SL_SensorParameters Struct Reference
Structure containing information about a single sensor available in the current device. More...
Data Fields
enum SL_SENSOR_TYPE type
float resolution
float sampling_rate
struct SL_Vector2 range
float noise_density
float random_walk
enum SL_SENSORS_UNIT sensor_unit
bool is_available
Note
This object is meant to be used as a read - only container, editing any of its fields won't impact the SDK.
Field Documentation
◆ resolution
float SL_SensorParameters::resolution
The type of the sensor as DEVICE_SENSORS (SL_SENSOR_TYPE)
◆ sampling_rate
float SL_SensorParameters::sampling_rate
The resolution of the sensor.
◆ range
struct SL_Vector2 SL_SensorParameters::range
The sampling rate (or ODR) of the sensor.
◆ noise_density
float SL_SensorParameters::noise_density
The range values of the sensor. MIN: "range.x", MAX: "range.y"
◆ random_walk
float SL_SensorParameters::random_walk
also known as white noise, given as continous (frequency independant). Units will be expressed in sensor_unit/squared_root(Hz). "NAN" if the information is not available
◆ sensor_unit
enum SL_SENSORS_UNIT SL_SensorParameters::sensor_unit
derived from the Allan Variance, given as continous (frequency independant). Units will be expressed in sensor_unit/s/squared_root(Hz)."NAN" if the information is not available
◆ is_available
bool SL_SensorParameters::is_available
The string relative to the measurement unit of the sensor (SL_SENSORS_UNIT).
