CameraParameters Struct Reference
Intrinsic parameters of a camera. More...
Attributes
float fx
float fy
float cx
float cy
double disto [12]
float v_fov
float h_fov
float d_fov
Resolution image_size
That information about the camera will be returned by Camera::getCameraInformation().
Note
Similar to the CalibrationParameters, those parameters are taken from the settings file (SNXXX.conf) and are modified during the sl::Camera::open call when running a self-calibration). Those parameters given after sl::Camera::open call, represent the camera matrix corresponding to rectified or unrectified images.
When filled with rectified parameters, fx,fy,cx,cy must be the same for Left and Right Camera once sl::Camera::open has been called. Since distortion is corrected during rectification, distortion should not be considered on rectified images.
Variables
◆ fx
float fx
Focal length in pixels along x axis.
◆ fy
float fy
Focal length in pixels along y axis.
◆ cx
float cx
Optical center along x axis, defined in pixels (usually close to width/2).
◆ cy
float cy
Optical center along y axis, defined in pixels (usually close to height/2).
◆ disto
double disto[12]
Distortion factor : [ k1, k2, p1, p2, k3, k4, k5, k6, s1, s2, s3, s4]. Radial (k1, k2, k3, k4, k5, k6), Tangential (p1,p2) and Prism (s1, s2, s3, s4) distortion.
◆ v_fov
float v_fov
Vertical field of view, in degrees.
◆ h_fov
float h_fov
Horizontal field of view, in degrees.
◆ d_fov
float d_fov
Diagonal field of view, in degrees.
◆ image_size
