DOCUMENTATION
SAMPLES
API REFERENCE
SUPPORT
DOWNLOADS
C++
Python
C#
C
SpatialMappingParameters Member List
This is the complete list of members for
, including all inherited members.
allowed_range
static
allowed_resolution
static
get
(MAPPING_RESOLUTION mapping_resolution=MAPPING_RESOLUTION::MEDIUM)
static
get
(MAPPING_RANGE mapping_range=MAPPING_RANGE::MEDIUM)
static
getRecommendedRange
(MAPPING_RESOLUTION mapping_resolution, Camera &camera)
static
getRecommendedRange
(float resolution_meters, Camera &camera)
static
interval
typedef
load
(String filename)
map_type
MAPPING_RANGE
enum name
MAPPING_RESOLUTION
enum name
max_memory_usage
operator!=
(const SpatialMappingParameters ¶m1) const
operator==
range_meter
resolution_meter
reverse_vertex_order
save
(String filename)
save_texture
set
set
SPATIAL_MAP_TYPE
enum name
(MAPPING_RESOLUTION resolution=MAPPING_RESOLUTION::MEDIUM, MAPPING_RANGE range=MAPPING_RANGE::AUTO, int max_memory_usage_=2048, bool save_texture_=false, bool use_chunk_only_=false, bool reverse_vertex_order_=false, SPATIAL_MAP_TYPE map_type=SPATIAL_MAP_TYPE::MESH)
use_chunk_only
