ROS 2 - Data display with Rviz2
RVIZ is a ROS graphical interface that allows you to visualize a lot of information, using plugins for many kinds of available topics. RVIZ 2 is simply a port of RVIZ into ROS 2.
The zed_display_rviz2 package provides three Python launch scripts, display_zed.launch.py
, display_zedm.launch.py
, display_zed2.launch.py
, and display_zed2i.launch.py
. They run three preconfigured RVIZ 2 sessions for the ZED, ZED-M, ZED2, and ZED2i cameras respectively. The three sessions load the default RVIZ 2 plugins preconfigured to show the most used data from the ZED ROS 2 infrastructure.
To create your own RVIZ 2 configuration, you can combine the plugins described below.
Global options #
To be able to visualize the information published by the ZED camera, it is necessary to correctly configure the Global Options
Key parameters:
Fixed frame
: Indicates the name of the frame used as a reference for all the other frames. You can select every frame available in the combo box.mao
orodom
are the best choices.Frame rate
: The maximum frequency used to update the 3D view.30
or60
FPS are good values. Available computational power should guide your decision.
Grid #
This plugin allows you to visualize a grid normally associated with the floor plane.
Key parameters:
Reference frame
: The frame used as a reference for the grid coordinates (normally:<fixed_frame>
)Plane cell count
: The size of the grid in cellsNormal cell count
: The number of cells in the direction normal to the grid plane (normally:0
)Cell size
: Dimensions in meters of each grid cellPlane
: The two axes that identify the grid plane
Robot model #
This plugin allows you to visualize the Robot Model according to its description from the URDF model.
Key parameters:
Visual enabled
: Enable/disable the 3D visualization of the modelDescription Source
: You can choose betweenFile
andTopic
. At the moment of writing this guide theTopic
option is not working as expected, soFile
is the right optionDescription File
: the URDF file that contains the Robot Descriptionzed.urdf
orzedm.urdf
By expanding the Links
voice, you can see the whole model tree, with all the joints and the links available and the relative position and orientation in the space relative to the fixed frame
TF #
This plugin allows you to visualize the position and orientation of all frames that compose the TF Hierarchy.
Key parameters:
Show names
: Enable/disable the 3D visualization of link namesShow axes
: Enable/disable the 3D visualization of the axes of the framesShow arrows
: Enable/disable the 3D visualization of the arrows that connect the various framesMarker Scale
: Used to rescale all the TF objects to let them be more visible and less chaoticUpdate interval
: The update time in seconds. Leave at0
to see each update
Critical to using this plugin is the ability to enable/disable visualizing individual frames. This allows you to concentrate only on the parts that are most important for your current task.
Video #
Learn how to configure RVIZ for visualizing Video information by following the Video with RVIZ 2 tutorial.
Depth Sensing #
Learn how to configure RVIZ for visualizing Depth information by following the Depth with RVIZ 2 tutorial.
Positional Tracking #
Learn how to configure RVIZ for visualizing Position information by following the Position with RVIZ tutorial.
Object Detection #
Learn how to configure RVIZ for visualizing Object Detection information using the custom Stereolabs plugin by following the Object Detection with RVIZ tutorial.
Body Tracking #
Learn how to configure RVIZ for visualizing Body Tracking information using the custom Stereolabs plugin by following the Body Tracking with RVIZ tutorial.
Plane Detection #
Learn how to configure RVIZ for visualizing Plane Detection information by following the Object Detection with RVIZ tutorial.
