Translation Class Reference
Designed to contain translation data of the positional tracking. More...
 Translation ()
 empty Translation default constructor. More...
 Translation (const Translation &translation)
 Translation copy constructor (deep copy). More...
 Translation (float t1, float t2, float t3)
 Translation constructor. More...
 Translation (float3 in)
Translation operator* (const Orientation &mat) const
 Multiplication operator by an Orientation. More...
void normalize ()
 Normalizes the current translation. More...
float & operator() (int x)
 Get the value at specific position in the Translation. More...
_FCT_CPU_GPU_ int size () const
_FCT_CPU_GPU_ const float * ptr () const
_FCT_CPU_GPU_ Vector3< float > & setValues (const float *b)
_FCT_CPU_GPU_ float & operator[] (int i)
_FCT_CPU_GPU_ float norm ()
 returns the norm of the vector More...
_FCT_CPU_GPU_ float square ()
 returns the squared norm of the vector More...
_FCT_CPU_GPU_ float sum ()
 returns the sum of the vector More...
Static Functions
static Translation normalize (const Translation &tr)
 Get the normalized version of a given Translation. More...
static _FCT_CPU_GPU_ float dot (const Vector3< float > &a, const Vector3< float > &b)
 returns the dot product of two vector More...
static _FCT_CPU_GPU_ float distance (const Vector3< float > &a, const Vector3< float > &b)
 returns the distance between two vector More...
static _FCT_CPU_GPU_ Vector3< float > cross (const Vector3< float > &a, const Vector3< float > &b)
 returns the cross product between two vector More...
Translation is a vector as [tx, ty, tz]. You can access the data with the 't' ptr or by element name as : tx, ty, tz <-> | 0 1 2 |
Constructor and Destructor
◆ Translation() [1/4]
◆ Translation() [2/4]
Translation ( const Translation translation)
Parameters
translation: the Translation to copy.
◆ Translation() [3/4]
Translation ( float  t1,
float  t2,
float  t3
Parameters
t1: the x translation.
t2: the y translation.
t3: the z translation.
◆ Translation() [4/4]
Parameters
in: vector.
◆ operator*()
Translation operator* ( const Orientation mat) const
Parameters
mat: Orientation.
Returns
The current Translation after being multiplied by the orientation.
◆ normalize() [1/2]
void normalize ( )
◆ normalize() [2/2]
static Translation normalize ( const Translation tr)
static
Parameters
tr: the Translation to be used.
Returns
An other Translation object, which is equal to tr.normalize.
◆ operator()()
float& operator() ( int  x)
Parameters
x: the position of the value
Returns
The value at the x position.
◆ size()
_FCT_CPU_GPU_ int size ( ) const
inlineinherited
◆ ptr()
_FCT_CPU_GPU_ const float * ptr ( ) const
inlineinherited
◆ setValues()
_FCT_CPU_GPU_ Vector3<float >& setValues ( const float *  b)
inlineinherited
◆ operator[]()
_FCT_CPU_GPU_ float & operator[] ( int  i)
inlineinherited
◆ norm()
_FCT_CPU_GPU_ float norm ( )
inlineinherited
◆ square()
_FCT_CPU_GPU_ float square ( )
inlineinherited
◆ sum()
_FCT_CPU_GPU_ float sum ( )
inlineinherited
◆ dot()
static _FCT_CPU_GPU_ float dot ( const Vector3< float > &  a,
const Vector3< float > &  b
inlinestaticinherited
◆ distance()
static _FCT_CPU_GPU_ float distance ( const Vector3< float > &  a,
◆ cross()
static _FCT_CPU_GPU_ Vector3<float > cross ( const Vector3< float > &  a,
