BatchParameters Class Reference
sets batch trajectory parameters More...
 BatchParameters (bool enable=false, float id_retention_time=240.f, float batch_duration=2.f)
 Default constructor. Set all parameters to their default values. More...
bool operator== (const BatchParameters &param1) const
bool operator!= (const BatchParameters &param1) const
Attributes
bool enable = false
 Defines if the Batch option in the object detection module is enabled. Batch queueing system provides: More...
float id_retention_time = 240
 Max retention time in seconds of a detected object. After this time, the same object will mostly have a different ID. More...
float latency = 2.f
 Trajectories will be output in batch with the desired latency in seconds. During this waiting time, re-identification of objects is done in the background. Specifying a short latency will limit the search ( falling in timeout) for previously seen object IDs but will be closer to real time output. Specifying a long latency will reduce the change of timeout in Re-ID but increase difference with live output. More...
Note
Parameters can be user adjusted.
Constructor and Destructor
◆ BatchParameters()
BatchParameters ( bool  enable = false,
float  id_retention_time = 240.f,
float  batch_duration = 2.f
◆ operator==()
bool operator== ( const BatchParameters param1) const
Comparison operator ==
Parameters
BatchParametersto compare
Returns
◆ operator!=()
bool operator!= ( const BatchParameters param1) const
Comparison operator !=
Parameters
Returns
Variables
◆ enable
bool enable = false
  • Deep-Learning based re-identification
  • Trajectory smoothing and filtering
    Note
    To activate this option, enable must be set to true.
◆ id_retention_time
◆ latency
float latency = 2.f
