MagnetometerData Struct Reference
Attributes
bool available
 Indicates if mag data is available More...
ulong timestamp
 mag Data timestamp in ns More...
Vector3 magneticField
 Magnetic field calibrated values in uT More...
Vector3 magneticFieldUncalibrated
 Magnetic field raw values in uT More...
float magneticHeading
 The camera heading in degrees relative to the magnetic North Pole. note: The magnetic North Pole has an offset with respect to the geographic North Pole, depending on the geographic position of the camera. To get a correct magnetic heading the magnetometer sensor must be calibrated using the ZED Sensor Viewer tool More...
HEADING_STATE magnetic_heading_state
 The state of the /ref magnetic_heading value More...
float magnetic_heading_accuracy
 The accuracy of the magnetic heading measure in the range [0.0,1.0]. A negative value means that the magnetometer must be calibrated using the ZED Sensor Viewer tool More...
Variables
◆ available
bool available
◆ timestamp
ulong timestamp
◆ magneticField
◆ magneticFieldUncalibrated
◆ magneticHeading
◆ magnetic_heading_state
◆ magnetic_heading_accuracy
