Orientation Class Reference
Designed to contain orientation (quaternion) data of the positional tracking. More...
 Orientation ()
 empty Orientation default constructor. More...
 Orientation (const Orientation &orientation)
 Orientation copy constructor (deep copy). More...
 Orientation (const float4 &in)
 Orientation (const Rotation &rotation)
 Orientation constructor from an Rotation. More...
 Orientation (const Translation &tr1, const Translation &tr2)
 Orientation constructor from a vector represented by two Translation. More...
float operator() (int x)
 Returns the value at specific position in the Orientation. More...
Orientation operator* (const Orientation &orientation) const
 Multiplication operator by an Orientation. More...
void setRotationMatrix (const Rotation &rotation)
 Sets the orientation from a Rotation. More...
Rotation getRotationMatrix () const
 Returns the current orientation as a Rotation. More...
void setIdentity ()
 Sets the current Orientation to identity. More...
void setZeros ()
 Fills the current Orientation with zeros. More...
void normalise ()
 Normalizes the current Orientation. More...
_FCT_CPU_GPU_ int size () const
_FCT_CPU_GPU_ const float * ptr () const
_FCT_CPU_GPU_ Vector4< float > & setValues (const float *b)
_FCT_CPU_GPU_ float & operator[] (int i)
_FCT_CPU_GPU_ const float & operator[] (int i) const
_FCT_CPU_GPU_ float norm ()
 returns the norm of the vector More...
_FCT_CPU_GPU_ float square ()
 returns the squared norm of the vector More...
_FCT_CPU_GPU_ float sum ()
 returns the sum of the vector More...
Static Functions
static Orientation identity ()
 Creates an Orientation initialized to identity. More...
static Orientation zeros ()
 Creates an Orientation filled with zeros. More...
static Orientation normalise (const Orientation &orient)
 Creates the normalized version of an existing Orientation. More...
static _FCT_CPU_GPU_ float dot (const Vector4< float > &a, const Vector4< float > &b)
 returns the dot product of two vector More...
static _FCT_CPU_GPU_ float distance (const Vector4< float > &a, const Vector4< float > &b)
 returns the distance between two vector More...
Orientation is a vector defined as [ox, oy, oz, ow].
Constructor and Destructor
◆ Orientation() [1/5]
◆ Orientation() [2/5]
Orientation ( const Orientation orientation)
Parameters
orientation: the Orientation to copy.
◆ Orientation() [3/5]
Orientation ( const float4 in)
Parameters
in: the vector to copy.
Set in the following order : [ox, oy, oz, ow].
◆ Orientation() [4/5]
Orientation ( const Rotation rotation)
It converts the Rotation representation to the Orientation one.
Parameters
rotation: the Rotation to be used.
◆ Orientation() [5/5]
Orientation ( const Translation tr1,
const Translation tr2
Parameters
tr1: the first point of the vector.
tr2: the second point of the vector.
◆ operator()()
float operator() ( int  x)
Parameters
x: the position of the value
Returns
The value at the x position.
◆ operator*()
Orientation operator* ( const Orientation orientation) const
Parameters
orientation: the orientation.
Returns
The current orientation after being multiplied by the other orientation.
◆ setRotationMatrix()
void setRotationMatrix ( const Rotation rotation)
Parameters
◆ getRotationMatrix()
Rotation getRotationMatrix ( ) const
Returns
The rotation computed from the orientation data.
◆ setIdentity()
void setIdentity ( )
◆ identity()
static Orientation identity ( )
static
Returns
An identity Orientation.
◆ setZeros()
void setZeros ( )
◆ zeros()
static Orientation zeros ( )
static
Returns
An Orientation filled with zeros.
◆ normalise() [1/2]
void normalise ( )
◆ normalise() [2/2]
static Orientation normalise ( const Orientation orient)
static
Parameters
orient: the Orientation to be used.
Returns
The normalized version of the Orientation.
◆ size()
_FCT_CPU_GPU_ int size ( ) const
inlineinherited
◆ ptr()
_FCT_CPU_GPU_ const float * ptr ( ) const
inlineinherited
◆ setValues()
_FCT_CPU_GPU_ Vector4<float >& setValues ( const float *  b)
inlineinherited
◆ operator[]() [1/2]
_FCT_CPU_GPU_ float & operator[] ( int  i)
inlineinherited
◆ operator[]() [2/2]
_FCT_CPU_GPU_ const float & operator[] ( int  i) const
inlineinherited
◆ norm()
_FCT_CPU_GPU_ float norm ( )
inlineinherited
◆ square()
_FCT_CPU_GPU_ float square ( )
inlineinherited
◆ sum()
_FCT_CPU_GPU_ float sum ( )
inlineinherited
◆ dot()
static _FCT_CPU_GPU_ float dot ( const Vector4< float > &  a,
const Vector4< float > &  b
inlinestaticinherited
◆ distance()
static _FCT_CPU_GPU_ float distance ( const Vector4< float > &  a,
