All Classes Namespaces Functions Variables Enumerations Enumerator Properties Modules Pages
SensorParameters
Structure containing information about a single sensor available in the current device More...
Attributes
SENSOR_TYPE type
 The type of the sensor as DEVICE_SENSORS. More...
float resolution
 The resolution of the sensor. More...
float sampling_rate
 The sampling rate (or ODR) of the sensor. More...
float2 range
 The range values of the sensor. MIN: range.x, MAX: range.y More...
float noise_density
 also known as white noise, given as continous (frequency independant). Units will be expressed in sensor_unit/√(Hz). NAN if the information is not available. More...
float random_walk
 derived from the Allan Variance, given as continous (frequency independant). Units will be expressed in sensor_unit/s/√(Hz).NAN if the information is not available. More...
SENSORS_UNIT sensor_unit
 The string relative to the measurement unit of the sensor. More...
bool isAvailable
Variables
◆ type
◆ resolution
float resolution
◆ sampling_rate
float sampling_rate
◆ range
float2 range
◆ noise_density
float noise_density
◆ random_walk
float random_walk
◆ sensor_unit
◆ isAvailable
bool isAvailable
