ZED Link Quad on Xavier AGX
This tutorial will help you set up the ZED Link Quad GMSL2 capture card, and use the Stereolabs GMSL2 cameras with the NVIDIA® Jetson™ Xavier AGX Developer Kits.
Prerequisites #
- 1x NVIDIA® Jetson™ Xavier AGX Developer Kit.
- 1x ZED Link Quad GMSL2 capture card
- 2x 1-to-4 GMSL2 Fakra Male to Female cable (included in the box)
- 1x NVIDIA® Power supplier to power the Development Kit (included with the devkit)
- 12V-19V (min 6W) power input (Barrel Jack 5.5 mm outer diameter, 2.5 mm inner diameter) to power the GMSL2 capture card (not included)
Plug in the capture card in the ‘Camera connector’ slot and fix it by using the three provided screws:
Connect the camera #
📌 Note: GMSL2 cameras must be ideally plugged before booting up. If it is not the case, you can restart the
zed_x_daemon
that will be installed by the driver in the next section.
📌 Note: When using the ZED Link Quad capture card with more than two stereo cameras, it is important to note that no more than two devices can be connected to the same GMSL2 port. This means only two wires of each 4-wires port can be used simultaneously with stereo devices.
Setting up the software #
Install the ZED Link Driver #
Install the ZED SDK #
