SensorsData::MagnetometerData Class Reference
Contains Magnetometer sensor data. More...
Types
enum class  HEADING_STATE
Attributes
bool is_available
sl::Timestamp timestamp
sl::float3 magnetic_field_uncalibrated
sl::float3 magnetic_field_calibrated
float magnetic_heading
HEADING_STATE magnetic_heading_state
float magnetic_heading_accuracy
float effective_rate
Enumeration
◆ HEADING_STATE
enum HEADING_STATE
strong
Enumerator
GOOD
The heading is reliable and not affected by iron interferences.
OK
The heading is reliable, but affected by slight iron interferences.
NOT_GOOD
The heading is not reliable because affected by strong iron interferences.
NOT_CALIBRATED
The magnetometer has not been calibrated.
MAG_NOT_AVAILABLE
The magnetomer sensor is not available.
Variables
◆ is_available
bool is_available
Defines if the sensor is available in your camera.
◆ timestamp
Defines the sensors data timestamp
◆ magnetic_field_uncalibrated
(3x1) Vector for magnetometer raw values (uncalibrated) In other words, the current magnetic field (uT), along with the x, y, and z axes.
Note
The magnetometer raw values are affected by soft and hard iron interferences. The sensor must be calibrated, placing the camera in the working environment, using the ZED Sensor Viewer tool.
Not available in SVO or Stream mode.
◆ magnetic_field_calibrated
(3x1) Vector for magnetometer values (after user calibration) In other words, the current calibrated and normalized magnetic field (uT), along with the x, y, and z axes.
Note
To calibrate the magnetometer sensor please use the ZED Sensor Viewer tool after placing the camera in the final operating environment
◆ magnetic_heading
The camera heading in degrees relative to the magnetic North Pole.
Note
The magnetic North Pole has an offset with respect to the geographic North Pole, depending on the geographic position of the camera.
To get a correct magnetic heading the magnetometer sensor must be calibrated using the ZED Sensor Viewer tool
◆ magnetic_heading_state
The state of the /ref magnetic_heading value
◆ magnetic_heading_accuracy
The accuracy of the magnetic heading measure in the range [0.0,1.0].
Note
A negative value means that the magnetometer must be calibrated using the ZED Sensor Viewer tool
◆ effective_rate
Realtime data acquisition rate [Hz]
