zed_interface.h
Go to the documentation of this file.
1 #ifndef __INTERFACE_ZED_H
2 #define __INTERFACE_ZED_H
3
4 #include "types_c.h"
5 #include <stdbool.h>
6 #include <cuda.h>
7 #include <cuda_runtime.h>
8
13 //#define DEBUG
14 #ifdef _WIN32
15 #ifdef INTERFACE_NOEXPORT
16 #define INTERFACE_API
17 #else
18 #ifdef INTERFACE_EXPORT
19 #define INTERFACE_API __declspec(dllexport)
20 #else
21 #define INTERFACE_API __declspec(dllimport)
22 #endif
23 #endif
24 #else
25 #define INTERFACE_API
26 #endif
27
28 #ifdef __cplusplus
29 extern "C" {
30 #endif
31
32
36  INTERFACE_API void sl_unload_all_instances();
37
42  INTERFACE_API void sl_unload_instance(int camera_id);
43
49  INTERFACE_API bool sl_find_usb_device(enum USB_DEVICE device);
50
57  INTERFACE_API bool sl_create_camera(int camera_id);
58
64  INTERFACE_API bool sl_is_opened(int camera_id);
65
78  INTERFACE_API int sl_open_camera(int camera_id, struct SL_InitParameters *init_parameters, const char* path_svo, const char* ip, int stream_port, const char* output_file, const char* opt_settings_path, const char* opencv_calib_path);
79
84  INTERFACE_API CUcontext sl_get_cuda_context(int camera_id);
85
90  INTERFACE_API struct SL_InitParameters* sl_get_init_parameters(int camera_id);
91
97  INTERFACE_API struct SL_RuntimeParameters* sl_get_runtime_parameters(int camera_id);
98
105
110  INTERFACE_API void sl_close_camera(int camera_id);
111
118  INTERFACE_API int sl_set_region_of_interest(int camera_id, void* roi_mask);
125  INTERFACE_API int sl_grab(int camera_id, struct SL_RuntimeParameters *runtime);
126
134  INTERFACE_API void sl_get_device_list(struct SL_DeviceProperties device_list[MAX_CAMERA_PLUGIN], int* nb_devices);
135
142  INTERFACE_API void sl_get_streaming_device_list(struct SL_StreamingProperties streaming_device_list[MAX_CAMERA_PLUGIN], int* nb_devices);
143
149  INTERFACE_API int sl_reboot(int sn, bool full_reboot);
150
162  INTERFACE_API int sl_enable_recording(int camera_id, const char* filename, enum SL_SVO_COMPRESSION_MODE compression_mode, unsigned int bitrate, int target_fps, bool transcode);
163
168  INTERFACE_API struct SL_RecordingStatus* sl_get_recording_status(int camera_id);
173  INTERFACE_API void sl_disable_recording(int camera_id);
174
180  INTERFACE_API struct SL_RecordingParameters* sl_get_recording_parameters(int camera_id);
181
187  INTERFACE_API void sl_pause_recording(int camera_id, bool status);
188
197  INTERFACE_API int sl_enable_positional_tracking(int camera_id, struct SL_PositionalTrackingParameters * tracking_param, const char* area_file_path);
198
221  INTERFACE_API void sl_disable_positional_tracking(int camera_id, const char *area_file_path);
222
229  INTERFACE_API int sl_save_area_map(int camera_id, const char* area_file_path);
230
236  INTERFACE_API int sl_get_area_export_state(int camera_id);
237
245  INTERFACE_API void sl_set_svo_position(int camera_id, int frame_number);
246
252  INTERFACE_API float sl_get_camera_fps(int camera_id);
253
259  INTERFACE_API float sl_get_current_fps(int camera_id);
260
266  int INTERFACE_API sl_get_width(int camera_id);
267
273  int INTERFACE_API sl_get_height(int camera_id);
274
280  INTERFACE_API int sl_get_confidence_threshold(int camera_id);
281
289  INTERFACE_API struct SL_CameraInformation* sl_get_camera_information(int camera_id, int res_width, int res_height);
290
296  INTERFACE_API void sl_update_self_calibration(int camera_id);
297
304  INTERFACE_API struct SL_CalibrationParameters* sl_get_calibration_parameters(int camera_id, bool raw_params);
305
311  INTERFACE_API struct SL_SensorsConfiguration* sl_get_sensors_configuration(int camera_id);
312
319  INTERFACE_API void sl_get_camera_imu_transform(int camera_id, struct SL_Vector3 *translation, struct SL_Quaternion *rotation);
320
326  INTERFACE_API int sl_get_input_type(int camera_id);
327
333  INTERFACE_API int sl_get_zed_serial(int camera_id);
334
340  INTERFACE_API int sl_get_camera_firmware(int camera_id);
341
347  INTERFACE_API int sl_get_sensors_firmware(int camera_id);
348
354  INTERFACE_API int sl_get_camera_model(int camera_id);
355
361  INTERFACE_API unsigned long long sl_get_image_timestamp(int camera_id);
362
368  INTERFACE_API unsigned long long sl_get_current_timestamp(int camera_id);
369
375  INTERFACE_API int sl_get_svo_number_of_frames(int camera_id);
376
383  INTERFACE_API void sl_set_camera_settings(int camera_id, enum SL_VIDEO_SETTINGS mode, int value);
384
393  INTERFACE_API int sl_set_roi_for_aec_agc(int camera_id, enum SL_SIDE side, struct SL_Rect* roi, bool reset);
394
401  INTERFACE_API int sl_get_camera_settings(int camera_id, enum SL_VIDEO_SETTINGS mode);
402
410  INTERFACE_API int sl_get_roi_for_aec_agc(int id, enum SL_SIDE side, struct SL_Rect* roi);
411
417  INTERFACE_API float sl_get_depth_min_range_value(int camera_id);
418
424  INTERFACE_API float sl_get_depth_max_range_value(int camera_id);
425
433  INTERFACE_API int sl_get_current_min_max_depth(int camera_id,float* min, float* max);
434
439  INTERFACE_API int sl_get_number_zed_connected();
440
445  INTERFACE_API char* sl_get_sdk_version();
446
454  INTERFACE_API int sl_convert_coordinate_system(struct SL_Quaternion* rotation, struct SL_Vector3* translation, enum SL_COORDINATE_SYSTEM coord_system_src, enum SL_COORDINATE_SYSTEM coord_system_dest);
455
462  //INTERFACE_API void sl_get_sdk_version(int *major, int *minor, int *patch);
463
469  INTERFACE_API int sl_get_svo_position(int camera_id);
470
476  INTERFACE_API unsigned int sl_get_frame_dropped_count(int camera_id);
477
478
482
488  INTERFACE_API bool sl_is_positional_tracking_enabled(int camera_id);
489
500  INTERFACE_API int sl_get_position_at_target_frame(int camera_id, struct SL_Quaternion *rotation, struct SL_Vector3 *position, struct SL_Quaternion *target_quaternion, struct SL_Vector3 *target_translation, enum SL_REFERENCE_FRAME reference_frame);
508  INTERFACE_API int sl_get_position_data(int camera_id, struct SL_PoseData *poseData, enum SL_REFERENCE_FRAME reference_frame);
517  INTERFACE_API int sl_get_position(int camera_id, struct SL_Quaternion *rotation, struct SL_Vector3 *position, enum SL_REFERENCE_FRAME reference_frame);
525  INTERFACE_API int sl_get_position_array(int camera_id, float* pose, enum SL_REFERENCE_FRAME reference_frame);
526
534  INTERFACE_API int sl_reset_positional_tracking(int camera_id, struct SL_Quaternion rotation, struct SL_Vector3 translation);
544  INTERFACE_API int sl_reset_positional_tracking_with_offset(int camera_id, struct SL_Quaternion rotation, struct SL_Vector3 translation, struct SL_Quaternion target_quaternion, struct SL_Vector3 target_translation);
552  INTERFACE_API int sl_set_imu_prior_orientation(int camera_id, struct SL_Quaternion rotation);
560  INTERFACE_API int sl_get_imu_orientation(int camera_id, struct SL_Quaternion *quat, enum SL_TIME_REFERENCE time_reference);
568  INTERFACE_API int sl_get_sensors_data(int camera_id, struct SL_SensorData *data, enum SL_TIME_REFERENCE time_reference);
569
570
574
588  INTERFACE_API void sl_spatial_mapping_merge_chunks(int camera_id, int nb_faces, int* nb_vertices, int* nb_triangles, int* nb_updated_submeshes, int* updated_indices, int* nb_vertices_tot, int* nb_triangles_tot, const int max_submesh);
589
600  INTERFACE_API int sl_enable_spatial_mapping(int camera_id, struct SL_SpatialMappingParameters* mapping_param);
605  INTERFACE_API void sl_disable_spatial_mapping(int camera_id);
606
618  INTERFACE_API void sl_pause_spatial_mapping(int camera_id, bool status);
623  INTERFACE_API void sl_request_mesh_async(int camera_id);
629  INTERFACE_API int sl_get_mesh_request_status_async(int camera_id);
635  INTERFACE_API enum SL_SPATIAL_MAPPING_STATE sl_get_spatial_mapping_state(int camera_id);
648  INTERFACE_API int sl_update_mesh(int camera_id, int* nb_vertices_per_submesh, int* nb_triangles_per_submesh, int* nb_submeshes, int* updated_indices, int* nb_vertices_tot, int* nb_triangles_tot, const int max_submesh);
660  INTERFACE_API int sl_retrieve_mesh(int camera_id, float* vertices, int* triangles, float* uvs, unsigned char* texture_ptr, const int max_submeshes);
673  INTERFACE_API int sl_update_chunks(int camera_id, int* nb_vertices_per_submesh, int* nb_triangles_per_submesh, int* nb_submeshes, int* updated_indices, int* nb_vertices_tot, int* nb_triangles_tot, const int max_submesh);
685  INTERFACE_API int sl_retrieve_chunks(int camera_id, float* vertices, int* triangles, float* uvs, unsigned char* texture_ptr, const int max_submesh);
686
693  INTERFACE_API int sl_update_fused_point_cloud(int camera_id, int* nb_vertices_tot);
700  INTERFACE_API int sl_retrieve_fused_point_cloud(int camera_id, float* vertices);
706  INTERFACE_API int sl_extract_whole_spatial_map(int camera_id);
714  INTERFACE_API bool sl_save_mesh(int camera_id, const char* filename, enum SL_MESH_FILE_FORMAT format);
722  INTERFACE_API bool sl_save_point_cloud(int c_id, const char* filename, enum SL_MESH_FILE_FORMAT format);
737  INTERFACE_API bool sl_load_mesh(int camera_id, const char* filename, int* nb_vertices_per_submesh, int* nb_triangles_per_submesh, int* num_submeshes, int* updated_indices, int* nb_vertices_tot, int* nb_triangles_tot, int* textures_size,const int max_submesh);
751  INTERFACE_API bool sl_apply_texture(int camera_id, int* nb_vertices_per_submesh, int* nb_triangles_per_submesh, int* nb_updated_submeshes, int* updated_indices, int* nb_vertices_tot, int* nb_triangles_tot, int* textures_size, const int max_submesh);
765  INTERFACE_API bool sl_filter_mesh(int camera_id, enum SL_MESH_FILTER filter_params, int* nb_vertices_per_submesh, int* nb_triangles_per_submesh, int* nb_updated_submeshes, int* updated_indices, int* nb_vertices_tot, int* nb_triangles_tot, const int max_submesh);
773  INTERFACE_API void sl_spatial_mapping_get_gravity_estimation(int camera_id, struct SL_Vector3 *gravity);
774
775
777
785  INTERFACE_API int sl_update_whole_mesh(int camera_id, int* nb_vertices, int* nb_triangles);
796  INTERFACE_API int sl_retrieve_whole_mesh(int camera_id, float* vertices, int* triangles, float* uvs, unsigned char* texture_ptr);
807  INTERFACE_API bool sl_load_whole_mesh(int camera_id, const char* filename, int* nb_vertices, int* nb_triangles, int* texture_size);
816  INTERFACE_API bool sl_apply_whole_texture(int camera_id, int* nb_vertices, int* nb_triangles, int* texture_size);
824  INTERFACE_API bool sl_filter_whole_mesh(int camera_id, enum SL_MESH_FILTER filter_params, int* nb_vertices, int* nb_triangles);
825
826
830
840  INTERFACE_API struct SL_PlaneData* sl_find_floor_plane(int camera_id, struct SL_Quaternion *reset_quaternion, struct SL_Vector3* reset_translation, struct SL_Quaternion prior_rotation, struct SL_Vector3 prior_translation);
848  INTERFACE_API struct SL_PlaneData* sl_find_plane_at_hit(int camera_id, struct SL_Vector2 pixel, bool thres);
858  INTERFACE_API int sl_convert_floorplane_to_mesh(int camera_id, float* vertices, int* triangles, int* nb_vertices_tot, int* nb_triangles_tot);
868  INTERFACE_API int sl_convert_hitplane_to_mesh(int camera_id, float* vertices, int* triangles, int* nb_vertices_tot, int* nb_triangles_tot);
869
870
874
887  INTERFACE_API int sl_retrieve_measure(int camera_id, void* measure_ptr, enum SL_MEASURE type, enum SL_MEM mem, int width, int height);
900  INTERFACE_API int sl_retrieve_image(int camera_id, void* image_ptr, enum SL_VIEW type, enum SL_MEM mem, int width, int height);
901
909  INTERFACE_API int sl_convert_image(void* image_in_ptr, void* image_signed_ptr, cudaStream_t stream);
910
914
937  INTERFACE_API int sl_enable_streaming(int camera_id, enum SL_STREAMING_CODEC codec, unsigned int bitrate, unsigned short port, int gop_size, int adaptative_bitrate, int chunk_size, int target_framerate);
938
943  INTERFACE_API void sl_disable_streaming(int camera_id);
949  INTERFACE_API int sl_is_streaming_enabled(int camera_id);
950
955  INTERFACE_API struct SL_StreamingParameters* sl_get_streaming_parameters(int camera_id);
956
960
968  INTERFACE_API int sl_save_current_image(int camera_id, enum SL_VIEW view, const char* file_name);
976  INTERFACE_API int sl_save_current_depth(int camera_id, enum SL_SIDE side, const char* file_name);
984  INTERFACE_API int sl_save_current_point_cloud(int camera_id, enum SL_SIDE side, const char* file_name);
985
986
987
988 #if WITH_OBJECT_DETECTION
989
993
1000  INTERFACE_API struct SL_AI_Model_status* sl_check_AI_model_status(enum SL_AI_MODELS model, int gpu_id);
1001
1008  INTERFACE_API int sl_optimize_AI_model(enum SL_AI_MODELS model, int gpu_id);
1009
1029  INTERFACE_API int sl_enable_objects_detection(int camera_id, struct SL_ObjectDetectionParameters* object_detection_parameters);
1030
1037
1048  INTERFACE_API void sl_pause_objects_detection(int camera_id, bool status);
1055  INTERFACE_API void sl_disable_objects_detection(int camera_id);
1056
1062  INTERFACE_API int sl_generate_unique_id(char* uuid);
1063
1072  INTERFACE_API int sl_ingest_custom_box_objects(int camera_id, int nb_objects, struct SL_CustomBoxObjectData* objects_in);
1073
1081  INTERFACE_API int sl_retrieve_objects(int camera_id, struct SL_ObjectDetectionRuntimeParameters* object_detection_runtime_parameters, struct SL_Objects* objects);
1082
1089  INTERFACE_API int sl_update_objects_batch(int camera_id, int* nb_batches);
1090
1125  INTERFACE_API int sl_get_objects_batch(int camera_id, int index, struct SL_ObjectsBatch* objs_batch);
1126
1127
1128  INTERFACE_API int sl_get_objects_batch_csharp(int camera_id, int index, int* nb_data, int* id, int* label, int* sublabel, int* tracking_state,
1129  struct SL_Vector3 positions[MAX_TRAJECTORY_SIZE], float position_covariances[MAX_TRAJECTORY_SIZE][6], struct SL_Vector3 velocities[MAX_TRAJECTORY_SIZE], unsigned long long timestamps[MAX_TRAJECTORY_SIZE],
1130  struct SL_Vector2 bounding_boxes_2d[MAX_TRAJECTORY_SIZE][4], struct SL_Vector3 bounding_boxes[MAX_TRAJECTORY_SIZE][8], float confidences[MAX_TRAJECTORY_SIZE], int action_states[MAX_TRAJECTORY_SIZE],
1131  struct SL_Vector2 keypoints_2d[MAX_TRAJECTORY_SIZE][18], struct SL_Vector3 keypoints[MAX_TRAJECTORY_SIZE][18], struct SL_Vector2 head_bounding_boxes_2d[MAX_TRAJECTORY_SIZE][4], struct SL_Vector3 head_bounding_boxes[MAX_TRAJECTORY_SIZE][8],
1132  struct SL_Vector3 head_positions[MAX_TRAJECTORY_SIZE], float keypoints_confidences[MAX_TRAJECTORY_SIZE][18]);
1133 #endif
1134 #ifdef __cplusplus
1135 }
1136 #endif
1137
1138 #ifdef __cplusplus
1139 extern "C" {
1140 #endif
1141
1145
1154  INTERFACE_API void* sl_mat_create_new(int width, int height, enum SL_MAT_TYPE type, enum SL_MEM mem);
1159  INTERFACE_API void* sl_mat_create_new_empty();
1165  INTERFACE_API bool sl_mat_is_init(void* ptr);
1172  INTERFACE_API void sl_mat_free(void* ptr, enum SL_MEM mem);
1178  INTERFACE_API void sl_mat_get_infos(void* ptr, char* buffer);
1179
1180  // GET values
1190  INTERFACE_API int sl_mat_get_value_uchar(void* ptr, int col, int row, unsigned char* value, enum SL_MEM mem);
1200  INTERFACE_API int sl_mat_get_value_uchar2(void* ptr, int col, int row, struct SL_Uchar2* value, enum SL_MEM mem);
1210  INTERFACE_API int sl_mat_get_value_uchar3(void* ptr, int col, int row, struct SL_Uchar3 * value, enum SL_MEM mem);
1220  INTERFACE_API int sl_mat_get_value_uchar4(void* ptr, int col, int row, struct SL_Uchar4* value, enum SL_MEM mem);
1221
1231  INTERFACE_API int sl_mat_get_value_float(void* ptr, int col, int row, float* value, enum SL_MEM mem);
1241  INTERFACE_API int sl_mat_get_value_float2(void* ptr, int col, int row, struct SL_Vector2 * value, enum SL_MEM mem);
1251  INTERFACE_API int sl_mat_get_value_float3(void* ptr, int col, int row, struct SL_Vector3 * value, enum SL_MEM mem);
1261  INTERFACE_API int sl_mat_get_value_float4(void* ptr, int col, int row, struct SL_Vector4 * value, enum SL_MEM mem);
1262
1263  // SET VALUE
1273  INTERFACE_API int sl_mat_set_value_uchar(void* ptr, int col, int row, unsigned char value, enum SL_MEM mem);
1283  INTERFACE_API int sl_mat_set_value_uchar2(void* ptr, int col, int row, struct SL_Uchar2 value, enum SL_MEM mem);
1293  INTERFACE_API int sl_mat_set_value_uchar3(void* ptr, int col, int row, struct SL_Uchar3 value, enum SL_MEM mem);
1303  INTERFACE_API int sl_mat_set_value_uchar4(void* ptr, int col, int row, struct SL_Uchar4 value, enum SL_MEM mem);
1313  INTERFACE_API int sl_mat_set_value_float(void* ptr, int col, int row, float value, enum SL_MEM mem);
1323  INTERFACE_API int sl_mat_set_value_float2(void* ptr, int col, int row, struct SL_Vector2 value, enum SL_MEM mem);
1333  INTERFACE_API int sl_mat_set_value_float3(void* ptr, int col, int row, struct SL_Vector3 value, enum SL_MEM mem);
1343  INTERFACE_API int sl_mat_set_value_float4(void* ptr, int col, int row, struct SL_Vector4 value, enum SL_MEM mem);
1344
1345  //SET TO
1353  INTERFACE_API int sl_mat_set_to_uchar(void* ptr, unsigned char value, enum SL_MEM mem);
1361  INTERFACE_API int sl_mat_set_to_uchar2(void* ptr, struct SL_Uchar2 value, enum SL_MEM mem);
1369  INTERFACE_API int sl_mat_set_to_uchar3(void* ptr, struct SL_Uchar3 value, enum SL_MEM mem);
1377  INTERFACE_API int sl_mat_set_to_uchar4(void* ptr, struct SL_Uchar4 value, enum SL_MEM mem);
1385  INTERFACE_API int sl_mat_set_to_float(void* ptr, float value, enum SL_MEM mem);
1393  INTERFACE_API int sl_mat_set_to_float2(void* ptr, struct SL_Vector2 value, enum SL_MEM mem);
1401  INTERFACE_API int sl_mat_set_to_float3(void* ptr, struct SL_Vector3 value, enum SL_MEM mem);
1409  INTERFACE_API int sl_mat_set_to_float4(void* ptr, struct SL_Vector4 value, enum SL_MEM mem);
1410
1416  INTERFACE_API int sl_mat_update_cpu_from_gpu(void* ptr);
1422  INTERFACE_API int sl_mat_update_gpu_from_cpu(void* ptr);
1430  INTERFACE_API int sl_mat_copy_to(void* ptr, void* ptr_dest, enum SL_COPY_TYPE cpy_type);
1431
1438  INTERFACE_API int sl_mat_read(void* ptr, const char* file_path);
1445  INTERFACE_API int sl_mat_write(void* ptr, const char* file_path);
1451  INTERFACE_API int sl_mat_get_width(void* ptr);
1457  INTERFACE_API int sl_mat_get_height(void* ptr);
1463  INTERFACE_API int sl_mat_get_channels(void* ptr);
1469  INTERFACE_API int sl_mat_get_memory_type(void* ptr);
1470
1476  INTERFACE_API int sl_mat_get_data_type(void* ptr);
1482  INTERFACE_API int sl_mat_get_pixel_bytes(void* ptr);
1488  INTERFACE_API int sl_mat_get_step(void* ptr, enum SL_MEM mem);
1494  INTERFACE_API int sl_mat_get_step_bytes(void* ptr, enum SL_MEM mem);
1500  INTERFACE_API int sl_mat_get_width_bytes(void* ptr);
1505  INTERFACE_API bool sl_mat_is_memory_owner(void* ptr);
1511  INTERFACE_API struct SL_Resolution sl_mat_get_resolution(void* ptr);
1520  INTERFACE_API void sl_mat_alloc(void* ptr, int width, int height, enum SL_MAT_TYPE type, enum SL_MEM mem);
1529  INTERFACE_API int sl_mat_set_from(void* ptr, void* ptr_source, enum SL_COPY_TYPE copy_type);
1536  INTERFACE_API int* sl_mat_get_ptr(void* ptr, enum SL_MEM mem);
1542  INTERFACE_API int sl_mat_clone(void* ptr, void* ptr_source);
1543
1549  INTERFACE_API void sl_mat_swap(void* ptr_1, void* ptr_2);
1550
1551 #ifdef __cplusplus
1552 }
1553 #endif
1554
1555 #endif
contains AI model status.
Definition: types_c.h:1442
Definition: types_c.h:1030
Structure containing information of a single camera (serial number, model, input type,...
Definition: types_c.h:1134
Container to store the externally detected objects. The objects can be ingested using sl_ingest_custo...
Definition: types_c.h:1699
Definition: types_c.h:994
Definition: types_c.h:792
Definition: types_c.h:1451
Definition: types_c.h:1527
Objects batch structure.
Definition: types_c.h:1767
Definition: types_c.h:1736
Definition: types_c.h:115
Definition: types_c.h:97
Definition: types_c.h:1153
Quaternion.
Definition: types_c.h:22
Sets the recording parameters.
Definition: types_c.h:1230
Recording structure that contains information about SVO.
Definition: types_c.h:1210
Definition: types_c.h:1793
Resolution.
Definition: types_c.h:780
Definition: types_c.h:952
Sensor Data structure.
Definition: types_c.h:193
Definition: types_c.h:1087
Definition: types_c.h:1370
Sets the streaming parameters.
Definition: types_c.h:1270
Definition: types_c.h:1342
uchar2
Definition: types_c.h:59
uchar3
Definition: types_c.h:67
uchar4
Definition: types_c.h:76
Vector2.
Definition: types_c.h:32
Vector3.
Definition: types_c.h:40
Vector4.
Definition: types_c.h:49
Lists available coordinates systems for positional tracking and 3D measures.
Definition: types_c.h:281
Gives the spatial mapping state.
Definition: types_c.h:490
SL_MESH_FILE_FORMAT
Lists available mesh file formats.
Definition: types_c.h:518
SL_AI_MODELS
Lists available AI moles.
Definition: types_c.h:656
SL_STREAMING_CODEC
List of codec.
Definition: types_c.h:380
SL_MAT_TYPE
List available Mat formats.
Definition: types_c.h:584
SL_VIDEO_SETTINGS
Lists available camera settings for the ZED camera (contrast, hue, saturation, gain....
Definition: types_c.h:389
SL_TIME_REFERENCE
Lists specific and particular timestamps.
Definition: types_c.h:372
SL_SIDE
Definition: types_c.h:339
SL_REFERENCE_FRAME
Defines which type of position matrix is used to store camera path and pose.
Definition: types_c.h:355
SL_MESH_FILTER
Lists available mesh filtering intensity.
Definition: types_c.h:509
SL_MEM
List available memory type.
Definition: types_c.h:312
Lists available compression modes for SVO recording.
Definition: types_c.h:572
SL_VIEW
Lists available views.
Definition: types_c.h:436
SL_COPY_TYPE
List available copy operation on Mat.
Definition: types_c.h:561
SL_MEASURE
Lists retrievable measures.
Definition: types_c.h:411
INTERFACE_API struct SL_CameraInformation * sl_get_camera_information(int camera_id, int res_width, int res_height)
Returns the calibration parameters, serial number and other information about the camera being used.
INTERFACE_API int sl_mat_get_value_uchar3(void *ptr, int col, int row, struct SL_Uchar3 *value, enum SL_MEM mem)
Returns the value of a specific point in the matrix.
INTERFACE_API int sl_mat_get_value_uchar(void *ptr, int col, int row, unsigned char *value, enum SL_MEM mem)
INTERFACE_API void * sl_mat_create_new(int width, int height, enum SL_MAT_TYPE type, enum SL_MEM mem)
Creates a Mat with the given resolution.
INTERFACE_API struct SL_SpatialMappingParameters * sl_get_spatial_mapping_parameters(int camera_id)
Returns the spatial mapping parameters used. Correspond to the structure send when the enableSpatialM...
INTERFACE_API int sl_mat_get_value_float3(void *ptr, int col, int row, struct SL_Vector3 *value, enum SL_MEM mem)
INTERFACE_API void sl_mat_free(void *ptr, enum SL_MEM mem)
Frees the memory of the Mat.
INTERFACE_API int * sl_mat_get_ptr(void *ptr, enum SL_MEM mem)
Gets a pointer to the Mat.
INTERFACE_API int sl_convert_coordinate_system(struct SL_Quaternion *rotation, struct SL_Vector3 *translation, enum SL_COORDINATE_SYSTEM coord_system_src, enum SL_COORDINATE_SYSTEM coord_system_dest)
Change the coordinate system of a transform matrix.
Creates a camera with resolution mode, fps and id for linux.
INTERFACE_API int sl_mat_set_value_float(void *ptr, int col, int row, float value, enum SL_MEM mem)
Sets a value to a specific point in the matrix.
Returns the current FPS.
INTERFACE_API int sl_mat_set_value_float4(void *ptr, int col, int row, struct SL_Vector4 value, enum SL_MEM mem)
INTERFACE_API bool sl_filter_mesh(int camera_id, enum SL_MESH_FILTER filter_params, int *nb_vertices_per_submesh, int *nb_triangles_per_submesh, int *nb_updated_submeshes, int *updated_indices, int *nb_vertices_tot, int *nb_triangles_tot, const int max_submesh)
Filters a mesh to removes triangles while still preserving its overall shaper (though less accurate).
Gets the ZED camera Current Firmware version.
INTERFACE_API int sl_mat_copy_to(void *ptr, void *ptr_dest, enum SL_COPY_TYPE cpy_type)
Copies data from this Mat to another Mat (deep copy).
INTERFACE_API int sl_retrieve_mesh(int camera_id, float *vertices, int *triangles, float *uvs, unsigned char *texture_ptr, const int max_submeshes)
Retrieves all chunks of the current mesh. Call update_mesh before calling this. Vertex and triangles ...
INTERFACE_API int sl_mat_read(void *ptr, const char *file_path)
Reads an image from a file. Supports .png and .jpeg. Only works if Mat has access to MEM_CPU.
INTERFACE_API int sl_mat_set_to_uchar(void *ptr, unsigned char value, enum SL_MEM mem)
Fills the entire Mat with the given value.
INTERFACE_API int sl_mat_set_value_float3(void *ptr, int col, int row, struct SL_Vector3 value, enum SL_MEM mem)
Gets the number of frames dropped since Grab() was called for the first time. Based on camera timesta...
INTERFACE_API int sl_mat_get_value_float4(void *ptr, int col, int row, struct SL_Vector4 *value, enum SL_MEM mem)
Pauses or resumes the object detection processes.
INTERFACE_API struct SL_RecordingParameters * sl_get_recording_parameters(int camera_id)
Returns the recording parameters used. Correspond to the structure send when the sl_enable_recording(...
Gets the current position of the camera and state of the tracking, with an optional offset to the tra...
Gets the current confidence threshold value for the disparity map (and by extension the depth map).
INTERFACE_API int sl_get_objects_batch(int camera_id, int index, struct SL_ObjectsBatch *objs_batch)
Gets a batch of detected objects. Need to be called after update_objects_batch().
INTERFACE_API void sl_mat_get_infos(void *ptr, char *buffer)
Returns information about the Mat.
INTERFACE_API struct SL_AI_Model_status * sl_check_AI_model_status(enum SL_AI_MODELS model, int gpu_id)
Check if a corresponding optimized engine is found for the requested Model based on your rig configur...
Sets a value in the ZED's camera settings.
Gets a vector pointing toward the direction of gravity. This is estimated from a 3D scan of the envir...
INTERFACE_API int sl_save_area_map(int camera_id, const char *area_file_path)
Saves the current area learning file. The file will contain spatial memory data generated by the trac...
INTERFACE_API int sl_update_fused_point_cloud(int camera_id, int *nb_vertices_tot)
Updates the fused point cloud (if spatial map type was FUSED_POINT_CLOUD).
Gets the ZED Camera model (see SL_MODEL).
Disables the streaming initiated by enable_streaming().
Pauses or resumes the recording.
INTERFACE_API void sl_get_device_list(struct SL_DeviceProperties device_list[MAX_CAMERA_PLUGIN], int *nb_devices)
Lists all the connected devices with their associated information.
INTERFACE_API int sl_mat_get_value_uchar4(void *ptr, int col, int row, struct SL_Uchar4 *value, enum SL_MEM mem)
INTERFACE_API char * sl_get_sdk_version()
Returns the version of the currently installed ZED SDK.
Initializes and starts the positional tracking processes. This function allows you to enable the posi...
INTERFACE_API int sl_update_chunks(int camera_id, int *nb_vertices_per_submesh, int *nb_triangles_per_submesh, int *nb_submeshes, int *updated_indices, int *nb_vertices_tot, int *nb_triangles_tot, const int max_submesh)
Updates the internal version of the mesh and returns the sizes of the meshes.
INTERFACE_API bool sl_load_whole_mesh(int camera_id, const char *filename, int *nb_vertices, int *nb_triangles, int *texture_size)
Loads a saved mesh file.
INTERFACE_API bool sl_load_mesh(int camera_id, const char *filename, int *nb_vertices_per_submesh, int *nb_triangles_per_submesh, int *num_submeshes, int *updated_indices, int *nb_vertices_tot, int *nb_triangles_tot, int *textures_size, const int max_submesh)
INTERFACE_API bool sl_mat_is_memory_owner(void *ptr)
Returns whether the Mat is the owner of the memory it's accessing.
Gets the rotation given by the ZED-M/ZED2 IMU. Returns an error if using ZED (v1) which does not cont...
INTERFACE_API int sl_enable_objects_detection(int camera_id, struct SL_ObjectDetectionParameters *object_detection_parameters)
Initializes and starts the Deep Learning detection module. The object detection module currently su...
INTERFACE_API int sl_save_current_point_cloud(int camera_id, enum SL_SIDE side, const char *file_name)
Writes the point cloud into a file defined by its extension.
INTERFACE_API int sl_mat_get_width_bytes(void *ptr)
Gets the size of each row in bytes.
INTERFACE_API int sl_mat_set_to_uchar4(void *ptr, struct SL_Uchar4 value, enum SL_MEM mem)
INTERFACE_API struct SL_CalibrationParameters * sl_get_calibration_parameters(int camera_id, bool raw_params)
Gets the Calibration Parameters.
INTERFACE_API int sl_get_roi_for_aec_agc(int id, enum SL_SIDE side, struct SL_Rect *roi)
Gets the region of interest for automatic exposure/gain computation.
INTERFACE_API void sl_mat_alloc(void *ptr, int width, int height, enum SL_MAT_TYPE type, enum SL_MEM mem)
Allocates memory for the Mat.
Forces unload of all instances.
INTERFACE_API void sl_spatial_mapping_merge_chunks(int camera_id, int nb_faces, int *nb_vertices, int *nb_triangles, int *nb_updated_submeshes, int *updated_indices, int *nb_vertices_tot, int *nb_triangles_tot, const int max_submesh)
Consolidates the chucks from a scan. This is used to turn a lots of small meshes (which are efficient...
INTERFACE_API struct SL_PlaneData * sl_find_plane_at_hit(int camera_id, struct SL_Vector2 pixel, bool thres)
Check for a plane in hte real world at given screen-space coordinates.
INTERFACE_API int sl_mat_get_value_float(void *ptr, int col, int row, float *value, enum SL_MEM mem)
Starts the mesh generation process in a thread that doesn't block the spatial mapping process.
Tells if the streaming is running (true) or still initializing (false).
Retrieves the estimated position and orientation of the camera in the specified reference frame.
Gets the total number of frames in the loaded SVO file.
INTERFACE_API bool sl_save_mesh(int camera_id, const char *filename, enum SL_MESH_FILE_FORMAT format)
Saves the scanned mesh in a specific file format.
Disables the Spatial Mapping process.
INTERFACE_API int sl_retrieve_whole_mesh(int camera_id, float *vertices, int *triangles, float *uvs, unsigned char *texture_ptr)
Retrieves the full mesh. Call update_mesh before calling this. Vertex and triangles arrays must be at...
INTERFACE_API int sl_enable_recording(int camera_id, const char *filename, enum SL_SVO_COMPRESSION_MODE compression_mode, unsigned int bitrate, int target_fps, bool transcode)
Creates a file for recording the ZED's output into a .SVO or .AVI video. An SVO is Stereolabs' own fo...
Disables the recording initiated by enableRecording() and closes the generated file.
INTERFACE_API int sl_save_current_image(int camera_id, enum SL_VIEW view, const char *file_name)
Writes the image into a file defined by its extension.
INTERFACE_API int sl_mat_get_channels(void *ptr)
Gets the number of channels stored in each pixel.
INTERFACE_API struct SL_PositionalTrackingParameters * sl_get_positional_tracking_parameters(int camera_id)
Returns the PositionalTrackingParameters.
INTERFACE_API int sl_save_current_depth(int camera_id, enum SL_SIDE side, const char *file_name)
Writes the depth map into a file defined by its extension.
INTERFACE_API int sl_get_current_min_max_depth(int camera_id, float *min, float *max)
Gets the current range of perceived depth.
INTERFACE_API struct SL_RuntimeParameters * sl_get_runtime_parameters(int camera_id)
Returns the Runtimeparameters used to open the ZED camera.
INTERFACE_API int sl_mat_get_memory_type(void *ptr)
Gets the type of memory (CPU and/or GPU).
INTERFACE_API int sl_enable_positional_tracking(int camera_id, struct SL_PositionalTrackingParameters *tracking_param, const char *area_file_path)
Reports if the camera has been successfully opened.
INTERFACE_API int sl_retrieve_fused_point_cloud(int camera_id, float *vertices)
Retrieves all points of the fused point cloud. Call update_fused_point_cloud before calling this.
INTERFACE_API struct SL_InitParameters * sl_get_init_parameters(int camera_id)
Returns the initparameters used to open the ZED camera.
INTERFACE_API int sl_generate_unique_id(char *uuid)
Generate a UUID like unique ID to help identify and track AI detections.
INTERFACE_API int sl_mat_write(void *ptr, const char *file_path)
Writes the Mat into a file as an image. Only works if Mat has access to MEM_CPU.
INTERFACE_API int sl_mat_clone(void *ptr, void *ptr_source)
Duplicates a Mat by copying all its data into a new one (deep copy).
INTERFACE_API int sl_update_whole_mesh(int camera_id, int *nb_vertices, int *nb_triangles)
Updates the internal version of the whole mesh and returns the size of its data.
INTERFACE_API struct SL_ObjectDetectionParameters * sl_get_object_detection_parameters(int cmaera_id)
Returns the object detection parameters used. Correspond to the structure send when the enableObjectD...
INTERFACE_API int sl_retrieve_image(int camera_id, void *image_ptr, enum SL_VIEW type, enum SL_MEM mem, int width, int height)
Retrieves an image texture from the ZED SDK in a human-viewable format. Image textures work for when ...
INTERFACE_API int sl_mat_set_to_float(void *ptr, float value, enum SL_MEM mem)
INTERFACE_API int sl_mat_set_to_uchar2(void *ptr, struct SL_Uchar2 value, enum SL_MEM mem)
Returns the camera FPS.
INTERFACE_API int sl_ingest_custom_box_objects(int camera_id, int nb_objects, struct SL_CustomBoxObjectData *objects_in)
Feed the 3D Object tracking function with your own 2D bounding boxes from your own detection algorith...
INTERFACE_API int sl_get_position_array(int camera_id, float *pose, enum SL_REFERENCE_FRAME reference_frame)
Gets the position of the camera and the current state of the ZED Tracking as a float array (4x4).
INTERFACE_API int sl_mat_get_step(void *ptr, enum SL_MEM mem)
Gets the memory 'step' in number/length of elements - how many values make up each row of pixels.
INTERFACE_API int sl_mat_update_cpu_from_gpu(void *ptr)
Copies data from the GPU to the CPU, if possible.
Gets the value of a given setting from the ZED camera.
Destroys the camera and disable the textures.
INTERFACE_API struct SL_StreamingParameters * sl_get_streaming_parameters(int camera_id)
Returns the streaming parameters used. Correspond to the structure send when the sl_enable_streaming(...
Resets the tracking with an offset.
INTERFACE_API void sl_mat_swap(void *ptr_1, void *ptr_2)
Swaps the content of the provided Mat (only swaps the pointers, no data copy).
INTERFACE_API int sl_mat_get_width(void *ptr)
Gets the Width of the matrix.
INTERFACE_API int sl_mat_get_data_type(void *ptr)
Gets the type of data (Mat_Type).
INTERFACE_API int sl_mat_set_value_uchar2(void *ptr, int col, int row, struct SL_Uchar2 value, enum SL_MEM mem)
INTERFACE_API bool sl_apply_texture(int camera_id, int *nb_vertices_per_submesh, int *nb_triangles_per_submesh, int *nb_updated_submeshes, int *updated_indices, int *nb_vertices_tot, int *nb_triangles_tot, int *textures_size, const int max_submesh)
Applies the scanned texture onto the internal scanned mesh.
INTERFACE_API int sl_mat_set_from(void *ptr, void *ptr_source, enum SL_COPY_TYPE copy_type)
Copies data from another Mat into this one(deep copy).
INTERFACE_API bool sl_mat_is_init(void *ptr)
Tells if the Mat has been initialized.
Performs an hardware reset of the ZED 2 / ZED 2i.
Disables the Object Detection process.
INTERFACE_API struct SL_PlaneData * sl_find_floor_plane(int camera_id, struct SL_Quaternion *reset_quaternion, struct SL_Vector3 *reset_translation, struct SL_Quaternion prior_rotation, struct SL_Vector3 prior_translation)
Looks for a plane in the visible area that is likely to represent the floor.
INTERFACE_API int sl_mat_set_to_float3(void *ptr, struct SL_Vector3 value, enum SL_MEM mem)
Gets the full Sensor data from the ZED-M/ZED2/ZED2i. Returns an error is using ZED (v1) which does no...
INTERFACE_API int sl_update_objects_batch(int camera_id, int *nb_batches)
Updates the internal batch of detected objects.
Gets the depth min value from InitParameters (see SL_InitParameters::depth_minimum_distance).
Returns the state of the spatial memory export process.
Resets the tracking, and re-initializes the position with the given pose.
INTERFACE_API struct SL_RecordingStatus * sl_get_recording_status(int camera_id)
Get the recording information.
Returns the height of the current image.
Gets the ZED mcu Current Firmware version.
INTERFACE_API void sl_get_streaming_device_list(struct SL_StreamingProperties streaming_device_list[MAX_CAMERA_PLUGIN], int *nb_devices)
List all the streaming devices with their associated information.
INTERFACE_API int sl_mat_set_value_uchar4(void *ptr, int col, int row, struct SL_Uchar4 value, enum SL_MEM mem)
INTERFACE_API int sl_mat_set_to_float2(void *ptr, struct SL_Vector2 value, enum SL_MEM mem)
INTERFACE_API bool sl_filter_whole_mesh(int camera_id, enum SL_MESH_FILTER filter_params, int *nb_vertices, int *nb_triangles)
INTERFACE_API bool sl_apply_whole_texture(int camera_id, int *nb_vertices, int *nb_triangles, int *texture_size)
INTERFACE_API int sl_mat_set_value_uchar3(void *ptr, int col, int row, struct SL_Uchar3 value, enum SL_MEM mem)
Gets the current position of the camera and state of the tracking, filling a PoseData struck useful f...
Forces unload of one instance.
INTERFACE_API struct SL_Resolution sl_mat_get_resolution(void *ptr)
Returns the resolution of the image that this Mat holds.
INTERFACE_API int sl_mat_update_gpu_from_cpu(void *ptr)
Copies data from the CPU to the GPU, if possible.
INTERFACE_API struct SL_SensorsConfiguration * sl_get_sensors_configuration(int camera_id)
Gets the Sensors configuration.
INTERFACE_API int sl_mat_set_to_uchar3(void *ptr, struct SL_Uchar3 value, enum SL_MEM mem)
INTERFACE_API int sl_set_roi_for_aec_agc(int camera_id, enum SL_SIDE side, struct SL_Rect *roi, bool reset)
Sets the region of interest for automatic exposure/gain computation.
Extracts the current spatial map from the spatial mapping process.
INTERFACE_API int sl_retrieve_objects(int camera_id, struct SL_ObjectDetectionRuntimeParameters *object_detection_runtime_parameters, struct SL_Objects *objects)
Retrieve objects detected by the object detection module.
INTERFACE_API int sl_open_camera(int camera_id, struct SL_InitParameters *init_parameters, const char *path_svo, const char *ip, int stream_port, const char *output_file, const char *opt_settings_path, const char *opencv_calib_path)
Opens the camera depending on the init parameters.
INTERFACE_API bool sl_save_point_cloud(int c_id, const char *filename, enum SL_MESH_FILE_FORMAT format)
Saves the scanned point cloud in a specific file format.
INTERFACE_API int sl_update_mesh(int camera_id, int *nb_vertices_per_submesh, int *nb_triangles_per_submesh, int *nb_submeshes, int *updated_indices, int *nb_vertices_tot, int *nb_triangles_tot, const int max_submesh)
INTERFACE_API int sl_mat_get_pixel_bytes(void *ptr)
Gets the size in bytes of one pixel.
INTERFACE_API int sl_mat_set_value_uchar(void *ptr, int col, int row, unsigned char value, enum SL_MEM mem)
INTERFACE_API int sl_mat_get_value_uchar2(void *ptr, int col, int row, struct SL_Uchar2 *value, enum SL_MEM mem)
Gets the depth max value from InitParameters (see SL_InitParameters::depth_maximum_distance).
Returns the mesh generation status. Useful for knowing when to update and retrieve the mesh.
Gets the Camera-created CUDA context for sharing it with other CUDA-capable libraries.
Checks usb devices connected. param device : type of device to find.
Get the Timestamp at the time the frame has been extracted from USB stream. (should be called after a...
INTERFACE_API int sl_convert_hitplane_to_mesh(int camera_id, float *vertices, int *triangles, int *nb_vertices_tot, int *nb_triangles_tot)
Using data from a detected hit plane, updates supplied vertex and triangles arrays with data needed t...
INTERFACE_API int sl_mat_set_to_float4(void *ptr, struct SL_Vector4 value, enum SL_MEM mem)
Gets the ZED Serial Number.
INTERFACE_API int sl_convert_image(void *image_in_ptr, void *image_signed_ptr, cudaStream_t stream)
Convert Image format from Unsigned char to Signed char, designed for Unreal Engine pipeline,...
Gets the input type (see SL_INPUT_TYPE).
INTERFACE_API int sl_mat_get_step_bytes(void *ptr, enum SL_MEM mem)
Gets the memory 'step' in bytes - how many bytes make up each row of pixels.
Creates a streaming pipeline.
Get the current Timestamp at the time the function is called. Can be compared to the camera Timestamp...
Optimize the requested model, possible download if the model is not present on the host.
INTERFACE_API int sl_retrieve_chunks(int camera_id, float *vertices, int *triangles, float *uvs, unsigned char *texture_ptr, const int max_submesh)
Retrieves all chunks of the full mesh. Call update_mesh before calling this. Vertex and triangles arr...
INTERFACE_API int sl_mat_get_height(void *ptr)
Gets the Height of the matrix.
INTERFACE_API int sl_retrieve_measure(int camera_id, void *measure_ptr, enum SL_MEASURE type, enum SL_MEM mem, int width, int height)
Retrieves a measure texture from the ZED SDK. Use this to get an individual texture from the last gra...
INTERFACE_API int sl_convert_floorplane_to_mesh(int camera_id, float *vertices, int *triangles, int *nb_vertices_tot, int *nb_triangles_tot)
Using data from a detected floor plane, updates supplied vertex and triangles arrays with data needed...
Grabs the lastest images from the camera.
INTERFACE_API int sl_mat_get_value_float2(void *ptr, int col, int row, struct SL_Vector2 *value, enum SL_MEM mem)
INTERFACE_API int sl_enable_spatial_mapping(int camera_id, struct SL_SpatialMappingParameters *mapping_param)
Initializes and begins the spatial mapping processes.
Gets the IMU to Left camera transform matrix.
Sets a prior to the IMU orientation (using a ZED-mini, ZED2 or ZED2i). Prior must come from a externa...
INTERFACE_API int sl_mat_set_value_float2(void *ptr, int col, int row, struct SL_Vector2 value, enum SL_MEM mem)
Performs a new self calibration process. In some cases, due to temperature changes or strong vibratio...
Gets the number of zed connected.
Returns the width of the current image.
Sets the playback cursor to the desired frame number in the SVO file. This function allows you to mov...
INTERFACE_API int sl_set_region_of_interest(int camera_id, void *roi_mask)
Defines a region of interest to focus on for all the SDK, discarding other parts.
Gets the current state of spatial mapping.
INTERFACE_API void * sl_mat_create_new_empty()
Creates an empty Mat with the given resolution.
