All Classes Namespaces Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Chunk
Represents a sub-mesh, it contains local vertices and triangles. More...
 Chunk ()
 Default constructor which creates an empty Chunk. More...
 ~Chunk ()
 Chunk destructor. More...
void clear ()
 Clears all chunk data. More...
Attributes
std::vector< float3vertices
std::vector< uint3triangles
std::vector< float3normals
std::vector< float2uv
unsigned long long timestamp
float3 barycenter
bool has_been_updated
Vertices and normals have the same size and are linked by id stored in triangles.
Note
uv contains data only if your mesh have textures (by loading it or after calling applyTexture).
Constructor and Destructor
◆ Chunk()
Chunk ( )
◆ ~Chunk()
~Chunk ( )
Chunk destructor.
◆ clear()
void clear ( )
Variables
◆ vertices
std::vector<float3> vertices
Vertices are defined by a 3D point {x,y,z}.
◆ triangles
std::vector<uint3> triangles
Vector of triangles, defined as a set of three vertices {v1, v2, v3}.
◆ normals
std::vector<float3> normals
Normals are defined by three components, {nx, ny, nz}. Normals are defined for each vertex.
◆ uv
std::vector<float2> uv
UVs defines the 2D projection of each vertices onto the Texture.
Values are normalized [0;1], starting from the bottom left corner of the texture (as requested by opengl).
In order to display a textured mesh you need to bind the Texture and then draw each triangle by picking its uv values.
Note
Contains data only if your mesh has textures (by loading it or calling applyTexture).
◆ timestamp
Timestamp of the latest update.
◆ barycenter
float3 barycenter
3D centroid of the chunk.
◆ has_been_updated
True if the chunk has been updated by an inner process.
