Important: This article is outdated (ZED SDK 1.2). Please see the new OpenCV guide here.
Redirect me to the updated tutorial
depth grab
/********************************** ** Using ZED with OpenCV **********************************/ #include <iostream> // OpenCV #include <opencv2/core/core.hpp> #include <opencv2/highgui/highgui.hpp> #include <opencv2/imgproc/imgproc.hpp> // ZED #include <zed/Camera.hpp> // Input from keyboard char keyboard = ' '; int main(int argc, char** argv) { // Initialize ZED color stream in HD and depth in Performance mode sl::zed::Camera* zed = new sl::zed::Camera(sl::zed::HD1080); sl::zed::ERRCODE err = zed->init(sl::zed::MODE::PERFORMANCE, 0, true); // Quit if an error occurred if (err != sl::zed::SUCCESS) { std::cout << "Unable to init the ZED:" << errcode2str(err) << std::endl; delete zed; return 1; } // Initialize color image and depth int width = zed->getImageSize().width; int height = zed->getImageSize().height; cv::Mat image(height, width, CV_8UC4,1); cv::Mat depth(height, width, CV_8UC4,1); // Create OpenCV windows cv::namedWindow("Image", cv::WINDOW_AUTOSIZE); cv::namedWindow("Depth", cv::WINDOW_AUTOSIZE); // Settings for windows cv::Size displaySize(720, 404); cv::Mat imageDisplay(displaySize, CV_8UC4); cv::Mat depthDisplay(displaySize, CV_8UC4); // Loop until 'q' is pressed while (keyboard != 'q') { // Grab frame and compute depth in FILL sensing mode if (!zed->grab(sl::zed::SENSING_MODE::FILL)) { // Retrieve left color image sl::zed::Mat left = zed->retrieveImage(sl::zed::SIDE::LEFT); memcpy(image.data,left.data,width*height*4*sizeof(uchar)); // Retrieve depth map sl::zed::Mat depthmap = zed->normalizeMeasure(sl::zed::MEASURE::DEPTH); memcpy(depth.data,depthmap.data,width*height*4*sizeof(uchar)); // Display image in OpenCV window cv::resize(image, imageDisplay, displaySize); cv::imshow("Image", imageDisplay); // Display depth map in OpenCV window cv::resize(depth, depthDisplay, displaySize); cv::imshow("Depth", depthDisplay); } keyboard = cv::waitKey(30); } delete zed; }
#include <iostream> // OpenCV #include <opencv2/core/core.hpp> #include <opencv2/highgui/highgui.hpp> #include <opencv2/imgproc/imgproc.hpp> // ZED #include <zed/Camera.hpp> int main(int argc, char** argv) { }
Do not forget to add the links to OpenCV (headers and libs) and ZED SDK (headers and libs).
Let’s create our ZED Camera object and select its resolution. Here, we will work in Full HD (HD1080
). Each image will have a 1920×1080 resolution. Please note that there are four resolutions and framerate available, as detailed in our Developer’s guide. Then, we initialize the ZED with its depth computation mode (QUALITY
, MEDIUM
, PERFORMANCE
or NONE
), device number and verbosity.
Now, assuming the initialization was correct, we can create our OpenCV matrix and OpenCV windows with the correct resolutions and types.
We use the width and height of the ZED frames to create the OpenCV matrix with those parameters. Because we want to display the color image and normalized depth image, we have to create each matrix in 8 bits / 4 channels format (CV_8UC4
Let’s write our main loop. The simplest way is to create a ‘while’ loop and handle all the events with OpenCV.
To grab an image and depth, we first need to select a sensing mode. There are two sensing modes available: STANDARD
and FILL
. STANDARD
mode is suited for applications such as collision avoidance and navigation, while FILL
mode is targeted at augmented reality and computational imaging where a fully dense depth map is needed. Here, we decide to use the FILL
sensing mode.
// Grab frame and compute depth in FILL sensing mode grab(sl::zed::SENSING_MODE::FILL))
Then, we just retrieve the color image and depth map and copy the buffers in our two OpenCV matrix. As you can see, we can directly copy the buffer of the zed::Mat
into the buffer of cv::Mat
//get left image and copy to opencv data sl::zed::Mat left = zed->retrieveImage(sl::zed::SIDE::LEFT); memcpy(image.data,left.data,width*height*4*sizeof(uchar)); //get depth image and copy to opencv data sl::zed::Mat depthmap= zed->normalizeMeasure(sl::zed::MEASURE::DEPTH); memcpy(depth.data,depthmap.data,width*height*4*sizeof(uchar)); Now, our OpenCV matrix contain the correct buffers. We can use standard OpenCV functions to resize the windows and display them on our screen: // show image in the OpenCV window cv::resize(image, imageDisplay, displaySize); cv::imshow("Image", imageDisplay); // show depth map in the OpenCV window cv::resize(depth, depthDisplay, displaySize); cv::imshow("Depth", depthDisplay);
And that’s all we need! You can now build and run the application. You should see on your screen the two following windows: “Depth” and “Image”.
depth grab
