ZED ROS 2 Wrapper Custom Messages
All the custom messages used by the ZED ROS 2 Wrapper are defined in the zed-ros2-interfaces repository.
Plane Detection result #
The zed_interfaces/PlaneStamped message, published by the Plane Detection module, is defined as:
# Standard Header
std_msgs/Header header
# Mesh of the place
shape_msgs/Mesh mesh
# Representation of a plane, using the plane equation ax + by + cz + d = 0
shape_msgs/Plane coefficients
# Normal vector
geometry_msgs/Point32 normal
# Center point
geometry_msgs/Point32 center
# Plane pose relative to the global reference frame
geometry_msgs/Transform pose
# Width and height of the bounding rectangle around the plane contours
float32[2] extents
# The polygon bounds of the plane
geometry_msgs/Polygon bounds
Depth information #
The zed_interfaces/DepthInfoStamped message is defined as:
# Standard Header
# Miminum measured depth
float32 min_depth
# Maximum measured depth
float32 max_depth
Positional Tracking status #
The zed_interfaces/PosTrackStatus message is defined as:
# Status constants
# SEARCHING - The camera is searching for a previously known position to locate itself
# OK - Positional tracking is working normally
# OFF - Positional tracking is not enabled.
# FPS_TOO_LOW - Effective FPS is too low to give proper results for motion tracking. Consider using PERFORMANCES parameters (DEPTH_MODE_PERFORMANCE, low camera resolution (VGA,HD720))
# SEARCHING_FLOOR_PLANE - The camera is searching for the floor plane to locate itself related to it, the REFERENCE_FRAME::WORLD will be set afterward.
uint8 SEARCHING=0
uint8 OK = 1
uint8 OFF = 2
uint8 FPS_TOO_LOW = 3
uint8 SEARCHING_FLOOR_PLANE = 3
# Status
uint8 status
Object Detection and Body Tracking results #
The Object Detection and the Body Tracking modules publish data on the detected objects and body topics by using the same custom message.
The zed_interfaces/ObjectsStamped message is defined as:
# Standard Header
# Array of `object_stamped` topics
zed_interfaces/Object[] objects
where zed_interfaces/Object is defined as:
# Object label
string label
# Object label ID
int16 label_id
# Object sub
string sublabel
# Object confidence level (1-99)
float32 confidence
# Object centroid position
float32[3] position
# Position covariance
float32[6] position_covariance
# Object velocity
float32[3] velocity
bool tracking_available
# Tracking available
# Tracking state
# 0 -> OFF (object not valid)
# 1 -> OK
# 2 -> SEARCHING (occlusion occurred, trajectory is estimated)
int8 tracking_state
# Action state
# 0 -> IDLE
# 2 -> MOVING
int8 action_state
# 2D Bounding box projected to Camera image
zed_interfaces/BoundingBox2Di bounding_box_2d
# 3D Bounding box in world frame
zed_interfaces/BoundingBox3D bounding_box_3d
# 3D dimensions (width, height, lenght)
float32[3] dimensions_3d
# Is skeleton available?
bool skeleton_available
# Skeleton format
# 0 -> POSE_18
# 1 -> POSE_34
# 2 -> POSE_38
# 3 -> POSE_70
int8 body_format
# 2D Bounding box projected to Camera image of the person head
zed_interfaces/BoundingBox2Df head_bounding_box_2d
# 3D Bounding box in world frame of the person head
zed_interfaces/BoundingBox3D head_bounding_box_3d
# 3D position of the centroid of the person head
float32[3] head_position
# 2D Person skeleton projected to Camera image
zed_interfaces/Skeleton2D skeleton_2d
# 3D Person skeleton in world frame
zed_interfaces/Skeleton3D skeleton_3d
And all the submessages are defined as following:
zed_interfaces/BoundingBox2Df:
#      0 ------- 1
#      3 ------- 2
zed_interfaces/Keypoint2Df[4] corners
zed_interfaces/BoundingBox2Di:
#      0 ------- 1
#      3 ------- 2
zed_interfaces/Keypoint2Di[4] corners
zed_interfaces/BoundingBox3D:
#      1 ------- 2
#    0 ------- 3 |
#    | 5.......| 6
#    4 ------- 7
zed_interfaces/Keypoint3D[8] corners
zed_interfaces/Keypoint2Df:
float32[2] kp
zed_interfaces/Keypoint2Di:
uint32[2] kp
zed_interfaces/Keypoint3D:
float32[3] kp
zed_interfaces/Skeleton2D:
# Skeleton joints
zed_interfaces/Keypoint2Df[70] keypoints
zed_interfaces/Skeleton3D:
# Skeleton joints
zed_interfaces/Keypoint3D[70] keypoints
