RuntimeParameters Class Reference
Parameters that defines the behavior of the grab. More...
 RuntimeParameters (SENSING_MODE sensing_mode_=SENSING_MODE::STANDARD, bool enable_depth_=true, int confidence_threshold_=100, int texture_confidence_threshold_=100, REFERENCE_FRAME measure3D_reference_frame_=REFERENCE_FRAME::CAMERA, bool remove_saturated_areas_=true)
 Default constructor, set all parameters to their default and optimized values. More...
bool save (String filename)
 Saves the current set of parameters into a file. More...
bool load (String filename)
 Loads the values of the parameters contained in a file. More...
bool operator== (const RuntimeParameters &param1) const
bool operator!= (const RuntimeParameters &param1) const
Attributes
bool enable_depth
int confidence_threshold = 100
int texture_confidence_threshold = 100
bool remove_saturated_areas = true
Default values are enabled.
You can customize it to fit your application and then save it to create a preset that can be loaded for further executions.
Constructor and Destructor
◆ RuntimeParameters()
RuntimeParameters ( SENSING_MODE  sensing_mode_ = SENSING_MODE::STANDARD,
bool  enable_depth_ = true,
int  confidence_threshold_ = 100,
int  texture_confidence_threshold_ = 100,
REFERENCE_FRAME  measure3D_reference_frame_ = REFERENCE_FRAME::CAMERA,
bool  remove_saturated_areas_ = true
◆ save()
bool save ( String  filename)
Parameters
filename: the name of the file which will be created to store the parameters (extension '.yml' will be added if not set).
Returns
true if the file was successfully saved, otherwise false.
Warning
For security reason, the file must not exist. In case a file already exists, Function will return false and existing file will not be updated.
◆ load()
bool load ( String  filename)
Parameters
filename: the path to the file from which the parameters will be loaded. (extension '.yml' will be added at the end of the filename if not detected).
Returns
true if the file was successfully loaded, otherwise false.
◆ operator==()
bool operator== ( const RuntimeParameters param1) const
Comparison operator ==
Parameters
RuntimeParametersto compare
Returns
◆ operator!=()
bool operator!= ( const RuntimeParameters param1) const
Comparison operator !=
Parameters
Returns
Variables
◆ sensing_mode
Defines the algorithm used for depth map computation, more info : SENSING_MODE definition.
default : SENSING_MODE::STANDARD
◆ measure3D_reference_frame
Provides 3D measures (point cloud and normals) in the desired reference frame (default is REFERENCE_FRAME::CAMERA)
default : REFERENCE_FRAME::CAMERA
◆ enable_depth
bool enable_depth
Defines if the depth map should be computed.
If false, only the images are available.
default : true
◆ confidence_threshold
Threshold to reject depth values based on their confidence.
Each depth pixel has a corresponding confidence. (MEASURE::CONFIDENCE), the confidence range is [1,100].
By default, the confidence threshold is set at 100, meaning that no depth pixel will be rejected.
Decreasing this value will remove depth data from both objects edges and low textured areas, to keep only confident depth estimation data. Pixels with a value close to 100 are not to be trusted. Accurate depth pixels tends to be closer to lower values. It can be seen as a probability of error, scaled to 100.
◆ texture_confidence_threshold
Threshold to reject depth values based on their texture confidence.
The texture confidence range is [1,100].
By default, the texture confidence threshold is set at 100, meaning that no depth pixel will be rejected.
Decreasing this value will remove depth data from image areas which are uniform. Pixels with a value close to 100 are not to be trusted. Accurate depth pixels tends to be closer to lower values.
◆ remove_saturated_areas
Defines if the saturated area (Luminance>=255) must be removed from depth map estimation
True by default
It is recommended to keep this parameter at true because saturated area can create false detection.
