Designed to contain rotation data of the positional tracking. It inherits from the generic Matrix3f. More...
Functions | |
| Rotation () | |
| empty Rotation default constructor. More... | |
| Rotation (const Rotation &rotation) | |
| Rotation copy constructor (deep copy). More... | |
| Rotation (const Matrix3f &mat) | |
| Rotation (const Orientation &orientation) | |
| Rotation constructor from an Orientation. More... | |
| Rotation (const float angle, const Translation &axis) | |
| Creates a Rotation representing the 3D rotation of angle around an arbitrary 3D axis. More... | |
| void | setOrientation (const Orientation &orientation) |
| Sets the Rotation from an Orientation. More... | |
| Orientation | getOrientation () const |
| Returns the Orientation corresponding to the current Rotation. More... | |
| float3 | getRotationVector () |
| Returns the 3x1 rotation vector obtained from 3x3 rotation matrix using Rodrigues formula. More... | |
| void | setRotationVector (const float3 &vec_rot) |
| Sets the Rotation from a rotation vector (using Rodrigues' transformation). More... | |
| float3 | getEulerAngles (bool radian=true) const |
| Converts the Rotation as Euler angles. More... | |
| void | setEulerAngles (const float3 &euler_angles, bool radian=true) |
| Sets the Rotation from the Euler angles. More... | |
| Matrix3f | operator* (const Matrix3f &mat) const |
| Gives the result of the multiplication between two Matrix3f. More... | |
| Matrix3f | operator* (const float &scalar) const |
| Gives the result of the multiplication between a Matrix3f and a scalar. More... | |
| Matrix3f | operator+ (const Matrix3f &mat) const |
| Gives the result of the addition between two Matrix3f. More... | |
| Matrix3f | operator+ (const float &scalar) const |
| Gives the result of the addition between a Matrix3f and a scalar. More... | |
| Matrix3f | operator- (const Matrix3f &mat) const |
| Gives the result of the subtraction between two Matrix3f. More... | |
| Matrix3f | operator- (const float &scalar) const |
| Gives the result of the subtraction between a Matrix3f and a scalar. More... | |
| bool | operator== (const Matrix3f &mat) const |
| Test two Matrix3f equality. More... | |
| bool | operator!= (const Matrix3f &mat) const |
| Test two Matrix3f inequality. More... | |
| float & | operator() (int u, int v) |
| Gets access to a specific point in the Matrix3f (read / write). More... | |
| void | inverse () |
| Sets the Matrix3f to its inverse. More... | |
| void | transpose () |
| Sets the Matrix3f to its transpose. More... | |
| void | setIdentity () |
| Sets the Matrix3f to identity. More... | |
| void | setZeros () |
| Sets the Matrix3f to zero. More... | |
| String | getInfos () |
| Returns the components of the Matrix3f in a String. More... | |
Static Functions | |
| static Matrix3f | inverse (const Matrix3f &rotation) |
| Returns the inverse of a Matrix3f. More... | |
| static Matrix3f | transpose (const Matrix3f &rotation) |
| Returns the transpose of a Matrix3f. More... | |
| static Matrix3f | identity () |
| Creates an identity Matrix3f. More... | |
| static Matrix3f | zeros () |
| Creates a Matrix3f filled with zeros. More... | |
Attributes | |
| String | matrix_name |
| Name of the matrix (optional). More... | |
| mat | : the mat to copy. |
| Rotation | ( | const Orientation & | orientation | ) |
It converts the Orientation representation to the Rotation one.
| orientation | : the Orientation to be used. |
| Rotation | ( | const float | angle, |
| const Translation & | axis | ||
| angle | : the rotation angle in rad. |
| axis | : the 3D axis to rotate around. |
| void setOrientation | ( | const Orientation & | orientation | ) |
| orientation | : the Orientation containing the rotation to set. |
| Orientation getOrientation | ( | ) | const |
| float3 getRotationVector | ( | ) |
| void setRotationVector | ( | const float3 & | vec_rot | ) |
| vec_rot | : the rotation Vector. |
| float3 getEulerAngles | ( | bool | radian = true | ) | const |
| void setEulerAngles | ( | const float3 & | euler_angles, |
inherited |
inherited |
inherited |
inherited |
| u | : specify the row |
| v | : specify the column |
inherited |
inherited |
inherited |
staticinherited |
inherited |
staticinherited |
inherited |
inherited |
