Pose Class Reference
Contains positional tracking data which gives the position and orientation of the ZED in 3D space. More...
 Pose ()
 Default constructor which creates an empty Pose (identity). More...
 Pose (const Pose &pose)
 Pose constructor with deep copy. More...
 Pose (const Transform &pose_data, unsigned long long timestamp=0, int confidence=0)
 ~Pose ()
 Pose destructor. More...
Translation getTranslation ()
 Returns the translation from the pose. More...
Orientation getOrientation ()
 Returns the orientation from the pose. More...
Rotation getRotationMatrix ()
 Returns the rotation (3x3) from the pose. More...
float3 getRotationVector ()
 Returns the rotation (3x1 rotation vector obtained from 3x3 rotation matrix using Rodrigues formula) from the pose. More...
float3 getEulerAngles (bool radian=true)
 Convert the Rotation of the Transform as Euler angles. More...
Attributes
Transform pose_data
 4x4 Matrix which contains the rotation (3x3) and the translation. Orientation is extracted from this transform as well. More...
sl::Timestamp timestamp
 Timestamp of the pose. This timestamp should be compared with the camera timestamp for synchronization. More...
int pose_confidence
 Confidence / Quality of the pose estimation for the target frame.
A confidence metric of the tracking [0-100], 0 means that the tracking is lost, 100 means that the tracking can be fully trusted. More...
float pose_covariance [36]
 6x6 Pose covariance of translation (the first 3 values) and rotation in so3 (the last 3 values) More...
bool valid
 Boolean that indicates if tracking is activated or not. You should check that first if something wrong. More...
float twist [6]
 Twist of the camera available in reference camera, this expresses velocity in free space, broken into its linear and angular parts. More...
float twist_covariance [36]
 Row-major representation of the 6x6 twist covariance matrix of the camera, this expresses the uncertainty of the twist. More...
Different representations of position and orientation can be retrieved, along with timestamp and pose confidence.
Constructor and Destructor
◆ Pose() [1/3]
Pose ( )
◆ Pose() [2/3]
Pose ( const Pose pose)
◆ Pose() [3/3]
Pose ( const Transform pose_data,
unsigned long long  timestamp = 0,
int  confidence = 0
◆ ~Pose()
~Pose ( )
Pose destructor.
◆ getTranslation()
Translation getTranslation ( )
Returns
The (3x1) translation vector.
◆ getOrientation()
Orientation getOrientation ( )
Returns
The (4x1) orientation vector.
◆ getRotationMatrix()
Rotation getRotationMatrix ( )
Returns
The (3x3) rotation matrix.
◆ getRotationVector()
float3 getRotationVector ( )
Returns
The (3x1) rotation vector.
◆ getEulerAngles()
float3 getEulerAngles ( bool  radian = true)
Parameters
radian: Define if the angle in is radian or degree. default : true.
Returns
The Euler angles, as a float3 representing the rotations around the X, Y and Z axes. (YZX convention)
Variables
◆ pose_data
Transform pose_data
◆ timestamp
◆ pose_confidence
int pose_confidence
◆ pose_covariance
float pose_covariance[36]
◆ valid
bool valid
◆ twist
float twist[6]
◆ twist_covariance
float twist_covariance[36]
