Note: This is for ZED SDK 1.0 only. Please see the latest SDK guides and documentation here.
Don’t forget to:
#include <iostream> #include <Windows.h> #include <GL/glew.h> #include <stddef.h> #include <SDL.h> #include <SDL_syswm.h> #include <OVR.h> #include <OVR_CAPI.h> #include <OVR_CAPI_GL.h> #include <zed/Camera.hpp> #include "Shader.hpp" int main(int argc, char** argv) { }
#define MAX_FPS 75
GLchar* OVR_ZED_VS = "#version 330 core layout(location=0) in vec3 in_vertex; layout(location=1) in vec2 in_texCoord; uniform float hit; out vec2 b_coordTexture; void main() { b_coordTexture = in_texCoord; gl_Position = vec4(in_vertex.x - hit, in_vertex.y, in_vertex.z,1); }"; GLchar* OVR_ZED_FS = "#version 330 core uniform sampler2D u_textureZED; in vec2 b_coordTexture; out vec4 out_color; void main() { out_color = vec4(texture(u_textureZED, b_coordTexture).rgb,1); }";
// Initialize SDL2 context SDL_Init(SDL_INIT_VIDEO); // Initialize Oculus context ovrResult result = ovr_Initialize(nullptr); if (OVR_FAILURE(result)) { std::cout << "ERROR: Failed to initialize libOVR" << std::endl; SDL_Quit(); return -1; } ovrSession hmd; ovrGraphicsLuid luid; // Connect to the Oculus headset result = ovr_Create(&hmd, &luid); if (OVR_FAILURE(result)) { std::cout << "ERROR: Oculus Rift not detected" << std::endl; ovr_Shutdown(); SDL_Quit(); return -1; } int x = SDL_WINDOWPOS_CENTERED, y = SDL_WINDOWPOS_CENTERED; int winWidth = 1280; int winHeight = 720; Uint32 flags = SDL_WINDOW_OPENGL | SDL_WINDOW_SHOWN; // Create SDL2 Window SDL_Window* window = SDL_CreateWindow("OVR ZED App", x, y, winWidth, winHeight, flags); // Create OpenGL context SDL_GLContext glContext = SDL_GL_CreateContext(window); // Initialize GLEW glewInit(); // Turn off vsync to let the compositor do its magic SDL_GL_SetSwapInterval(0);
// Initialize the ZED Camera sl::zed::Camera* zed = 0; zed = new sl::zed::Camera(sl::zed::HD720); sl::zed::ERRCODE zederr = zed->init(sl::zed::MODE::PERFORMANCE, 0); int zedWidth = zed->getImageSize().width; int zedHeight = zed->getImageSize().height; if (zederr != sl::zed::SUCCESS) { std::cout << "ERROR: " << sl::zed::errcode2str(zederr) << std::endl; ovr_Destroy(hmd); ovr_Shutdown(); SDL_GL_DeleteContext(glContext); SDL_DestroyWindow(window); SDL_Quit(); delete zed; return -1; }
GLuint zedTextureID_L, zedTextureID_R; // Generate OpenGL texture for left images of the ZED camera glGenTextures(1, &zedTextureID_L); glBindTexture(GL_TEXTURE_2D, zedTextureID_L); glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA, zedWidth, zedHeight, 0, GL_BGRA, GL_UNSIGNED_BYTE, NULL); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_REPEAT); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_REPEAT); // Generate OpenGL texture for right images of the ZED camera glGenTextures(1, &zedTextureID_R); glBindTexture(GL_TEXTURE_2D, zedTextureID_R); glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA, zedWidth, zedHeight, 0, GL_BGRA, GL_UNSIGNED_BYTE, NULL); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_REPEAT); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_REPEAT); glBindTexture(GL_TEXTURE_2D, 0);
ovrHmdDesc hmdDesc = ovr_GetHmdDesc(hmd); // Get the texture sizes of Oculus eyes ovrSizei textureSize0 = ovr_GetFovTextureSize(hmd, ovrEye_Left, hmdDesc.DefaultEyeFov[0], 1.0f); ovrSizei textureSize1 = ovr_GetFovTextureSize(hmd, ovrEye_Right, hmdDesc.DefaultEyeFov[1], 1.0f); // Compute the final size of the render buffer ovrSizei bufferSize; bufferSize.w = textureSize0.w + textureSize1.w; bufferSize.h = std::max(textureSize0.h, textureSize1.h); // Initialize OpenGL swap textures to render ovrSwapTextureSet* ptextureSet = 0; if (OVR_SUCCESS(ovr_CreateSwapTextureSetGL(hmd, GL_SRGB8_ALPHA8, bufferSize.w, bufferSize.h, &ptextureSet))) { for (int i = 0; i < ptextureSet->TextureCount; ++i) { ovrGLTexture* tex = (ovrGLTexture*)&ptextureSet->Textures[i]; glBindTexture(GL_TEXTURE_2D, tex->OGL.TexId); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_LINEAR); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_CLAMP_TO_EDGE); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_CLAMP_TO_EDGE); } } else { std::cout << "ERROR: failed creating swap texture" << std::endl; ovr_Destroy(hmd); ovr_Shutdown(); SDL_GL_DeleteContext(glContext); SDL_DestroyWindow(window); SDL_Quit(); delete zed; return -1; } // Generate frame buffer to render GLuint fboID; glGenFramebuffers(1, &fboID); // Generate depth buffer of the frame buffer GLuint depthBuffID; glGenTextures(1, &depthBuffID); glBindTexture(GL_TEXTURE_2D, depthBuffID); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_LINEAR); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_CLAMP_TO_EDGE); glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_CLAMP_TO_EDGE); GLenum internalFormat = GL_DEPTH_COMPONENT24; GLenum type = GL_UNSIGNED_INT; glTexImage2D(GL_TEXTURE_2D, 0, internalFormat, bufferSize.w, bufferSize.h, 0, GL_DEPTH_COMPONENT, type, NULL);
// Create a mirror texture to display the render result in the SDL2 window ovrGLTexture* mirrorTexture = nullptr; result = ovr_CreateMirrorTextureGL(hmd, GL_SRGB8_ALPHA8, winWidth, winHeight, reinterpret_cast<ovrTexture**>(&mirrorTexture)); if (!OVR_SUCCESS(result)) { std::cout << "ERROR: Failed to create mirror texture" << std::endl; } GLuint mirrorFBOID; glGenFramebuffers(1, &mirrorFBOID); glBindFramebuffer(GL_READ_FRAMEBUFFER, mirrorFBOID); glFramebufferTexture2D(GL_READ_FRAMEBUFFER, GL_COLOR_ATTACHMENT0, GL_TEXTURE_2D, mirrorTexture->OGL.TexId, 0); glFramebufferRenderbuffer(GL_READ_FRAMEBUFFER, GL_DEPTH_ATTACHMENT, GL_RENDERBUFFER, 0); glBindFramebuffer(GL_READ_FRAMEBUFFER, 0);
ovrLayerEyeFov ld; ld.Header.Type = ovrLayerType_EyeFov; // Tell to the Oculus compositor that our texture origin is at the bottom left ld.Header.Flags = ovrLayerFlag_TextureOriginAtBottomLeft | ovrLayerFlag_HeadLocked; // Because OpenGL | Disable head tracking // Set the Oculus layer eye field of view for each view for (int eye = 0; eye < 2; ++eye) { // Set the color texture as the current swap texture ld.ColorTexture[eye] = ptextureSet; // Set the viewport as the right or left vertical half part of the color texture ld.Viewport[eye] = OVR::Recti(eye == ovrEye_Left ? 0 : bufferSize.w / 2, 0, bufferSize.w / 2, bufferSize.h); // Set the field of view ld.Fov[eye] = hmdDesc.DefaultEyeFov[eye]; // Set the pose matrix ld.RenderPose[eye] = eyeRenderPose; } double sensorSampleTime = ovr_GetTimeInSeconds(); ld.SensorSampleTime = sensorSampleTime; // Get the render description of the left and right "eyes" of the Oculus headset ovrEyeRenderDesc eyeRenderDesc[2]; eyeRenderDesc[0] = ovr_GetRenderDesc(hmd, ovrEye_Left, hmdDesc.DefaultEyeFov[0]); eyeRenderDesc[1] = ovr_GetRenderDesc(hmd, ovrEye_Right, hmdDesc.DefaultEyeFov[1]); // Get the Oculus view scale description ovrVector3f viewOffset[2] = { eyeRenderDesc[0].HmdToEyeViewOffset, eyeRenderDesc[1].HmdToEyeViewOffset }; ovrViewScaleDesc viewScaleDesc; viewScaleDesc.HmdSpaceToWorldScaleInMeters = 1.0f; viewScaleDesc.HmdToEyeViewOffset[0] = viewOffset[0]; viewScaleDesc.HmdToEyeViewOffset[1] = viewOffset[1];
// Create and compile the shader's sources Shader shader(OVR_ZED_VS, OVR_ZED_FS);
// Compute the ZED image field of view with the ZED parameters float zedFovH = atanf(zed->getImageSize().width / (zed->getParameters()->LeftCam.fx * 2.f)) * 2.f; // Compute the Oculus' field of view with its parameters float ovrFovH = (atanf(hmdDesc.DefaultEyeFov[0].LeftTan) + atanf(hmdDesc.DefaultEyeFov[0].RightTan)); // Compute the useful part of the ZED image unsigned int usefulWidth = zed->getImageSize().width * ovrFovH / zedFovH; // Compute the size of the final image displayed in the headset with the ZED image's aspect-ratio kept unsigned int widthFinal = bufferSize.w / 2; unsigned int heightFinal = zed->getImageSize().height * widthFinal / usefulWidth; // Convert this size to OpenGL viewport's frame's coordinates float heightGL = (heightFinal) / (float)(bufferSize.h); float widthGL = ((zed->getImageSize().width * (heightFinal / (float)zed->getImageSize().height)) / (float)widthFinal);
// Create a rectangle with the coordonates computed and push it in GPU memory. float rectVertices[12] = { -widthGL, -heightGL, 0, widthGL, -heightGL, 0, widthGL, heightGL, 0, -widthGL, heightGL, 0 }; GLuint rectVBO[3]; glGenBuffers(1, &rectVBO[0]); glBindBuffer(GL_ARRAY_BUFFER, rectVBO[0]); glBufferData(GL_ARRAY_BUFFER, sizeof(rectVertices), rectVertices, GL_STATIC_DRAW); float rectTexCoord[8] = { 0, 1, 1, 1, 1, 0, 0, 0 }; glGenBuffers(1, &rectVBO[1]); glBindBuffer(GL_ARRAY_BUFFER, rectVBO[1]); glBufferData(GL_ARRAY_BUFFER, sizeof(rectTexCoord), rectTexCoord, GL_STATIC_DRAW); unsigned int rectIndices[6] = { 0, 1, 2, 0, 2, 3 }; glGenBuffers(1, &rectVBO[2]); glBindBuffer(GL_ELEMENT_ARRAY_BUFFER, rectVBO[2]); glBufferData(GL_ELEMENT_ARRAY_BUFFER, sizeof(rectIndices), rectIndices, GL_STATIC_DRAW); glBindBuffer(GL_ELEMENT_ARRAY_BUFFER, 0); glBindBuffer(GL_ARRAY_BUFFER, 0);
// Initialize hit value float hit = 0.02f; // Initialize a boolean that will be used to stop the application’s loop and another one to pause/unpause rendering bool end = false; bool refresh = true; // SDL variable that will be used to store input events SDL_Event events; // Initialize time variables. They will be used to limit the number of frames rendered per second. int time1 = 0, timePerFrame = 0; int frameRate = (int)(1000 / MAX_FPS);
// Enable the shader glUseProgram(shader.getProgramId()); // Bind the Vertex Buffer Objects of the rectangle that displays ZED images // vertices glEnableVertexAttribArray(Shader::ATTRIB_VERTICES_POS); glBindBuffer(GL_ARRAY_BUFFER, rectVBO[0]); glVertexAttribPointer(Shader::ATTRIB_VERTICES_POS, 3, GL_FLOAT, GL_FALSE, 0, 0); // indices glBindBuffer(GL_ELEMENT_ARRAY_BUFFER, rectVBO[2]); // texture coordinates glEnableVertexAttribArray(Shader::ATTRIB_TEXTURE2D_POS); glBindBuffer(GL_ARRAY_BUFFER, rectVBO[1]); glVertexAttribPointer(Shader::ATTRIB_TEXTURE2D_POS, 2, GL_FLOAT, GL_FALSE, 0, 0);
// Main loop while (!end) { // code... } // Disable all OpenGL buffer glDisableVertexAttribArray(Shader::ATTRIB_TEXTURE2D_POS); glDisableVertexAttribArray(Shader::ATTRIB_VERTICES_POS); glBindBuffer(GL_ELEMENT_ARRAY_BUFFER, 0); glBindBuffer(GL_ARRAY_BUFFER, 0); glBindTexture(GL_TEXTURE_2D, 0); glUseProgram(0); glBindVertexArray(0); // Delete the Vertex Buffer Objects of the rectangle glDeleteBuffers(3, rectVBO); // Delete SDL, OpenGL, Oculus and ZED context ovr_DestroySwapTextureSet(hmd, ptextureSet); ovr_DestroyMirrorTexture(hmd, &mirrorTexture->Texture); ovr_Destroy(hmd); ovr_Shutdown(); SDL_GL_DeleteContext(glContext); SDL_DestroyWindow(window); SDL_Quit(); delete zed; // quit return 0;
// Compute the time used to render the previous frame timePerFrame = SDL_GetTicks() - time1; // If the previous frame has been rendered too fast if (timePerFrame < frameRate) { // Pause the loop to have a max FPS equal to MAX_FPS SDL_Delay(frameRate - timePerFrame); timePerFrame = frameRate; } // Frame counter static unsigned int c = 0; // Chronometer static unsigned int time = 0; // If chronometer reached 1 second if (time > 1000) { // Display FPS std::cout << "FPS: " << c << std::endl; // Reset chronometer time = 0; // Reset frame counter c = 0; } // Increment the chronometer and the frame counter time += timePerFrame; c++; // Start frame chronometer time1 = SDL_GetTicks();
// While there is an event catched and not tested while (SDL_PollEvent(&events)) { // If a key is released if (events.type == SDL_KEYUP) { // If Q quit the application if (events.key.keysym.scancode == SDL_SCANCODE_Q) end = true; // If R reset the hit value else if (events.key.keysym.scancode == SDL_SCANCODE_R) hit = 0.0f; // If C pause/unpause rendering else if (events.key.keysym.scancode == SDL_SCANCODE_C) refresh = !refresh; } // If the mouse wheel is used if (events.type == SDL_MOUSEWHEEL) { // Increase or decrease hit value float s; events.wheel.y > 0 ? s = 1.0f : s = -1.0f; hit += 0.005f * s; } }
// If rendering is unpaused and // successful grab ZED image if (refresh && !zed->grab(sl::zed::SENSING_MODE::RAW, false, false)) { }
// Increment the CurrentIndex to point to the next texture within the output swap texture set. // CurrentIndex must be advanced round-robin fashion every time we draw a new frame ptextureSet->CurrentIndex = (ptextureSet->CurrentIndex + 1) % ptextureSet->TextureCount; // Get the current swap texture pointer auto tex = reinterpret_cast<ovrGLTexture*>(&ptextureSet->Textures[ptextureSet->CurrentIndex]); // Bind the frame buffer glBindFramebuffer(GL_FRAMEBUFFER, fboID); // Set its color layer 0 as the current swap texture glFramebufferTexture2D(GL_FRAMEBUFFER, GL_COLOR_ATTACHMENT0, GL_TEXTURE_2D, tex->OGL.TexId, 0); // Set its depth layer as our depth buffer glFramebufferTexture2D(GL_FRAMEBUFFER, GL_DEPTH_ATTACHMENT, GL_TEXTURE_2D, depthBuffID, 0); // Clear the frame buffer glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); glClearColor(0, 0, 0, 1);
// Render for each Oculus eye the equivalent ZED image for (int eye = 0; eye &amp;amp;amp;lt; 2; eye++) { // Set the left or right vertical half of the buffer as the viewport glViewport(eye == ovrEye_Left ? 0 : bufferSize.w / 2, 0, bufferSize.w / 2, bufferSize.h); // Bind the left or right ZED image glBindTexture(GL_TEXTURE_2D, eye == ovrEye_Left ? zedTextureID_L : zedTextureID_R); glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA, zedWidth, zedHeight, 0, GL_BGRA, GL_UNSIGNED_BYTE, zed->retrieveImage(eye == ovrEye_Left ? sl::zed::SIDE::LEFT : sl::zed::SIDE::RIGHT).data); // Bind the hit value glUniform1f(glGetUniformLocation(shader.getProgramId(), "hit"), eye == ovrEye_Left ? hit : -hit); // Draw the ZED image glDrawElements(GL_TRIANGLES, 6, GL_UNSIGNED_INT, 0); }
} // if (refresh) ovrLayerHeader* layers = &ld.Header; // Submit the frame to the Oculus compositor // which will display the frame in the Oculus headset result = ovr_SubmitFrame(hmd, 0, &viewScaleDesc, &layers, 1); if (!OVR_SUCCESS(result)) { std::cout << "ERROR: failed to submit frame" << std::endl; glDeleteBuffers(3, rectVBO); ovr_DestroySwapTextureSet(hmd, ptextureSet); ovr_DestroyMirrorTexture(hmd, &mirrorTexture->Texture); ovr_Destroy(hmd); ovr_Shutdown(); SDL_GL_DeleteContext(glContext); SDL_DestroyWindow(window); SDL_Quit(); delete zed; return -1; }
// Copy the frame to the mirror buffer // which will be drawn in the SDL2 image glBindFramebuffer(GL_READ_FRAMEBUFFER, mirrorFBOID); glBindFramebuffer(GL_DRAW_FRAMEBUFFER, 0); GLint w = mirrorTexture->OGL.Header.TextureSize.w; GLint h = mirrorTexture->OGL.Header.TextureSize.h; glBlitFramebuffer(0, h, w, 0, 0, 0, w, h, GL_COLOR_BUFFER_BIT, GL_NEAREST); glBindFramebuffer(GL_READ_FRAMEBUFFER, 0); // Swap the SDL2 window SDL_GL_SwapWindow(window);
