Objects Class Reference
Contains the result of the object detection module. The detected objects are listed in object_list. More...
bool getObjectDataFromId (sl::ObjectData &objectData, int objectDataId)
 Function that look for a given object ID in the current object list and return the object associated if found and a status. More...
Attributes
sl::Timestamp timestamp
 Defines the timestamp corresponding to the frame acquisition. This value is especially useful for the async mode to synchronize the data. More...
std::vector< sl::ObjectData > object_list
 The list of detected objects. More...
bool is_new
 Defined if the object list has already been retrieved or not. More...
bool is_tracked
 Defined if both the object tracking and the world orientation has been setup. More...
◆ getObjectDataFromId()
bool getObjectDataFromId ( sl::ObjectData &  objectData,
int  objectDataId
Parameters
objectData[out] : the object corresponding to the given ID if found
objectDataId[in] : the input object ID
Returns
True if found False otherwise
Variables
◆ timestamp
◆ object_list
std::vector<sl::ObjectData> object_list
◆ is_new
bool is_new
◆ is_tracked
bool is_tracked
