Video Module
Classes
struct  RecordingStatus
 Recording structure that contains information about SVO. More...
class  InitParameters
 Holds the options used to initialize the Camera object.
Once passed to the Camera::open() function, these settings will be set for the entire execution life time of the Camera.
You can get further information in the detailed description bellow.
. More...
class  StreamingParameters
 Sets the streaming parameters. More...
class  RecordingParameters
 Sets the recording parameters. More...
class  Camera
 This class is the main interface with the camera and the SDK features, such as: video, depth, tracking, mapping and more.
Find more information in the detailed description below. A standard program will use the Camera class like this: More...
struct  DeviceProperties
 Properties of a camera. More...
struct  StreamingProperties
 Properties of a streaming device. More...
class  InputType
 Defines the input type used in the ZED SDK. Can be used to select a specific camera with ID or serial number, or a svo file. More...
Enumerations
enum class  SIDE
 defines left,right,both to distinguish between left and right or both sides More...
enum  FLIP_MODE : int
 Gives the camera flip mode. More...
enum class  RESOLUTION
 Represents the available resolution defined in the cameraResolution list. More...
enum class  VIDEO_SETTINGS
 Lists available camera settings for the ZED camera (contrast, hue, saturation, gain...). More...
enum class  VIEW
 Lists available views. More...
enum class  TIME_REFERENCE
 Lists specific and particular timestamps. More...
enum class  SVO_COMPRESSION_MODE
 Lists available compression modes for SVO recording. More...
enum class  MODEL
 Lists compatible ZED Camera model. More...
enum class  INPUT_TYPE
 Lists available input type in SDK. More...
enum class  CAMERA_STATE
 List of possible camera state. More...
enum class  STREAMING_CODEC
sl::Resolution getResolution (RESOLUTION resolution)
 Returns the actual size of the given resolution. More...
String toVerbose (const ERROR_CODE &errorCode)
 Return a text explaining how to fix the given ERROR_CODE. More...
◆ SIDE
enum SIDE
strong
Enumerator
LEFT
Left side only.
RIGHT
Right side only.
BOTH
Left and Right side.
◆ FLIP_MODE
Enumerator
OFF
default behavior.
ON
Images and camera sensors data are flipped useful when your camera is mounted upside down.
AUTO
Live mode: use the camera orientation (if an IMU is available) to set the flip mode. SVO mode: read the state of this enum when recorded.
◆ RESOLUTION
enum RESOLUTION
strong
Note
The VGA resolution does not respect the 640*480 standard to better fit the camera sensor (672*376 is used).
Enumerator
HD2K
2208*1242 (x2), available framerates: 15 fps.
HD1080
1920*1080 (x2), available framerates: 15, 30 fps.
HD720
1280*720 (x2), available framerates: 15, 30, 60 fps.
VGA
672*376 (x2), available framerates: 15, 30, 60, 100 fps.
◆ VIDEO_SETTINGS
enum VIDEO_SETTINGS
strong
Warning
GAIN and EXPOSURE are linked in auto/default mode (see sl::Camera::setCameraSettings).
Each enum defines one of those settings.
Enumerator
BRIGHTNESS
Defines the brightness control. Affected value should be between 0 and 8.
CONTRAST
Defines the contrast control. Affected value should be between 0 and 8.
HUE
Defines the hue control. Affected value should be between 0 and 11.
SATURATION
Defines the saturation control. Affected value should be between 0 and 8.
SHARPNESS
Defines the digital sharpening control. Affected value should be between 0 and 8.
GAMMA
Defines the ISP gamma control. Affected value should be between 1 and 9.
GAIN
Defines the gain control. Affected value should be between 0 and 100 for manual control.
EXPOSURE
Defines the exposure control. Affected value should be between 0 and 100 for manual control.
The exposition is mapped linearly in a percentage of the following max values. Special case for the setExposure(0) that corresponds to 0.17072ms.
The conversion to milliseconds depends on the framerate:
  • 15fps setExposure(100) -> 19.97ms
  • 30fps setExposure(100) -> 19.97ms
  • 60fps setExposure(100) -> 10.84072ms
  • 100fps setExposure(100) -> 10.106624ms
AEC_AGC
Defines if the Gain and Exposure are in automatic mode or not. Setting a Gain or Exposure through @GAIN or @EXPOSURE values will automatically set this value to 0.
AEC_AGC_ROI
Defines the region of interest for automatic exposure/gain computation. To be used with overloaded @setCameraSettings/@getCameraSettings functions.
WHITEBALANCE_TEMPERATURE
Defines the color temperature value. Setting a value will automatically set @WHITEBALANCE_AUTO to 0. Affected value should be between 2800 and 6500 with a step of 100.
WHITEBALANCE_AUTO
Defines if the White balance is in automatic mode or not
LED_STATUS
Defines the status of the camera front LED. Set to 0 to disable the light, 1 to enable the light. Default value is on. Requires Camera FW 1523 at least.
◆ VIEW
enum VIEW
strong
Enumerator
LEFT
Left BGRA image. Each pixel contains 4 unsigned char (B,G,R,A). sl::MAT_TYPE::U8_C4.
RIGHT
Right BGRA image. Each pixel contains 4 unsigned char (B,G,R,A). sl::MAT_TYPE::U8_C4.
LEFT_GRAY
Left GRAY image. Each pixel contains 1 unsigned char. sl::MAT_TYPE::U8_C1.
RIGHT_GRAY
Right GRAY image. Each pixel contains 1 unsigned char. sl::MAT_TYPE::U8_C1.
LEFT_UNRECTIFIED
Left BGRA unrectified image. Each pixel contains 4 unsigned char (B,G,R,A). sl::MAT_TYPE::U8_C4.
RIGHT_UNRECTIFIED
Right BGRA unrectified image. Each pixel contains 4 unsigned char (B,G,R,A). sl::MAT_TYPE::U8_C4.
LEFT_UNRECTIFIED_GRAY
Left GRAY unrectified image. Each pixel contains 1 unsigned char. sl::MAT_TYPE::U8_C1.
RIGHT_UNRECTIFIED_GRAY
Right GRAY unrectified image. Each pixel contains 1 unsigned char. sl::MAT_TYPE::U8_C1.
SIDE_BY_SIDE
Left and right image (the image width is therefore doubled). Each pixel contains 4 unsigned char (B,G,R,A). sl::MAT_TYPE::U8_C4.
DEPTH
Color rendering of the depth. Each pixel contains 4 unsigned char (B,G,R,A). sl::MAT_TYPE::U8_C4. Use MEASURE::DEPTH with Camera::retrieveMeasure() to get depth values.
CONFIDENCE
Color rendering of the depth confidence. Each pixel contains 4 unsigned char (B,G,R,A). sl::MAT_TYPE::U8_C4.
NORMALS
Color rendering of the normals. Each pixel contains 4 unsigned char (B,G,R,A). sl::MAT_TYPE::U8_C4.
DEPTH_RIGHT
Color rendering of the right depth mapped on right sensor. Each pixel contains 4 unsigned char (B,G,R,A). sl::MAT_TYPE::U8_C4.
NORMALS_RIGHT
Color rendering of the normals mapped on right sensor. Each pixel contains 4 unsigned char (B,G,R,A). sl::MAT_TYPE::U8_C4.
◆ TIME_REFERENCE
enum TIME_REFERENCE
strong
Enumerator
Defines the timestamp at the time the frame has been extracted from USB stream.
CURRENT
Defines the timestamp at the time of the function call.
◆ SVO_COMPRESSION_MODE
enum SVO_COMPRESSION_MODE
strong
sl::SVO_COMPRESSION_MODE::LOSSLESS is an improvement of previous lossless compression (used in ZED Explorer), even if size may be bigger, compression time is much faster.
Enumerator
LOSSLESS
PNG/ZSTD (lossless) CPU based compression : avg size = 42% (of RAW).
H264
H264(AVCHD) GPU based compression : avg size = 1% (of RAW). Requires a NVIDIA GPU
H265
H265(HEVC) GPU based compression: avg size = 1% (of RAW). Requires a NVIDIA GPU, Pascal architecture or newer
H264_LOSSLESS
H264 Lossless GPU/Hardware based compression: avg size = 25% (of RAW). Provides a SSIM/PSNR result (vs RAW) >= 99.9%. Requires a NVIDIA GPU
H265_LOSSLESS
H265 Lossless GPU/Hardware based compression: avg size = 25% (of RAW). Provides a SSIM/PSNR result (vs RAW) >= 99.9%. Requires a NVIDIA GPU
◆ MODEL
enum MODEL
strong
Enumerator
ZED
Defines ZED Camera model
ZED_M
Defines ZED Mini (ZED-M) Camera model
ZED2
Defines ZED 2 Camera model
ZED2i
Defines ZED 2i Camera model
◆ INPUT_TYPE
enum INPUT_TYPE
strong
Enumerator
USB
USB input mode
SVO
SVO file input mode
STREAM
STREAM input mode (requires to use enableStreaming()/disableStreaming() on the "sender" side)
◆ CAMERA_STATE
enum CAMERA_STATE
strong
Enumerator
AVAILABLE
Defines if the camera can be opened by the SDK
NOT_AVAILABLE
Defines if the camera is already opened and unavailable
◆ STREAMING_CODEC
enum STREAMING_CODEC
strong
Enumerator
H264
AVCHD/H264 encoding used in image streaming.
H265
HEVC/H265 encoding used in image streaming.
Function Documentation
◆ getResolution()
sl::Resolution sl::getResolution ( RESOLUTION  resolution)
◆ toVerbose()
String sl::toVerbose ( const ERROR_CODE errorCode)
Returns
A string of advice for the user.
