Sets the spatial mapping parameters. More...
Types | |
| enum class | SPATIAL_MAP_TYPE |
| Lists the types of spatial maps that can be created. More... | |
| enum class | MAPPING_RESOLUTION |
| Lists the spatial mapping resolution presets. More... | |
| enum class | MAPPING_RANGE |
| Lists the spatial mapping depth range presets. More... | |
| typedef std::pair< float, float > | interval |
Functions | |
| SpatialMappingParameters (MAPPING_RESOLUTION resolution=MAPPING_RESOLUTION::MEDIUM, MAPPING_RANGE range=MAPPING_RANGE::AUTO, int max_memory_usage_=2048, bool save_texture_=false, bool use_chunk_only_=false, bool reverse_vertex_order_=false, SPATIAL_MAP_TYPE map_type=SPATIAL_MAP_TYPE::MESH) | |
| Default constructor. Sets all parameters to their default and optimized values. More... | |
| void | set (MAPPING_RESOLUTION mapping_resolution=MAPPING_RESOLUTION::MEDIUM) |
| Sets the resolution corresponding to the given MAPPING_RESOLUTION preset. More... | |
| void | set (MAPPING_RANGE mapping_range=MAPPING_RANGE::MEDIUM) |
| Sets the maximum value of the depth corresponding to the given MAPPING_RANGE preset. More... | |
| bool | save (String filename) |
| Saves the current set of parameters into a file. More... | |
| bool | load (String filename) |
| Loads the values of the parameters contained in a file. More... | |
| bool | operator== (const SpatialMappingParameters ¶m1) const |
| bool | operator!= (const SpatialMappingParameters ¶m1) const |
Static Functions | |
| static float | get (MAPPING_RESOLUTION mapping_resolution=MAPPING_RESOLUTION::MEDIUM) |
| Returns the resolution corresponding to the given MAPPING_RESOLUTION preset. More... | |
| static float | get (MAPPING_RANGE mapping_range=MAPPING_RANGE::MEDIUM) |
| Returns the maximum value of depth corresponding to the given MAPPING_RANGE presets. More... | |
| static float | getRecommendedRange (MAPPING_RESOLUTION mapping_resolution, Camera &camera) |
| Returns the recommended maximum depth value for the given MAPPING_RESOLUTION preset. More... | |
| static float | getRecommendedRange (float resolution_meters, Camera &camera) |
| Returns the recommended maximum depth value for the given resolution in meters. More... | |
Attributes | |
| float | resolution_meter = 0.05f |
| Spatial mapping resolution in meters. Should fit allowed_resolution. More... | |
| float | range_meter = 0.f |
| Depth range in meters. Can be different from the value set by sl::InitParameters::depth_maximum_distance. Set to 0 by default. In this case, the range is computed from resolution_meter and from the current internal parameters to fit your application. More... | |
| bool | save_texture = false |
| Set to true if you want to be able to apply the texture to your mesh after its creation. More... | |
| bool | use_chunk_only = false |
| Set to false if you want to ensure consistency between the mesh and its inner chunk data. More... | |
| int | max_memory_usage = 2048 |
| The maximum CPU memory (in MB) allocated for the meshing process. More... | |
| bool | reverse_vertex_order = false |
| Specify if the order of the vertices of the triangles needs to be inverted. If your display process does not handle front and back face culling, you can use this to correct it. More... | |
| SPATIAL_MAP_TYPE | map_type = SPATIAL_MAP_TYPE::MESH |
| The type of spatial map to be created. This dictates the format that will be used for the mapping(e.g. mesh, point cloud). See SPATIAL_MAP_TYPE. More... | |
Static Attributes | |
| static const interval | allowed_resolution |
| The resolution allowed by the spatial mapping. allowed_resolution.first is the minimum value allowed. allowed_resolution.second is the maximum value allowed. More... | |
| static const interval | allowed_range |
| Range of the maximum depth value allowed by spatial mapping. allowed_range.first is the minimum value allowed. allowed_range.second is the maximum value allowed. More... | |
Instantiating with the default constructor will set all parameters to their default values.
You can customize these values to fit your application, and then save them to a preset to be loaded in future executions.
| typedef std::pair<float, float> interval |
| SpatialMappingParameters | ( | MAPPING_RESOLUTION | resolution = MAPPING_RESOLUTION::MEDIUM, |
| MAPPING_RANGE | range = MAPPING_RANGE::AUTO, |
| int | max_memory_usage_ = 2048, |
| bool | save_texture_ = false, |
| bool | use_chunk_only_ = false, |
| bool | reverse_vertex_order_ = false, |
static |
| mapping_resolution | The desired MAPPING_RESOLUTION. Default: MAPPING_RESOLUTION::MEDIUM. |
| void set | ( | MAPPING_RESOLUTION | mapping_resolution = MAPPING_RESOLUTION::MEDIUM | ) |
static |
| mapping_range | The desired MAPPING_RANGE. Default: MAPPING_RANGE::MEDIUM. |
| void set | ( | MAPPING_RANGE | mapping_range = MAPPING_RANGE::MEDIUM | ) |
static |
| mapping_resolution | The desired MAPPING_RESOLUTION. |
| camera | The Camera object that will run the spatial mapping. |
static |
| resolution_meters | The desired resolution in meters. |
| bool save | ( | String | filename | ) |
| filename | : the name of the file which will be created to store the parameters (extension '.yml' will be added if not set). |
| bool load | ( | String | filename | ) |
| filename | the path to the file from which the parameters will be loaded. |
| bool operator== | ( | const SpatialMappingParameters & | param1 | ) | const |
Comparison operator ==
| SpatialMappingParameters | to compare |
| bool operator!= | ( | const SpatialMappingParameters & | param1 | ) | const |
Comparison operator !=
| float resolution_meter = 0.05f |
static |
| float range_meter = 0.f |
static |
| bool save_texture = false |
| bool use_chunk_only = false |
| int max_memory_usage = 2048 |
| bool reverse_vertex_order = false |
| SPATIAL_MAP_TYPE map_type = SPATIAL_MAP_TYPE::MESH |
