spatial map type was FUSED_POINT_CLOUD). More...
INTERFACE_API int sl_retrieve_fused_point_cloud (int camera_id, float *vertices)
 Retrieves all points of the fused point cloud. Call update_fused_point_cloud before calling this. More...
INTERFACE_API int sl_extract_whole_spatial_map (int camera_id)
 Extracts the current spatial map from the spatial mapping process. More...
INTERFACE_API bool sl_save_mesh (int camera_id, const char *filename, enum SL_MESH_FILE_FORMAT format)
 Saves the scanned mesh in a specific file format. More...
INTERFACE_API bool sl_save_point_cloud (int c_id, const char *filename, enum SL_MESH_FILE_FORMAT format)
 Saves the scanned point cloud in a specific file format. More...
INTERFACE_API bool sl_load_mesh (int camera_id, const char *filename, int *nb_vertices_per_submesh, int *nb_triangles_per_submesh, int *num_submeshes, int *updated_indices, int *nb_vertices_tot, int *nb_triangles_tot, int *textures_size, const int max_submesh)
 Loads a saved mesh file. More...
INTERFACE_API bool sl_apply_texture (int camera_id, int *nb_vertices_per_submesh, int *nb_triangles_per_submesh, int *nb_updated_submeshes, int *updated_indices, int *nb_vertices_tot, int *nb_triangles_tot, int *textures_size, const int max_submesh)
 Applies the scanned texture onto the internal scanned mesh. More...
INTERFACE_API bool sl_filter_mesh (int camera_id, enum SL_MESH_FILTER filter_params, int *nb_vertices_per_submesh, int *nb_triangles_per_submesh, int *nb_updated_submeshes, int *updated_indices, int *nb_vertices_tot, int *nb_triangles_tot, const int max_submesh)
 Filters a mesh to removes triangles while still preserving its overall shaper (though less accurate). More...
INTERFACE_API void sl_spatial_mapping_get_gravity_estimation (int camera_id, struct SL_Vector3 *gravity)
 Gets a vector pointing toward the direction of gravity. This is estimated from a 3D scan of the environment, and such, a scan must be started and finished for this value to be calculated. If using the ZED_M /ZED2, this isn't required thanks to its IMU. More...
INTERFACE_API int sl_update_whole_mesh (int camera_id, int *nb_vertices, int *nb_triangles)
 Updates the internal version of the whole mesh and returns the size of its data. More...
INTERFACE_API int sl_retrieve_whole_mesh (int camera_id, float *vertices, int *triangles, float *uvs, unsigned char *texture_ptr)
 Retrieves the full mesh. Call update_mesh before calling this. Vertex and triangles arrays must be at least of the sizes returned by update_mesh (nb_vertices and nbTriangles). More...
INTERFACE_API bool sl_load_whole_mesh (int camera_id, const char *filename, int *nb_vertices, int *nb_triangles, int *texture_size)
INTERFACE_API bool sl_apply_whole_texture (int camera_id, int *nb_vertices, int *nb_triangles, int *texture_size)
INTERFACE_API bool sl_filter_whole_mesh (int camera_id, enum SL_MESH_FILTER filter_params, int *nb_vertices, int *nb_triangles)
INTERFACE_API struct SL_PlaneDatasl_find_floor_plane (int camera_id, struct SL_Quaternion *reset_quaternion, struct SL_Vector3 *reset_translation, struct SL_Quaternion prior_rotation, struct SL_Vector3 prior_translation)
 Looks for a plane in the visible area that is likely to represent the floor. More...
INTERFACE_API struct SL_PlaneDatasl_find_plane_at_hit (int camera_id, struct SL_Vector2 pixel, bool thres)
 Check for a plane in hte real world at given screen-space coordinates. More...
INTERFACE_API int sl_convert_floorplane_to_mesh (int camera_id, float *vertices, int *triangles, int *nb_vertices_tot, int *nb_triangles_tot)
 Using data from a detected floor plane, updates supplied vertex and triangles arrays with data needed to make a mesh that represents it. More...
INTERFACE_API int sl_convert_hitplane_to_mesh (int camera_id, float *vertices, int *triangles, int *nb_vertices_tot, int *nb_triangles_tot)
 Using data from a detected hit plane, updates supplied vertex and triangles arrays with data needed to make a mesh that represents it. More...
INTERFACE_API int sl_retrieve_measure (int camera_id, void *measure_ptr, enum SL_MEASURE type, enum SL_MEM mem, int width, int height)
 Retrieves a measure texture from the ZED SDK. Use this to get an individual texture from the last grabbed frame with measurements in every pixel - such as depth map, confidence map etc. Measure textures are not human-viewable but don't lose accuracy, unlike image textures. More...
INTERFACE_API int sl_retrieve_image (int camera_id, void *image_ptr, enum SL_VIEW type, enum SL_MEM mem, int width, int height)
 Retrieves an image texture from the ZED SDK in a human-viewable format. Image textures work for when you want the result to be visible, such as the direct RGB image from the camera, or a greyscale image of the depth. However it will lose accuracy if used to show measurements like depth or confidence, unlike measure textures. More...
INTERFACE_API int sl_convert_image (void *image_in_ptr, void *image_signed_ptr, cudaStream_t stream)
 Convert Image format from Unsigned char to Signed char, designed for Unreal Engine pipeline, works on GPU memory. More...
INTERFACE_API int sl_enable_streaming (int camera_id, enum SL_STREAMING_CODEC codec, unsigned int bitrate, unsigned short port, int gop_size, int adaptative_bitrate, int chunk_size, int target_framerate)
 Creates a streaming pipeline. More...
INTERFACE_API void sl_disable_streaming (int camera_id)
 Disables the streaming initiated by enable_streaming(). More...
INTERFACE_API int sl_is_streaming_enabled (int camera_id)
 Tells if the streaming is running (true) or still initializing (false). More...
INTERFACE_API struct SL_StreamingParameterssl_get_streaming_parameters (int camera_id)
 Returns the streaming parameters used. Correspond to the structure send when the sl_enable_streaming() function was called. More...
INTERFACE_API int sl_save_current_image (int camera_id, enum SL_VIEW view, const char *file_name)
 Writes the image into a file defined by its extension. More...
INTERFACE_API int sl_save_current_depth (int camera_id, enum SL_SIDE side, const char *file_name)
 Writes the depth map into a file defined by its extension. More...
INTERFACE_API int sl_save_current_point_cloud (int camera_id, enum SL_SIDE side, const char *file_name)
 Writes the point cloud into a file defined by its extension. More...
INTERFACE_API struct SL_AI_Model_statussl_check_AI_model_status (enum SL_AI_MODELS model, int gpu_id)
 Check if a corresponding optimized engine is found for the requested Model based on your rig configuration. More...
INTERFACE_API int sl_optimize_AI_model (enum SL_AI_MODELS model, int gpu_id)
 Optimize the requested model, possible download if the model is not present on the host. More...
INTERFACE_API int sl_enable_objects_detection (int camera_id, struct SL_ObjectDetectionParameters *object_detection_parameters)
 Initializes and starts the Deep Learning detection module.
The object detection module currently supports two types of detection : More...
INTERFACE_API struct SL_ObjectDetectionParameterssl_get_object_detection_parameters (int cmaera_id)
 Returns the object detection parameters used. Correspond to the structure send when the enableObjectDetection() function was called. More...
INTERFACE_API void sl_pause_objects_detection (int camera_id, bool status)
 Pauses or resumes the object detection processes. More...
INTERFACE_API void sl_disable_objects_detection (int camera_id)
 Disables the Object Detection process. More...
INTERFACE_API int sl_generate_unique_id (char *uuid)
 Generate a UUID like unique ID to help identify and track AI detections. More...
INTERFACE_API int sl_ingest_custom_box_objects (int camera_id, int nb_objects, struct SL_CustomBoxObjectData *objects_in)
 Feed the 3D Object tracking function with your own 2D bounding boxes from your own detection algorithm. More...
INTERFACE_API int sl_retrieve_objects (int camera_id, struct SL_ObjectDetectionRuntimeParameters *object_detection_runtime_parameters, struct SL_Objects *objects)
 Retrieve objects detected by the object detection module. More...
INTERFACE_API int sl_update_objects_batch (int camera_id, int *nb_batches)
 Updates the internal batch of detected objects. More...
INTERFACE_API int sl_get_objects_batch (int camera_id, int index, struct SL_ObjectsBatch *objs_batch)
 Gets a batch of detected objects. Need to be called after update_objects_batch(). More...
INTERFACE_API int sl_get_objects_batch_csharp (int camera_id, int index, int *nb_data, int *id, int *label, int *sublabel, int *tracking_state, struct SL_Vector3 positions[MAX_TRAJECTORY_SIZE], float position_covariances[MAX_TRAJECTORY_SIZE][6], struct SL_Vector3 velocities[MAX_TRAJECTORY_SIZE], unsigned long long timestamps[MAX_TRAJECTORY_SIZE], struct SL_Vector2 bounding_boxes_2d[MAX_TRAJECTORY_SIZE][4], struct SL_Vector3 bounding_boxes[MAX_TRAJECTORY_SIZE][8], float confidences[MAX_TRAJECTORY_SIZE], int action_states[MAX_TRAJECTORY_SIZE], struct SL_Vector2 keypoints_2d[MAX_TRAJECTORY_SIZE][18], struct SL_Vector3 keypoints[MAX_TRAJECTORY_SIZE][18], struct SL_Vector2 head_bounding_boxes_2d[MAX_TRAJECTORY_SIZE][4], struct SL_Vector3 head_bounding_boxes[MAX_TRAJECTORY_SIZE][8], struct SL_Vector3 head_positions[MAX_TRAJECTORY_SIZE], float keypoints_confidences[MAX_TRAJECTORY_SIZE][18])
INTERFACE_API void * sl_mat_create_new (int width, int height, enum SL_MAT_TYPE type, enum SL_MEM mem)
 Creates a Mat with the given resolution. More...
INTERFACE_API void * sl_mat_create_new_empty ()
 Creates an empty Mat with the given resolution. More...
INTERFACE_API bool sl_mat_is_init (void *ptr)
 Tells if the Mat has been initialized. More...
INTERFACE_API void sl_mat_free (void *ptr, enum SL_MEM mem)
 Frees the memory of the Mat. More...
INTERFACE_API void sl_mat_get_infos (void *ptr, char *buffer)
 Returns information about the Mat. More...
INTERFACE_API int sl_mat_get_value_uchar (void *ptr, int col, int row, unsigned char *value, enum SL_MEM mem)
 Returns the value of a specific point in the matrix. More...
INTERFACE_API int sl_mat_get_value_uchar2 (void *ptr, int col, int row, struct SL_Uchar2 *value, enum SL_MEM mem)
INTERFACE_API int sl_mat_get_value_uchar3 (void *ptr, int col, int row, struct SL_Uchar3 *value, enum SL_MEM mem)
INTERFACE_API int sl_mat_get_value_uchar4 (void *ptr, int col, int row, struct SL_Uchar4 *value, enum SL_MEM mem)
INTERFACE_API int sl_mat_get_value_float (void *ptr, int col, int row, float *value, enum SL_MEM mem)
INTERFACE_API int sl_mat_get_value_float2 (void *ptr, int col, int row, struct SL_Vector2 *value, enum SL_MEM mem)
INTERFACE_API int sl_mat_get_value_float3 (void *ptr, int col, int row, struct SL_Vector3 *value, enum SL_MEM mem)
INTERFACE_API int sl_mat_get_value_float4 (void *ptr, int col, int row, struct SL_Vector4 *value, enum SL_MEM mem)
INTERFACE_API int sl_mat_set_value_uchar (void *ptr, int col, int row, unsigned char value, enum SL_MEM mem)
 Sets a value to a specific point in the matrix. More...
INTERFACE_API int sl_mat_set_value_uchar2 (void *ptr, int col, int row, struct SL_Uchar2 value, enum SL_MEM mem)
INTERFACE_API int sl_mat_set_value_uchar3 (void *ptr, int col, int row, struct SL_Uchar3 value, enum SL_MEM mem)
INTERFACE_API int sl_mat_set_value_uchar4 (void *ptr, int col, int row, struct SL_Uchar4 value, enum SL_MEM mem)
INTERFACE_API int sl_mat_set_value_float (void *ptr, int col, int row, float value, enum SL_MEM mem)
INTERFACE_API int sl_mat_set_value_float2 (void *ptr, int col, int row, struct SL_Vector2 value, enum SL_MEM mem)
INTERFACE_API int sl_mat_set_value_float3 (void *ptr, int col, int row, struct SL_Vector3 value, enum SL_MEM mem)
INTERFACE_API int sl_mat_set_value_float4 (void *ptr, int col, int row, struct SL_Vector4 value, enum SL_MEM mem)
INTERFACE_API int sl_mat_set_to_uchar (void *ptr, unsigned char value, enum SL_MEM mem)
 Fills the entire Mat with the given value. More...
INTERFACE_API int sl_mat_set_to_uchar2 (void *ptr, struct SL_Uchar2 value, enum SL_MEM mem)
INTERFACE_API int sl_mat_set_to_uchar3 (void *ptr, struct SL_Uchar3 value, enum SL_MEM mem)
INTERFACE_API int sl_mat_set_to_uchar4 (void *ptr, struct SL_Uchar4 value, enum SL_MEM mem)
INTERFACE_API int sl_mat_set_to_float (void *ptr, float value, enum SL_MEM mem)
INTERFACE_API int sl_mat_set_to_float2 (void *ptr, struct SL_Vector2 value, enum SL_MEM mem)
INTERFACE_API int sl_mat_set_to_float3 (void *ptr, struct SL_Vector3 value, enum SL_MEM mem)
INTERFACE_API int sl_mat_set_to_float4 (void *ptr, struct SL_Vector4 value, enum SL_MEM mem)
INTERFACE_API int sl_mat_update_cpu_from_gpu (void *ptr)
 Copies data from the GPU to the CPU, if possible. More...
INTERFACE_API int sl_mat_update_gpu_from_cpu (void *ptr)
 Copies data from the CPU to the GPU, if possible. More...
INTERFACE_API int sl_mat_copy_to (void *ptr, void *ptr_dest, enum SL_COPY_TYPE cpy_type)
 Copies data from this Mat to another Mat (deep copy). More...
INTERFACE_API int sl_mat_read (void *ptr, const char *file_path)
 Reads an image from a file. Supports .png and .jpeg. Only works if Mat has access to MEM_CPU. More...
INTERFACE_API int sl_mat_write (void *ptr, const char *file_path)
 Writes the Mat into a file as an image. Only works if Mat has access to MEM_CPU. More...
INTERFACE_API int sl_mat_get_width (void *ptr)
 Gets the Width of the matrix. More...
INTERFACE_API int sl_mat_get_height (void *ptr)
 Gets the Height of the matrix. More...
INTERFACE_API int sl_mat_get_channels (void *ptr)
 Gets the number of channels stored in each pixel. More...
INTERFACE_API int sl_mat_get_memory_type (void *ptr)
 Gets the type of memory (CPU and/or GPU). More...
INTERFACE_API int sl_mat_get_data_type (void *ptr)
 Gets the type of data (Mat_Type). More...
INTERFACE_API int sl_mat_get_pixel_bytes (void *ptr)
 Gets the size in bytes of one pixel. More...
INTERFACE_API int sl_mat_get_step (void *ptr, enum SL_MEM mem)
 Gets the memory 'step' in number/length of elements - how many values make up each row of pixels. More...
INTERFACE_API int sl_mat_get_step_bytes (void *ptr, enum SL_MEM mem)
 Gets the memory 'step' in bytes - how many bytes make up each row of pixels. More...
INTERFACE_API int sl_mat_get_width_bytes (void *ptr)
 Gets the size of each row in bytes. More...
INTERFACE_API bool sl_mat_is_memory_owner (void *ptr)
 Returns whether the Mat is the owner of the memory it's accessing. More...
INTERFACE_API struct SL_Resolution sl_mat_get_resolution (void *ptr)
 Returns the resolution of the image that this Mat holds. More...
INTERFACE_API void sl_mat_alloc (void *ptr, int width, int height, enum SL_MAT_TYPE type, enum SL_MEM mem)
 Allocates memory for the Mat. More...
INTERFACE_API int sl_mat_set_from (void *ptr, void *ptr_source, enum SL_COPY_TYPE copy_type)
 Copies data from another Mat into this one(deep copy). More...
INTERFACE_API int * sl_mat_get_ptr (void *ptr, enum SL_MEM mem)
 Gets a pointer to the Mat. More...
INTERFACE_API int sl_mat_clone (void *ptr, void *ptr_source)
 Duplicates a Mat by copying all its data into a new one (deep copy). More...
INTERFACE_API void sl_mat_swap (void *ptr_1, void *ptr_2)
 Swaps the content of the provided Mat (only swaps the pointers, no data copy). More...
Function Documentation
◆ sl_unload_instance()
INTERFACE_API void sl_unload_instance ( int  camera_id)
Parameters
camera_id: id of the instance to unload.
◆ sl_find_usb_device()
INTERFACE_API bool sl_find_usb_device ( enum USB_DEVICE  device)
Returns
true if connected.
◆ sl_create_camera()
INTERFACE_API bool sl_create_camera ( int  camera_id)
Parameters
camera_id: id of the camera to be added.
verbose: Enable verbose mode.
Returns
true if the camera has been created successfully.
◆ sl_is_opened()
INTERFACE_API bool sl_is_opened ( int  camera_id)
Parameters
camera_id: id of the camera.
Returns
true if the ZED is already setup, otherwise false.
◆ sl_open_camera()
INTERFACE_API int sl_open_camera ( int  camera_id,
struct SL_InitParameters init_parameters,
const char *  path_svo,
const char *  ip,
int  stream_port,
const char *  output_file,
const char *  opt_settings_path,
const char *  opencv_calib_path
Parameters
init_parameters: structure containing all the initial parameters.
path_svo: filename of the svo (for SVO input).
ip: ip of the camera to open (for Stream input).
stream_port: port of the camera to open (for Stream input).
output_file: sdk verbose log file. Redirect the SDK verbose message to file.
opt_settings_path: optional settings path. Equivalent to InitParameters::optional_settings_path.
opencv_calib_path: optional openCV calibration file. Equivalent to InitParameters::optional_opencv_calibration_file.
Returns
An error code giving information about the internal process. If SUCCESS (0) is returned, the camera is ready to use. Every other code indicates an error and the program should be stopped.
◆ sl_get_cuda_context()
INTERFACE_API CUcontext sl_get_cuda_context ( int  camera_id)
Parameters
camera_id: id of the camera instance.
◆ sl_get_init_parameters()
INTERFACE_API struct SL_InitParameters* sl_get_init_parameters ( int  camera_id)
Parameters
◆ sl_get_runtime_parameters()
INTERFACE_API struct SL_RuntimeParameters* sl_get_runtime_parameters ( int  camera_id)
Parameters
Returns
a structure containing all the runtime parameters.
◆ sl_get_positional_tracking_parameters()
INTERFACE_API struct SL_PositionalTrackingParameters* sl_get_positional_tracking_parameters ( int  camera_id)
Parameters
Returns
a structure containing all the positional tracking parameters
◆ sl_close_camera()
INTERFACE_API void sl_close_camera ( int  camera_id)
Parameters
camera_idof the camera instance.
◆ sl_set_region_of_interest()
INTERFACE_API int sl_set_region_of_interest ( int  camera_id,
void *  roi_mask
Parameters
roi_maskthe Mat defining the requested region of interest, all pixel set to 0 will be discard. If empty, set all pixels as valid, otherwise should fit the resolution of the current instance and its type should be U8_C1.
Returns
An ERROR_CODE if something went wrong.
◆ sl_grab()
INTERFACE_API int sl_grab ( int  camera_id,
struct SL_RuntimeParameters runtime
Parameters
runtime: structure containing all the runtime parameters.
Returns
An error code giving information about the internal process."SUCCESS" if the method succeeded.
◆ sl_get_device_list()
INTERFACE_API void sl_get_device_list ( struct SL_DeviceProperties  device_list[MAX_CAMERA_PLUGIN],
int *  nb_devices
This function lists all the cameras available and provides their serial number, models and other information.
Parameters
device_list[Out] : the devices properties for each connected camera.
nb_devices[Out] : the number of cameras connected.
◆ sl_get_streaming_device_list()
INTERFACE_API void sl_get_streaming_device_list ( struct SL_StreamingProperties  streaming_device_list[MAX_CAMERA_PLUGIN],
int *  nb_devices
Parameters
nb_devices[Out]: the number of cameras connected.
Returns
The streaming properties for each connected camera
◆ sl_reboot()
INTERFACE_API int sl_reboot ( int  sn,
bool  full_reboot
Parameters
sn: serial number of the camera to reset, or 0 to reset the first camera detected.
fullReboot: Perform a full reboot (Sensors and Video modules)
◆ sl_enable_recording()
INTERFACE_API int sl_enable_recording ( int  camera_id,
const char *  filename,
int  target_fps,
bool  transcode
Parameters
filename: filename of the SVO file.
compression_mode: compression mode. Can be one for the SL_SVO_COMPRESSION_MODE enum.
bitrate: overrides default bitrate of the SVO file, in KBits/s. Only works if SVO_COMPRESSION_MODE is H264 or H265.
target_fps: defines the target framerate for the recording module.
transcode: in case of streaming input, if set to false, it will avoid decoding/re-encoding and convert directly streaming input to a SVO file. This saves a encoding session and can be especially useful on NVIDIA Geforce cards where the number of encoding session is limited.
Returns
An ERROR_CODE that defines if SVO file was successfully created and can be filled with images.
◆ sl_get_recording_status()
INTERFACE_API struct SL_RecordingStatus* sl_get_recording_status ( int  camera_id)
Returns
The recording state structure. For more details, see RecordingStatus.
◆ sl_disable_recording()
INTERFACE_API void sl_disable_recording ( int  camera_id)
Parameters
◆ sl_get_recording_parameters()
INTERFACE_API struct SL_RecordingParameters* sl_get_recording_parameters ( int  camera_id)
Parameters
Returns
SL_RecordingParameters containing the parameters used for recording initialization.
◆ sl_pause_recording()
INTERFACE_API void sl_pause_recording ( int  camera_id,
bool  status
Parameters
status: if true, the recording is paused. If false, the recording is resumed.
◆ sl_enable_positional_tracking()
INTERFACE_API int sl_enable_positional_tracking ( int  camera_id,
struct SL_PositionalTrackingParameters tracking_param,
const char *  area_file_path
Parameters
area_file_path: area localization file that describes the surroundings, saved from a previous tracking session.
Returns
SL_ERROR_CODE::SUCCESS if everything went fine, ERROR_CODE::FAILURE otherwise.
◆ sl_disable_positional_tracking()
INTERFACE_API void sl_disable_positional_tracking ( int  camera_id,
Parameters
initial_world_rotation: rotation of the camera in the world frame when the camera is started. By default, it should be identity.
initial_world_position: position of the camera in the world frame when the camera is started. By default, it should be identity.
enable_area_memory: this mode enables the camera to remember its surroundings. This helps correct positional tracking drift, and can be helpful for positioning different cameras relative to one other in space.
enable_pose_smoothing: this mode enables smooth pose correction for small drift correction.
set_floor_as_origin: this mode initializes the tracking to be aligned with the floor plane to better position the camera in space.
set_as_static: this mode defines the camera as static. If true, it will not move in the environment. This allows you to set its position using initial_world_transform.
enable_imu_fusion: this mode enables or disables IMU fusion. When set to false, only the optical odometry will be used.
Returns
SL_ERROR_CODE::SUCCESS if everything went fine, ERROR_CODE::FAILURE otherwise. INTERFACE_API int enable_positional_tracking(int camera_id, struct SL_Quaternion initial_world_rotation, struct SL_Vector3 *initial_world_position, bool enable_area_memory, bool enable_pose_smoothing, bool set_floor_as_origin, bool set_as_static, bool enable_imu_fusion, const char area_file_path);
Disables the positional tracking.
Parameters
area_file_path: if set, saves the spatial memory into an '.area' file.
◆ sl_save_area_map()
INTERFACE_API int sl_save_area_map ( int  camera_id,
Parameters
area_file_path: save the spatial memory database in an '.area' file.
Returns
SL_ERROR_CODE::FAILURE if the area_file_path file wasn't found, SUCCESS otherwise.
◆ sl_get_area_export_state()
INTERFACE_API int sl_get_area_export_state ( int  camera_id)
Parameters
Returns
The current state (SL_AREA_EXPORTING_STATE) of the spatial memory export process
◆ sl_set_svo_position()
INTERFACE_API void sl_set_svo_position ( int  camera_id,
int  frame_number
Parameters
frame_number: the number of the desired frame to be decoded.
◆ sl_get_camera_fps()
INTERFACE_API float sl_get_camera_fps ( int  camera_id)
Parameters
Returns
The current frame rate.
◆ sl_get_current_fps()
INTERFACE_API float sl_get_current_fps ( int  camera_id)
Parameters
Returns
◆ sl_get_width()
int INTERFACE_API sl_get_width ( int  camera_id)
Parameters
Returns
Width of the image.
◆ sl_get_height()
int INTERFACE_API sl_get_height ( int  camera_id)
Parameters
Returns
Height of the image.
◆ sl_get_confidence_threshold()
INTERFACE_API int sl_get_confidence_threshold ( int  camera_id)
Parameters
Returns
The confidence threshold.
◆ sl_get_camera_information()
INTERFACE_API struct SL_CameraInformation* sl_get_camera_information ( int  camera_id,
int  res_width,
int  res_height
Parameters
res_width: You can specify a size different from default image size to get the scaled camera information.
res_height: You can specify a size different from default image size to get the scaled camera information.
Returns
SL_CameraInformation containing the calibration parameters of the ZED, as well as serial number and firmware version.
◆ sl_update_self_calibration()
INTERFACE_API void sl_update_self_calibration ( int  camera_id)
Parameters
◆ sl_get_calibration_parameters()
INTERFACE_API struct SL_CalibrationParameters* sl_get_calibration_parameters ( int  camera_id,
bool  raw_params
Parameters
raw_params: if true, returns Intrinsic and Extrinsic stereo parameters for original images (unrectified/distorded), else returns parameters for rectified/undistorded images.
Returns
Structure containing Intrinsic and Extrinsic stereo parameters
◆ sl_get_sensors_configuration()
INTERFACE_API struct SL_SensorsConfiguration* sl_get_sensors_configuration ( int  camera_id)
Parameters
Returns
Structure containing information about all the sensors available in the current device.
◆ sl_get_camera_imu_transform()
INTERFACE_API void sl_get_camera_imu_transform ( int  camera_id,
Parameters
translation: translation between IMU frame and camera frame.
rotation: rotation between IMU frame and camera frame.
◆ sl_get_input_type()
INTERFACE_API int sl_get_input_type ( int  camera_id)
Parameters
Returns
The input type.
◆ sl_get_zed_serial()
INTERFACE_API int sl_get_zed_serial ( int  camera_id)
Parameters
Returns
The serial number of the camera.
◆ sl_get_camera_firmware()
INTERFACE_API int sl_get_camera_firmware ( int  camera_id)
Parameters
Returns
The firmware of the camera.
◆ sl_get_sensors_firmware()
INTERFACE_API int sl_get_sensors_firmware ( int  camera_id)
Parameters
Returns
The firmware version of the sensor module, 0 if no sensors are available.
◆ sl_get_camera_model()
INTERFACE_API int sl_get_camera_model ( int  camera_id)
Parameters
Returns
The ZED Camera model.
◆ sl_get_image_timestamp()
INTERFACE_API unsigned long long sl_get_image_timestamp ( int  camera_id)
Parameters
Returns
The Camera timestamp.
◆ sl_get_current_timestamp()
INTERFACE_API unsigned long long sl_get_current_timestamp ( int  camera_id)
Parameters
Returns
The current timestamp.
◆ sl_get_svo_number_of_frames()
INTERFACE_API int sl_get_svo_number_of_frames ( int  camera_id)
Parameters
Returns
The total number of frames in the SVO file (-1 if the SDK is not reading a SVO).
◆ sl_set_camera_settings()
INTERFACE_API void sl_set_camera_settings ( int  camera_id,
int  value
Parameters
mode: Setting to be changed
value: new value
◆ sl_set_roi_for_aec_agc()
INTERFACE_API int sl_set_roi_for_aec_agc ( int  camera_id,
enum SL_SIDE  side,
struct SL_Rect roi,
bool  reset
Parameters
side: defines left,right,both to distinguish between left and right or both sides (see SL_SIDE).
roi: Region of interest.
reset: reset aestruct C_agc if true.
Returns
SL_ERROR_CODE::SUCCESS if ROI has been applied. Other ERROR_CODE otherwise.
◆ sl_get_camera_settings()
INTERFACE_API int sl_get_camera_settings ( int  camera_id,
Parameters
mode: Setting to be retrieved (see SL_VIDEO_SETTINGS).
Returns
The current value for the corresponding setting. Returns -1 if encounters an error.
◆ sl_get_roi_for_aec_agc()
INTERFACE_API int sl_get_roi_for_aec_agc ( int  id,
enum SL_SIDE  side,
struct SL_Rect roi
Parameters
roi[Out] : Region of interest.
Returns
◆ sl_get_depth_min_range_value()
INTERFACE_API float sl_get_depth_min_range_value ( int  camera_id)
Parameters
Returns
The min depth value available.
◆ sl_get_depth_max_range_value()
INTERFACE_API float sl_get_depth_max_range_value ( int  camera_id)
Parameters
Returns
The max depth value available.
◆ sl_get_current_min_max_depth()
INTERFACE_API int sl_get_current_min_max_depth ( int  camera_id,
float *  min,
float *  max
Parameters
min: [out] Minimum depth detected (in selected sl::UNIT)
max: [out] Maximum depth detected (in selected sl::UNIT)
Returns
SL_ERROR_CODE::SUCCESS if values have been extracted. Other ERROR_CODE otherwise.
◆ sl_get_number_zed_connected()
INTERFACE_API int sl_get_number_zed_connected ( )
Returns
The number of Zed cameras connected.
◆ sl_get_sdk_version()
INTERFACE_API char* sl_get_sdk_version ( )
Returns
The ZED SDK version installed.
◆ sl_convert_coordinate_system()
INTERFACE_API int sl_convert_coordinate_system ( struct SL_Quaternion rotation,
Parameters
rotation[In, Out] : rotation to transform.
translation[In, Out] : translation to transform.
coord_system_src: the current coordinate system of the translation/rotation.
coord_system_destthe destination coordinate system for the translation/rotation.
◆ sl_get_svo_position()
INTERFACE_API int sl_get_svo_position ( int  camera_id)
Parameters
major: major int of the version filled
minor: minor int of the version filled
patch: patch int of the version filled
Gets the current position of the SVO being recorded to.
Parameters
Returns
The current SVO position;
◆ sl_get_frame_dropped_count()
INTERFACE_API unsigned int sl_get_frame_dropped_count ( int  camera_id)
Parameters
Returns
The number of frames dropped since the first Grab() call.
◆ sl_is_positional_tracking_enabled()
INTERFACE_API bool sl_is_positional_tracking_enabled ( int  camera_id)
Parameters
Returns
true if the tracking module is enabled
◆ sl_get_position_at_target_frame()
INTERFACE_API int sl_get_position_at_target_frame ( int  camera_id,
struct SL_Vector3 position,
struct SL_Vector3 target_translation,
Parameters
rotation: Quaternion filled with the current rotation of the camera depending on its reference frame.
position: Vector filled with the current position of the camera depending on its reference frame.
target_quaternion: Rotational offset applied to the tracking frame.
target_translation: Positional offset applied to the tracking frame.
reference_frame: Reference frame for setting the rotation/position.
Returns
The current state of the tracking process (see SL_POSITIONAL_TRACKING_STATE).
◆ sl_get_position_data()
INTERFACE_API int sl_get_position_data ( int  camera_id,
struct SL_PoseData poseData,
Parameters
poseData: Current Pose.
reference_frame: Reference frame sor setting the rotation/position.
Returns
◆ sl_get_position()
INTERFACE_API int sl_get_position ( int  camera_id,
Parameters
Returns
◆ sl_get_position_array()
INTERFACE_API int sl_get_position_array ( int  camera_id,
float *  pose,
Parameters
pose: pose of the camera as a float array (float[16]).
reference_frame: the reference from which you want the pose to be expressed (see SL_REFERENCE_FRAME::WORLD).
Returns
The Positional tracking state.
◆ sl_reset_positional_tracking()
INTERFACE_API int sl_reset_positional_tracking ( int  camera_id,
Parameters
rotation: rotation of the camera in the world frame when the function is called.
translation: position of the camera in the world frame when the function is called.
Returns
SL_ERROR_CODE::SUCCESS if the tracking has been reset, ERROR_CODE::FAILURE otherwise.
◆ sl_reset_positional_tracking_with_offset()
INTERFACE_API int sl_reset_positional_tracking_with_offset ( int  camera_id,
Parameters
target_quaternion: rotation offset to apply.
target_translation: translation offset to apply.
Returns
◆ sl_set_imu_prior_orientation()
INTERFACE_API int sl_set_imu_prior_orientation ( int  camera_id,
Parameters
rotation: Prior rotation. \SUCCESS if the transform has been passed, ERROR_CODE::INVALID_FUNCTION_CALL otherwise
◆ sl_get_imu_orientation()
INTERFACE_API int sl_get_imu_orientation ( int  camera_id,
struct SL_Quaternion quat,
Parameters
quat[Out]: Rotation from the IMU.
time_reference: time reference.
Returns
ERROR_CODE::SUCCESS if sensors data have been extracted.
◆ sl_get_sensors_data()
INTERFACE_API int sl_get_sensors_data ( int  camera_id,
struct SL_SensorData data,
Parameters
data: sensor data.
Returns
◆ sl_spatial_mapping_merge_chunks()
INTERFACE_API void sl_spatial_mapping_merge_chunks ( int  camera_id,
int  nb_faces,
int *  nb_vertices,
int *  nb_triangles,
int *  nb_updated_submeshes,
int *  updated_indices,
int *  nb_vertices_tot,
int *  nb_triangles_tot,
Parameters
nb_faces: define the new number of faces per chunk (useful for Unity that doesn't handle chunks over 65K vertices).
nb_vertices: Array of the number of vertices in each submesh.
nb_triangles: Array of the number of triangles in each submesh.
nb_updated_submeshes: Number of submeshes.
updates_indices: List of all submeshes updated since the last update.
nb_vertices_tot: Total number of updated vertices in all submeshes.
nb_triangles_tot: Total number of updated triangles in all submeshes.
max_sub_mesh: Maximum number of submeshes.
◆ sl_enable_spatial_mapping()
INTERFACE_API int sl_enable_spatial_mapping ( int  camera_id,
struct SL_SpatialMappingParameters mapping_param
Parameters
type: Spatial mapping type (see SL_SPATIAL_MAP_TYPE).
resolution_meter: Spatial mapping resolution in meters.
max_range_meter: Maximum scanning range in meters.
save_texture: True to scan surface textures in addition to geometry.
max_memory_usage: The maximum CPU memory (in megabytes) allocated for the meshing process.
Returns
◆ sl_disable_spatial_mapping()
INTERFACE_API void sl_disable_spatial_mapping ( int  camera_id)
Parameters
◆ sl_get_spatial_mapping_parameters()
INTERFACE_API struct SL_SpatialMappingParameters* sl_get_spatial_mapping_parameters ( int  camera_id)
Parameters
Returns
SpatialMappingParameters containing the parameters used for spatial mapping intialization.
◆ sl_pause_spatial_mapping()
INTERFACE_API void sl_pause_spatial_mapping ( int  camera_id,
bool  status
Sets the pause state of the data integration mechanism for the ZED's spatial mapping.
Parameters
status: If true, the integration is paused. If false, the spatial mapping is resumed.
◆ sl_request_mesh_async()
INTERFACE_API void sl_request_mesh_async ( int  camera_id)
Parameters
◆ sl_get_mesh_request_status_async()
INTERFACE_API int sl_get_mesh_request_status_async ( int  camera_id)
Parameters
Returns
SUCCESS if the mesh is ready and not yet retrieved, otherwise ERROR_CODE::FAILURE.
◆ sl_get_spatial_mapping_state()
INTERFACE_API enum SL_SPATIAL_MAPPING_STATE sl_get_spatial_mapping_state ( int  camera_id)
Parameters
Returns
The current state ( SL_SPATIAL_MAPPING_STATE) of the spatial mapping process (
◆ sl_update_mesh()
INTERFACE_API int sl_update_mesh ( int  camera_id,
int *  nb_vertices_per_submesh,
int *  nb_triangles_per_submesh,
int *  nb_submeshes,
Parameters
nb_submeshes: Number of submeshes.
num_vertices_tot: Total number of updated vertices in all submeshes.
num_triangles_tot: Total number of updated triangles in all submeshes.
Returns
SUCCESS if the mesh is updated.
◆ sl_retrieve_mesh()
INTERFACE_API int sl_retrieve_mesh ( int  camera_id,
float *  vertices,
int *  triangles,
float *  uvs,
unsigned char *  texture_ptr,
Parameters
vertices: Vertices of the mesh
triangles: Triangles of the mesh.
max_submeshes: Maximum number of submesh that can be handled.
uvs: uvs of the texture.
texture_ptr: Texture of the mesh (if enabled).
Returns
SUCCESS if the mesh is retrieved.
◆ sl_update_chunks()
INTERFACE_API int sl_update_chunks ( int  camera_id,
int *  nb_submeshes,
Parameters
Returns
SUCCESS if the chunks are updated.
◆ sl_retrieve_chunks()
INTERFACE_API int sl_retrieve_chunks ( int  camera_id,
float *  vertices,
int *  triangles,
float *  uvs,
Parameters
max_submesh: Maximum number of submesh that can be handled.
vertices: Vertices of the chunk
triangles: Triangles of the chunk.
Returns
SUCCESS if the chunk is retrieved.
◆ sl_update_fused_point_cloud()
INTERFACE_API int sl_update_fused_point_cloud ( int  camera_id,
Parameters
num_vertices_tot: returns the total number of vertices.
Returns
SUCCESS if the fused point cloud is updated.
◆ sl_retrieve_fused_point_cloud()
INTERFACE_API int sl_retrieve_fused_point_cloud ( int  camera_id,
float *  vertices
Parameters
vertices: Points of the fused point cloud.
Returns
SUCCESS if the fused point cloud is retrieved.
◆ sl_extract_whole_spatial_map()
INTERFACE_API int sl_extract_whole_spatial_map ( int  camera_id)
Parameters
camera_id: id of the camera instance. SUCCESS if the mesh is filled and available, otherwise FAILURE.
◆ sl_save_mesh()
INTERFACE_API bool sl_save_mesh ( int  camera_id,
Parameters
filename: Path and filename of the mesh.
format: File format (extension). Can be .obj, .ply or .bin.
Returns
True if the file was successfully saved, false otherwise.
◆ sl_save_point_cloud()
INTERFACE_API bool sl_save_point_cloud ( int  c_id,
Parameters
filename: Path and filename of the point cloud.
Returns
◆ sl_load_mesh()
INTERFACE_API bool sl_load_mesh ( int  camera_id,
int *  num_submeshes,
int *  textures_size,
Parameters
filename: Path and filename of the mesh. Should incluse the extension (.obj, .ply or .bin).
nb_ertices: Array of the number of vertices in each submesh.
nb_sub_meshes: Number of submeshes.
updated_indices: List of all submeshes updated since the last update.
nb_triangles_tot: Array of the number of triangles in each submesh.
max_submesh: Maximum number of submeshes taht can be handled.
texture_size: Array containing the sizes of all the textures (width ,height) if applicable.
Returns
True if the file was successfully loaded, false otherwise.
◆ sl_apply_texture()
INTERFACE_API bool sl_apply_texture ( int  camera_id,
Parameters
Returns
True if the texturing was successful, false otherwise.
◆ sl_filter_mesh()
INTERFACE_API bool sl_filter_mesh ( int  camera_id,
Parameters
filter_params: Filter level. Higher settings remore more triangles (SL_MeshFilterParameters::MESH_FILTER).
max_submesh: Maximum number of submeshes that can be handled.
Returns
True if the filtering was successful, false otherwise.
◆ sl_spatial_mapping_get_gravity_estimation()
INTERFACE_API void sl_spatial_mapping_get_gravity_estimation ( int  camera_id,
struct SL_Vector3 gravity
Parameters
gravity[Out] : vector of gravity.
◆ sl_update_whole_mesh()
INTERFACE_API int sl_update_whole_mesh ( int  camera_id,
int *  nb_vertices,
int *  nb_triangles
Parameters
nb_vertices: Total number of updated vertices in all submeshes.
nb_triangles: Total number of updated triangles in all submeshes.
Returns
◆ sl_retrieve_whole_mesh()
INTERFACE_API int sl_retrieve_whole_mesh ( int  camera_id,
float *  vertices,
int *  triangles,
float *  uvs,
Parameters
Returns
◆ sl_load_whole_mesh()
INTERFACE_API bool sl_load_whole_mesh ( int  camera_id,
int *  nb_vertices,
int *  nb_triangles,
int *  texture_size
Parameters
Returns
◆ sl_apply_whole_texture()
INTERFACE_API bool sl_apply_whole_texture ( int  camera_id,
int *  nb_vertices,
int *  nb_triangles,
int *  texture_size
Parameters
Returns
◆ sl_filter_whole_mesh()
INTERFACE_API bool sl_filter_whole_mesh ( int  camera_id,
int *  nb_vertices,
int *  nb_triangles
Parameters
Returns
◆ sl_find_floor_plane()
INTERFACE_API struct SL_PlaneData* sl_find_floor_plane ( int  camera_id,
struct SL_Quaternion reset_quaternion,
struct SL_Vector3 reset_translation,
Parameters
reset_quaternion: The rotation to align the axis with the gravity.
reset_translation: The translation to align the tracking with the floor plane. The initial position will then be at ground height.
prior_rotation: Prior rotation.
prior_translation: Prior translation.
Returns
The detected floor plane if the function succeeded.
◆ sl_find_plane_at_hit()
INTERFACE_API struct SL_PlaneData* sl_find_plane_at_hit ( int  camera_id,
bool  thres
Parameters
pixel: Point on the ZED image to check for a plane.
thres: Check if area is enough for Unity. If true, removes smaller planes.
Returns
Data of the detected plane.
◆ sl_convert_floorplane_to_mesh()
INTERFACE_API int sl_convert_floorplane_to_mesh ( int  camera_id,
float *  vertices,
int *  triangles,
Parameters
vertices: Array to be filled with mesh vertices.
triangles: Array to be filled with mesh triangles, stored as indexes of each triangle's points.
nb_vertices_tot: Total number of vertices in the mesh.
nb_triangles_tot: Total triangles indexes (3x number of triangles).
Returns
SUCCESS if the mesh conversion was successful.
◆ sl_convert_hitplane_to_mesh()
INTERFACE_API int sl_convert_hitplane_to_mesh ( int  camera_id,
float *  vertices,
int *  triangles,
Parameters
Returns
◆ sl_retrieve_measure()
INTERFACE_API int sl_retrieve_measure ( int  camera_id,
void *  measure_ptr,
enum SL_MEM  mem,
int  width,
int  height
Parameters
measure_ptr: pointer to the measure texture.
type: Measure type (depth, confidence, xyz, etc). See SL_MEASURE.
mem: Whether the measure should be on CPU or GPU memory. See SL_MEM.
width: width of the texture in pixel.
height: height of the texture in pixel.
Returns
"SUCCESS" if the retrieve succeeded.
◆ sl_retrieve_image()
INTERFACE_API int sl_retrieve_image ( int  camera_id,
void *  image_ptr,
enum SL_VIEW  type,
enum SL_MEM  mem,
int  width,
int  height
Parameters
image_ptr: pointer to the image texture.
type: Image type (left RGB, right depth map, etc). See SL_VIEW.
mem: Whether the image should be on CPU or GPU memory (SL_MEM).
Returns
◆ sl_convert_image()
INTERFACE_API int sl_convert_image ( void *  image_in_ptr,
void *  image_signed_ptr,
cudaStream_t  stream
Parameters
image_in: input image to convert
image_signed: output image to converted
stream: a cuda stream to put the compute to (def. 0)
Note
If the Output Mat does not satisfies the requirements, it is freed and re-allocated.
◆ sl_enable_streaming()
INTERFACE_API int sl_enable_streaming ( int  camera_id,
int  gop_size,
int  chunk_size,
Parameters
codec: defines the codec used for streaming (see SL_STREAMING_CODE).
bitrate: defines the streaming bitrate in Kbits/s.
STREAMING_CODEC Resolution FPS bitrate (kbps)
H264 HD2K 15 8500
H264 HD1080 30 12500
H264 HD720 60 7000
H265 HD2K 15 7000
H265 HD1080 30 11000
H265 HD720 60 6000
Note
Available range : [1000 - 60000]
Parameters
port: defines the port used for streaming.
gop_size: defines the gop size in number of frames.
adaptative_bitrate: enable/disable adaptive bitrate.
chunk_size: defines a single chunk size.
target_framrate: defines the target framerate for the streaming output.
Returns
An ERROR_CODE that defines if the stream was started.
◆ sl_disable_streaming()
INTERFACE_API void sl_disable_streaming ( int  camera_id)
Parameters
◆ sl_is_streaming_enabled()
INTERFACE_API int sl_is_streaming_enabled ( int  camera_id)
Parameters
Returns
True is the streaming is running, False if still initializing.
◆ sl_get_streaming_parameters()
INTERFACE_API struct SL_StreamingParameters* sl_get_streaming_parameters ( int  camera_id)
Returns
SL_StreamingParameters containing the parameters used for streaming initialization.
◆ sl_save_current_image()
INTERFACE_API int sl_save_current_image ( int  camera_id,
enum SL_VIEW  view,
const char *  file_name
Parameters
view: View of the image (SL_VIEW).
file_name: file path including the name and extension.
Returns
SUCCESS if the image was successfuly saved.
◆ sl_save_current_depth()
INTERFACE_API int sl_save_current_depth ( int  camera_id,
enum SL_SIDE  side,
Parameters
side: side of the image (0 = left, 1 = right).
Returns
SUCCESS if the depth was successfuly saved.
◆ sl_save_current_point_cloud()
INTERFACE_API int sl_save_current_point_cloud ( int  camera_id,
enum SL_SIDE  side,
Parameters
side: side of the pc (0 = left, 1 = right).
Returns
SUCCESS if the point cloud was successfuly saved.
◆ sl_check_AI_model_status()
INTERFACE_API struct SL_AI_Model_status* sl_check_AI_model_status ( enum SL_AI_MODELS  model,
int  gpu_id
Parameters
model: AI model to check.
gpu_id: ID of the gpu.
Returns
The status of the given model for the specified GPU.
◆ sl_optimize_AI_model()
INTERFACE_API int sl_optimize_AI_model ( enum SL_AI_MODELS  model,
int  gpu_id
Parameters
model: AI model to optimize.
gpu_id: ID of the gpu to optimize on.
Returns
SUCCESS if the model is well optimized.
◆ sl_enable_objects_detection()
INTERFACE_API int sl_enable_objects_detection ( int  camera_id,
struct SL_ObjectDetectionParameters object_detection_parameters
  • Multiple class of objects with the DETECTION_MODEL::MULTI_CLASS_BOX, DETECTION_MODEL::MULTI_CLASS_BOX_MEDIUM or DETECTION_MODEL::MULTI_CLASS_BOX_ACCURATE. The full list of detectable objects is available through OBJECT_CLASS and OBJECT_SUBCLASS.
  • Human skeleton detection with the DETECTION_MODEL::HUMAN_BODY_FAST,DETECTION_MODEL::HUMAN_BODY_MEDIUM or DETECTION_MODEL::HUMAN_BODY_ACCURATE. This model only detects humans but also provides a full skeleton map for each person.
Detected objects can be retrieved using the retrieve_objects() function.
Parameters
object_detection_parameters: structure containing all specific parameters for object detection (see SL_ObjectDetectionParameters).
Returns
  • ERROR_CODE::SUCCESS : if everything went fine.
  • ERROR_CODE::CORRUPTED_SDK_INSTALLATION : if the AI model is missing or corrupted. In this case, the SDK needs to be reinstalled.
  • ERROR_CODE::MODULE_NOT_COMPATIBLE_WITH_CAMERA : if the camera used does not have a IMU (ZED Camera). the IMU gives the gravity vector that helps in the 3D box localization.
  • ERROR_CODE::MOTION_SENSORS_REQUIRED : if the camera model is correct (ZED2/ZED2i) but the IMU is missing. It probably happens because InitParameters::disable_sensors was set to true.
  • ERROR_CODE::INVALID_FUNCTION_CALL : if one of the ObjectDetection parameter is not compatible with other modules parameters (For example, depth mode has been set to NONE).
  • ERROR_CODE::FAILURE : otherwise.
◆ sl_get_object_detection_parameters()
INTERFACE_API struct SL_ObjectDetectionParameters* sl_get_object_detection_parameters ( int  cmaera_id)
Parameters
Returns
ObjectDetectionParameters containing the parameters used for object detection initialization.
◆ sl_pause_objects_detection()
INTERFACE_API void sl_pause_objects_detection ( int  camera_id,
bool  status
If the object detection has been enabled with ObjectDetectionParameters::image_sync set to false (running asynchronously), this function will pause processing.
While in pause, calling this function with status = false will resume the object detection. The retrieveObjects function will keep on returning the last objects detected while in pause.
Parameters
status: If true, object detection is paused. If false, object detection is resumed.
◆ sl_disable_objects_detection()
INTERFACE_API void sl_disable_objects_detection ( int  camera_id)
The object detection module immediately stops and frees its memory allocations.
Parameters
◆ sl_generate_unique_id()
INTERFACE_API int sl_generate_unique_id ( char *  uuid)
Parameters
uuid: Unique ID generated.
Returns
: Size of the unique ID generated.
◆ sl_ingest_custom_box_objects()
INTERFACE_API int sl_ingest_custom_box_objects ( int  camera_id,
int  nb_objects,
struct SL_CustomBoxObjectData objects_in
Parameters
objects_in: 2D detections from custom detection algorithm.
nb_objects: number of custom objects (size of the object_in array).
Note
The detection should be done on the current grabbed left image as the internal process will use all current available data to extract 3D informations and perform object tracking.
Returns
◆ sl_retrieve_objects()
INTERFACE_API int sl_retrieve_objects ( int  camera_id,
struct SL_ObjectDetectionRuntimeParameters object_detection_runtime_parameters,
struct SL_Objects objects
Parameters
objects: The detected objects will be saved into this object. If the object already contains data from a previous detection, it will be updated, keeping a unique ID for the same person.
object_detection_runtime_parameters: Object detection runtime settings, can be changed at each detection. In async mode, the parameters update is applied on the next iteration.
Returns
◆ sl_update_objects_batch()
INTERFACE_API int sl_update_objects_batch ( int  camera_id,
int *  nb_batches
Parameters
[Out]: number of batches.
Returns
◆ sl_get_objects_batch()
INTERFACE_API int sl_get_objects_batch ( int  camera_id,
int  index,
struct SL_ObjectsBatch objs_batch
Parameters
index: index of the batch to retrieve ([0, nb_batches]).
nb_data: number of detected objects in the batch.
id: The trajectory ID.
label: Object Category. Identify the object type (SL_OBJECT_CLASS).
sublabel: Object subclass (SL_OBJECT_SUBCLASS).
tracking_state: defines the object tracking state (SL_OBJECT_TRACKING_STATE).
positions: a sample of 3D positions.
position_covariances: a sample of the associated position covariances.
velocities: a sample of 3D velocity.
timestamps: The associated position timestamp.
bounding_boxes_2d: 2D bounding box of the person represented as four 2D points starting at the top left corner and rotation clockwise. Expressed in pixels on the original image resolution, [0,0] is the top left corner. A ---— B | Object | D ---— C
bounding_box: a sample of 3d bounding boxes.
confidences: a sample of object detection confidence.
action_states: a sample of object action state (SL_OBJECT_ACTION_STATE).
keypoints_2d: a sample of 2d position keypoints. Not available with DETECTION_MODE::MULTI_CLASS_BOX.
keypoints: a sample of 3d position keypoints. Not available with DETECTION_MODE::MULTI_CLASS_BOX.
head_bounding_boxes_2d: bounds the head with four 2D points. Not available with DETECTION_MODE::MULTI_CLASS_BOX.
head_bounding_boxes: bounds the head with eight 3D points. Not available with DETECTION_MODE::MULTI_CLASS_BOX.
head_positions: 3D head centroids.
keypoint_confidences: Per keypoint detection confidence, can not be lower than the ObjectDetectionRuntimeParameters::detection_confidence_threshold. Not available with DETECTION_MODEL::MULTI_CLASS_BOX.
Returns
◆ sl_mat_create_new()
INTERFACE_API void* sl_mat_create_new ( int  width,
int  height,
enum SL_MEM  mem
Parameters
width: width of the new mat.
height: height of the new mat.
type: Data type and number of channels the Mat will hold (see SL_MAT_TYPE).
mem: Whether Mat should exist on CPU or GPU memory (SL_MEM).
Returns
Ptr of the Mat.
◆ sl_mat_create_new_empty()
INTERFACE_API void* sl_mat_create_new_empty ( )
Returns
Ptr of the Mat.
◆ sl_mat_is_init()
INTERFACE_API bool sl_mat_is_init ( void *  ptr)
Parameters
ptr: Ptr to the Mat.
Returns
True if the Mat has been initialized.
◆ sl_mat_free()
INTERFACE_API void sl_mat_free ( void *  ptr,
enum SL_MEM  mem
Parameters
Returns
◆ sl_mat_get_infos()
INTERFACE_API void sl_mat_get_infos ( void *  ptr,
char *  buffer
Parameters
buffer: buffer providing Mat information.
◆ sl_mat_get_value_uchar()
INTERFACE_API int sl_mat_get_value_uchar ( void *  ptr,
int  col,
int  row,
unsigned char *  value,
enum SL_MEM  mem
Parameters
col: specifies the column.
row: specifices the row.
value[Out] : the value to get.
Returns
ERROR_CODE::SUCCESS if everything went well, ERROR_CODE::FAILURE otherwise.
◆ sl_mat_get_value_uchar2()
INTERFACE_API int sl_mat_get_value_uchar2 ( void *  ptr,
int  col,
int  row,
enum SL_MEM  mem
Parameters
Returns
◆ sl_mat_get_value_uchar3()
INTERFACE_API int sl_mat_get_value_uchar3 ( void *  ptr,
int  col,
int  row,
enum SL_MEM  mem
Parameters
Returns
◆ sl_mat_get_value_uchar4()
INTERFACE_API int sl_mat_get_value_uchar4 ( void *  ptr,
int  col,
int  row,
enum SL_MEM  mem
Parameters
Returns
◆ sl_mat_get_value_float()
INTERFACE_API int sl_mat_get_value_float ( void *  ptr,
int  col,
int  row,
float *  value,
enum SL_MEM  mem
Parameters
Returns
◆ sl_mat_get_value_float2()
INTERFACE_API int sl_mat_get_value_float2 ( void *  ptr,
int  col,
int  row,
enum SL_MEM  mem
Parameters
Returns
◆ sl_mat_get_value_float3()
INTERFACE_API int sl_mat_get_value_float3 ( void *  ptr,
int  col,
int  row,
enum SL_MEM  mem
Parameters
Returns
◆ sl_mat_get_value_float4()
INTERFACE_API int sl_mat_get_value_float4 ( void *  ptr,
int  col,
int  row,
enum SL_MEM  mem
Parameters
Returns
◆ sl_mat_set_value_uchar()
INTERFACE_API int sl_mat_set_value_uchar ( void *  ptr,
int  col,
int  row,
enum SL_MEM  mem
Parameters
value: the value to be set.
Returns
◆ sl_mat_set_value_uchar2()
INTERFACE_API int sl_mat_set_value_uchar2 ( void *  ptr,
int  col,
int  row,
enum SL_MEM  mem
Parameters
Returns
◆ sl_mat_set_value_uchar3()
INTERFACE_API int sl_mat_set_value_uchar3 ( void *  ptr,
int  col,
int  row,
enum SL_MEM  mem
Parameters
Returns
◆ sl_mat_set_value_uchar4()
INTERFACE_API int sl_mat_set_value_uchar4 ( void *  ptr,
int  col,
int  row,
enum SL_MEM  mem
Parameters
Returns
◆ sl_mat_set_value_float()
INTERFACE_API int sl_mat_set_value_float ( void *  ptr,
int  col,
int  row,
float  value,
enum SL_MEM  mem
Parameters
Returns
◆ sl_mat_set_value_float2()
INTERFACE_API int sl_mat_set_value_float2 ( void *  ptr,
int  col,
int  row,
enum SL_MEM  mem
Parameters
Returns
◆ sl_mat_set_value_float3()
INTERFACE_API int sl_mat_set_value_float3 ( void *  ptr,
int  col,
int  row,
enum SL_MEM  mem
Parameters
Returns
◆ sl_mat_set_value_float4()
INTERFACE_API int sl_mat_set_value_float4 ( void *  ptr,
int  col,
int  row,
enum SL_MEM  mem
Parameters
Returns
◆ sl_mat_set_to_uchar()
INTERFACE_API int sl_mat_set_to_uchar ( void *  ptr,
enum SL_MEM  mem
Parameters
value: the value with which to fill the Mat.
Returns
◆ sl_mat_set_to_uchar2()
INTERFACE_API int sl_mat_set_to_uchar2 ( void *  ptr,
enum SL_MEM  mem
Parameters
Returns
◆ sl_mat_set_to_uchar3()
INTERFACE_API int sl_mat_set_to_uchar3 ( void *  ptr,
enum SL_MEM  mem
Parameters
Returns
◆ sl_mat_set_to_uchar4()
INTERFACE_API int sl_mat_set_to_uchar4 ( void *  ptr,
enum SL_MEM  mem
Parameters
Returns
◆ sl_mat_set_to_float()
INTERFACE_API int sl_mat_set_to_float ( void *  ptr,
float  value,
enum SL_MEM  mem
Parameters
Returns
◆ sl_mat_set_to_float2()
INTERFACE_API int sl_mat_set_to_float2 ( void *  ptr,
enum SL_MEM  mem
Parameters
Returns
◆ sl_mat_set_to_float3()
INTERFACE_API int sl_mat_set_to_float3 ( void *  ptr,
enum SL_MEM  mem
Parameters
Returns
◆ sl_mat_set_to_float4()
INTERFACE_API int sl_mat_set_to_float4 ( void *  ptr,
enum SL_MEM  mem
Parameters
Returns
◆ sl_mat_update_cpu_from_gpu()
INTERFACE_API int sl_mat_update_cpu_from_gpu ( void *  ptr)
Parameters
Returns
◆ sl_mat_update_gpu_from_cpu()
INTERFACE_API int sl_mat_update_gpu_from_cpu ( void *  ptr)
Parameters
Returns
◆ sl_mat_copy_to()
INTERFACE_API int sl_mat_copy_to ( void *  ptr,
void *  ptr_dest,
Parameters
ptr: Ptr to the Source Mat.
ptr_dest: Ptr to the Destination Mat.
cpy_type: The To and From memory types (see SL_COPY_TYPE).
Returns
◆ sl_mat_read()
INTERFACE_API int sl_mat_read ( void *  ptr,
const char *  file_path
Parameters
file_path: File path, including file name and extension.
Returns
◆ sl_mat_write()
INTERFACE_API int sl_mat_write ( void *  ptr,
Parameters
Returns
◆ sl_mat_get_width()
INTERFACE_API int sl_mat_get_width ( void *  ptr)
Parameters
Returns
The width of the matrix.
◆ sl_mat_get_height()
INTERFACE_API int sl_mat_get_height ( void *  ptr)
Parameters
Returns
The height of the matrix.
◆ sl_mat_get_channels()
INTERFACE_API int sl_mat_get_channels ( void *  ptr)
Parameters
Returns
Number of values/channels.
◆ sl_mat_get_memory_type()
INTERFACE_API int sl_mat_get_memory_type ( void *  ptr)
Parameters
Returns
The memory type (SL_MEM).
◆ sl_mat_get_data_type()
INTERFACE_API int sl_mat_get_data_type ( void *  ptr)
Parameters
Returns
The memory type (SL_MAT_TYPE).
◆ sl_mat_get_pixel_bytes()
INTERFACE_API int sl_mat_get_pixel_bytes ( void *  ptr)
Parameters
Returns
The size in bytes of one pixel.
◆ sl_mat_get_step()
INTERFACE_API int sl_mat_get_step ( void *  ptr,
enum SL_MEM  mem
Parameters
Returns
The Step length.
◆ sl_mat_get_step_bytes()
INTERFACE_API int sl_mat_get_step_bytes ( void *  ptr,
enum SL_MEM  mem
Parameters
Returns
The Step length in bytes.
◆ sl_mat_get_width_bytes()
INTERFACE_API int sl_mat_get_width_bytes ( void *  ptr)
Parameters
Returns
The size of each row in bytes.
◆ sl_mat_is_memory_owner()
INTERFACE_API bool sl_mat_is_memory_owner ( void *  ptr)
Returns
True if the Mat is the owner of the memory it's accessing.
◆ sl_mat_get_resolution()
INTERFACE_API struct SL_Resolution sl_mat_get_resolution ( void *  ptr)
Parameters
Returns
The resolution of the mat.
◆ sl_mat_alloc()
INTERFACE_API void sl_mat_alloc ( void *  ptr,
int  width,
int  height,
enum SL_MEM  mem
Parameters
width: Width of the image/matrix in pixels.
height: Height of the image/matrix in pixels.
mem: Whether Mat should exist on CPU or GPU memory ( SL_MEM).
◆ sl_mat_set_from()
INTERFACE_API int sl_mat_set_from ( void *  ptr,
void *  ptr_source,
Parameters
ptr_srouce: Source Mat from which to copy.
copy_type: The To and From memory types (SL_COPY_TYPE).
Returns
◆ sl_mat_get_ptr()
INTERFACE_API int* sl_mat_get_ptr ( void *  ptr,
enum SL_MEM  mem
Parameters
Returns
A pointer to the Mat.
◆ sl_mat_clone()
INTERFACE_API int sl_mat_clone ( void *  ptr,
void *  ptr_source
Parameters
◆ sl_mat_swap()
INTERFACE_API void sl_mat_swap ( void *  ptr_1,
void *  ptr_2
Parameters
ptr1: Ptr to the first Mat.
ptr2: Ptr to the second Mat.
