SensorsConfiguration Struct Reference
Structure containing information about all the sensors available in the current device. More...
bool isSensorAvailable (const sl::SENSOR_TYPE &sensor_type)
Attributes
unsigned int firmware_version = 0
sl::Transform camera_imu_transform
sl::Transform imu_magnetometer_transform
sl::SensorParameters accelerometer_parameters
sl::SensorParameters gyroscope_parameters
sl::SensorParameters magnetometer_parameters
sl::SensorParameters barometer_parameters
That information about the camera sensors is available in the CameraInformation struct returned by Camera::getCameraInformation().
Note
This object is meant to be used as a read-only container, editing any of its fields won't impact the SDK.
◆ isSensorAvailable()
bool isSensorAvailable ( const sl::SENSOR_TYPE sensor_type)
Check if a sensor type is available on the device
Variables
◆ firmware_version
The firmware version of the sensor module, 0 if no sensors are available (ZED camera model).
◆ camera_imu_transform
IMU to Left camera transform matrix, that contains rotation and translation between IMU frame and camera frame.
◆ imu_magnetometer_transform
Magnetometer to IMU transform matrix, that contains rotation and translation between IMU frame and magnetometer frame.
◆ accelerometer_parameters
Configuration of the accelerometer device
◆ gyroscope_parameters
Configuration of the gyroscope device
◆ magnetometer_parameters
Configuration of the magnetometer device
◆ barometer_parameters
Configuration of the barometer device
