Represents a generic 3*3 matrix. More...
Functions | |
Matrix3f () | |
Matrix3f default constructor. More... | |
Matrix3f (float data[]) | |
Matrix3f copy constructor (deep copy). More... | |
Matrix3f (const Matrix3f &mat) | |
Matrix3f | operator* (const Matrix3f &mat) const |
Gives the result of the multiplication between two Matrix3f. More... | |
Matrix3f | operator* (const float &scalar) const |
Gives the result of the multiplication between a Matrix3f and a scalar. More... | |
Matrix3f | operator+ (const Matrix3f &mat) const |
Gives the result of the addition between two Matrix3f. More... | |
Matrix3f | operator+ (const float &scalar) const |
Gives the result of the addition between a Matrix3f and a scalar. More... | |
Matrix3f | operator- (const Matrix3f &mat) const |
Gives the result of the subtraction between two Matrix3f. More... | |
Matrix3f | operator- (const float &scalar) const |
Gives the result of the subtraction between a Matrix3f and a scalar. More... | |
bool | operator== (const Matrix3f &mat) const |
Test two Matrix3f equality. More... | |
bool | operator!= (const Matrix3f &mat) const |
Test two Matrix3f inequality. More... | |
float & | operator() (int u, int v) |
Gets access to a specific point in the Matrix3f (read / write). More... | |
void | inverse () |
Sets the Matrix3f to its inverse. More... | |
void | transpose () |
Sets the Matrix3f to its transpose. More... | |
void | setIdentity () |
Sets the Matrix3f to identity. More... | |
void | setZeros () |
Sets the Matrix3f to zero. More... | |
String | getInfos () |
Returns the components of the Matrix3f in a String. More... | |
Static Functions | |
static Matrix3f | inverse (const Matrix3f &rotation) |
Returns the inverse of a Matrix3f. More... | |
static Matrix3f | transpose (const Matrix3f &rotation) |
Returns the transpose of a Matrix3f. More... | |
static Matrix3f | identity () |
Creates an identity Matrix3f. More... | |
static Matrix3f | zeros () |
Creates a Matrix3f filled with zeros. More... | |
Attributes | |
String | matrix_name |
Name of the matrix (optional). More... | |
It is defined in a row-major order, it means that, in the value buffer, the entire first row is stored first, followed by the entire second row, and so on. You can access the data with the 'r' ptr or by element attribute.
r00 | r01 | r02 |
r10 | r11 | r12 |
r20 | r21 | r22 |
Matrix3f operator* | ( | const float & | scalar | ) | const |
Matrix3f operator+ | ( | const float & | scalar | ) | const |
Matrix3f operator- | ( | const float & | scalar | ) | const |
float& operator() | ( | int | u, |
int | v | ||
u | : specify the row |
v | : specify the column |
void inverse | ( | ) |
void transpose | ( | ) |
void setIdentity | ( | ) |
static |
void setZeros | ( | ) |
static |
String getInfos | ( | ) |
String matrix_name |
