ZED Isaac Sim Extension Overview
The ZED Camera extension for NVIDIA® Isaac Sim enables developers to connect the ZED SDK to their virtual ZED Cameras in Isaac Sim, allowing them to seamlessly simulate ZED-based robotics applications.
Some examples of applications:
- Smart navigation, where mobile robots autonomously navigate in a virtual environment using the ZED SDK, the ZED ROS 2 wrapper, and any virtual robot rigged with the ZED X Camera
- Repeatable testing environment that makes it easier to debug and optimize applications.
ZED Camera extension #
The extension will be available through the community (or third-party) tab in the NVIDIA® Isaac sim extension manager. It includes the Omnigraph node needed to stream data and the USD model of the ZED X camera.
The extension can also be found on the official Stereolabs GitHub repository.
Get started #
To connect your virtual ZED camera to the ZED SDK you have to complete the following steps:
Step 1: Install NVIDIA® Isaac Sim #
The recommended way to install Isaac Sim is to use the Omniverse launcher. You can find the installation instructions here.
Step 2: Install the ZED SDK #
The ZED SDK must be installed on the machine running Isaac Sim. You can find the installation instructions here.
Step 3: Add the virtual camera to your simulation #
If you haven’t already, we recommend to familiarize yourself with Isaac Sim by reading the Isaac Sim Main Concepts section of the official NVIDIA® documentation.
Then, get started with the ZED camera in Isaac Sim!
ROS 2 integration #
Isaac Sim can be used to simulate robots and generates ZED data to be used with ROS 2 and the ZED ROS 2 Wrapper.
Follow this guide to learn how to configure the Isaac Sim ROS 2 Bridge to send simulated information to a ZED ROS 2 Wrapper node.
