Structure containing information about a single sensor available in the current device. More...
Attributes | |
| sl::SENSOR_TYPE | type |
| float | resolution |
| float | sampling_rate |
| sl::float2 | range |
| float | noise_density |
| float | random_walk |
| sl::SENSORS_UNIT | sensor_unit |
| bool | isAvailable |
That information about the camera sensors is available in the CameraInformation struct returned by Camera::getCameraInformation().
| sl::SENSOR_TYPE type |
The type of the sensor as DEVICE_SENSORS
| float resolution |
The resolution of the sensor.
| float sampling_rate |
The sampling rate (or ODR) of the sensor.
| sl::float2 range |
The range values of the sensor. MIN: range.x, MAX: range.y
| float noise_density |
also known as white noise, given as continous (frequency independant). Units will be expressed in sensor_unit/√(Hz). NAN if the information is not available
| float random_walk |
derived from the Allan Variance, given as continous (frequency independant). Units will be expressed in sensor_unit/s/√(Hz).NAN if the information is not available
| sl::SENSORS_UNIT sensor_unit |
The string relative to the measurement unit of the sensor.
| bool isAvailable |
