News
Jun 7, 2022.
Getting Started with Jetson AGX Orin™ Dev Kit
NVIDIA® Jetson AGX Orin™ Developer Kit enables the development of full-featured AI applications for products based on Jetson Orin modules. It includes a high-performance, power-efficient Jetson AGX Orin module, and can emulate the other Jetson Orin modules that will be launched on the market before the end of the year. It is now available for purchase on the Stereolabs store.
AGX Orin vs AGX Xavier : up to 2.5x faster
First boot
Requirements
  • NVIDIA Jetson AGX Orin module (included in box)
  • Reference Carrier board (included in box)
  • Wi-Fi module (included in box)
  • USB Type-C power supply (included in box)
  • USB Type-C to USB Type-A cable (included in box)
  • Internet connection
  • PC monitor with DisplayPort cable
  • USB keyboard and mouse
Boot and configure
  • Connect a display port cable to the Orin and to the PC monitor. You can use a DisplayPort to HDMI adapter if the monitor does not support the DisplayPort connection.
  • Connect a mouse and a keyboard to the USB ports
  • Optionally connect an ethernet cable if a WiFi network is not available
  • Plugin the USB Type-C™ power adapter to the Type-C™ port above the round power jack
  • Review and accept NVIDIA Jetson software EULA
  • Select system language, keyboard layout, and time zone
  • Create username, password, and computer name
  • Configure wireless networking
Upon completing the oem-config procedure, the developer kit reboots, and you should see the Ubuntu desktop like this on the display.
Install the JetPack components
Open a terminal window by hitting Ctrl + Alt + t
Check your L4T version
cat /etc/nv_tegra_release
You may get something like this, # R34 (release), REVISION: 1.0, GCID: 30102743, BOARD: t186ref, EABI: aarch64, DATE: Wed Apr 6 19:11:41 UTC 2022, and this shows that you have L4T for JetPack 5.0 Developer Preview.
sudo apt update
sudo apt dist-upgrade
sudo reboot
Adding a ZED camera
Download the latest ZED SDK for AGX Orin (e.g. ZED SDK for L4T 34.1 Beta) from the Stereolabs website.
cd ~/Downloads # replace with the correct folder if required
chmod +x ZED_SDK*
./ZED_SDK_Tegra_L4T<l4t_version>_v<ZED_SDK_version>.run
Please replace <l4t_version> and <ZED_SDK_version> with the correct values, e.g. ZED_SDK_Tegra_L4T34.1_v3.7.4.run.
Please do not hesitate to share your projects with us by publishing amazing pictures and videos, and tagging @stereolabs3d on Twitter, Instagram, Facebook, TikTok, YouTube, and LinkedIn.
NVIDIA® Jetson AGX Orin™ Developer Kit is now available and shipping from the Stereolabs store
