RecordingStatus Struct Reference
Recording structure that contains information about SVO. More...
 RecordingStatus ()
 Default constructor. Set all parameters to their default values. More...
Attributes
bool is_recording
bool is_paused
bool status
double current_compression_time
double current_compression_ratio
double average_compression_time
double average_compression_ratio
Constructor and Destructor
◆ RecordingStatus()
Variables
◆ is_recording
bool is_recording
Recorder status, true if enabled
◆ is_paused
bool is_paused
Recorder status, true if the pause is enabled
◆ status
bool status
Status of current frame. True for success or false if the frame couldn't be written in the SVO file.
◆ current_compression_time
Compression time for the current frame in ms.
◆ current_compression_ratio
Compression ratio (% of raw size) for the current frame.
◆ average_compression_time
Average compression time in ms since beginning of recording.
◆ average_compression_ratio
Average compression ratio (% of raw size) since beginning of recording.
