StreamingParameters Class Reference
Sets the streaming parameters. More...
 StreamingParameters (STREAMING_CODEC codec_=STREAMING_CODEC::H265, unsigned short port_=30000, unsigned int bitrate_=8000, int gop_size_=-1, bool adaptative_bitrate_=false, unsigned short chunk_size_=32768, unsigned int target_framerate_=0)
 Default constructor. Set all parameters to their default values. More...
bool operator== (const StreamingParameters &param1) const
bool operator!= (const StreamingParameters &param1) const
Attributes
STREAMING_CODEC codec = STREAMING_CODEC::H265
 Defines the codec used for streaming. More...
unsigned short port = 30000
 Defines the port used for streaming. More...
unsigned int bitrate = 8000
 Defines the streaming bitrate in Kbits/s. More...
int gop_size = -1
 Defines the gop size in number of frames. More...
bool adaptative_bitrate = false
 Enable/Disable adaptive bitrate. More...
unsigned short chunk_size = 16084
 Defines a single chunk size. More...
unsigned int target_framerate = 0
 defines the target framerate for the streaming output. More...
Note
Parameters can be user adjusted.
Constructor and Destructor
◆ StreamingParameters()
StreamingParameters ( STREAMING_CODEC  codec_ = STREAMING_CODEC::H265,
unsigned short  port_ = 30000,
unsigned int  bitrate_ = 8000,
int  gop_size_ = -1,
bool  adaptative_bitrate_ = false,
unsigned short  chunk_size_ = 32768,
unsigned int  target_framerate_ = 0
◆ operator==()
bool operator== ( const StreamingParameters param1) const
Comparison operator ==
Parameters
StreamingParametersto compare
Returns
◆ operator!=()
bool operator!= ( const StreamingParameters param1) const
Comparison operator !=
Parameters
Returns
Variables
◆ codec
Warning
If HEVC is used, make sure the receiving host is compatible with H265 decoding (Pascal NVIDIA card or newer). If not, prefer to use H264 since every compatible NVIDIA card supports H264 decoding
◆ port
Warning
Port must be an even number. Any odd number will be rejected.
Port must be opened.
◆ bitrate
STREAMING_CODEC Resolution FPS bitrate (kbps)
H264 HD2K 15 8500
H264 HD1080 30 12500
H264 HD720 60 7000
H265 HD2K 15 7000
H265 HD1080 30 11000
H265 HD720 60 6000
Note
Available range : [1000 - 60000]
◆ gop_size
int gop_size = -1
Note
if value is set to -1, the gop size will last at maximum 2 seconds, depending on camera fps.
The gop size determines the maximum distance between IDR/I-frames. Very high GOP size will result in slightly more efficient compression, especially on static scenes. But latency will increase.
maximum value: 256
◆ adaptative_bitrate
Note
Bitrate will be adjusted depending the number of packet dropped during streaming.
if activated, bitrate can vary between [bitrate/4, bitrate]
Warning
Currently, the adaptive bitrate only works when "sending" device is a NVIDIA Jetson (X1,X2,Xavier,Nano)
◆ chunk_size
Note
Stream buffers are divided in X number of chunk where each chunk is "chunk_size" bytes long.
Default value is 16084. You can lower this value if network generates a lot of packet lost : this will generates more chunk for a single image, but each chunk sent will be lighter to avoid inside-chunk corruption. Increasing this value can decrease latency.
Available range : [4096 - 65000]
◆ target_framerate
Warning
This framerate must be below or equal to the camera framerate. Allowed framerates are 15,30, 60 or 100 if possible. Any other values will be discarded and camera FPS will be taken. \ndefault : 0, meaning that the camera framerate will be taken
