Open a new terminal by pressing Ctrl + Alt + t or executing the “Terminal” application using the Ubuntu 18 launch system.
Add a new apt key:
[Note: the ROS GPG key has changed due to a security issue on the ROS build farm server. If you configured your Jetson Nano for ROS following this guide before the 24th June 2019, please follow this guide to replace the old key in the correct way]
$ sudo apt update
Install the ROS Desktop package, including support for rqt
, rviz
and other useful robotics packages:
It is recommended to load the ROS environment variables automatically when you execute a new shell session. Update your .bashrc
script:
Install and initialize rosdep. rosdep enables you to easily install system dependencies for source code you want to compile and is required to run some core components in ROS:
$ sudo apt install python-rosdep python-rosinstall python-rosinstall-generator python-wstool build-essential $ sudo rosdep init $ rosdep update
To start running your own ROS packages or install other packages from the source (such as the ZED ROS wrapper for example), you must create and configure a catkin
workspace.
$ catkin_make
Finally, update your .bashrc
script with the information about the new workspace:
$ cd ~/catkin_ws/src
Check the dependencies:
The rosdep
command explores all the packages available in the src
folder and verifies that all the declared dependencies are available, automatically installing the missing ones.
Compile the ZED ROS wrapper:
For ZED Mini:
