ZED Link Mono on Xavier NX
This tutorial will help you set up the ZED Link Mono GMSL2 capture card, and use the Stereolabs GMSL2 cameras with the NVIDIA® Jetson™ Xavier NX Developer Kits.
Prerequisites #
  • 1x NVIDIA® Jetson™ Xavier NX Developer Kit.
  • 1x ZED Link Mono GMSL2 capture card
  • 1x NVIDIA® Power supplier to power the Development Kit (included with the devkit)
  • 1x FPC Camera Cable 22-pin 0.5mm Pitch to 15-pin 1.0mm Pitch (not included)*
  • 12V-19V (min 2W) power input (Barrel Jack 5.5 mm outer diameter, 2.5 mm inner diameter) to power the GMSL2 capture card (not included)
* You can find the FPC Camera Cable 22 pin 0.5 pitch to 15-pin 1mm pitch at UCTRONICS.
📌 Note: MIPI cables transmit video signals. If the length increases, the video signal will be noisy. Max length recommended is 15 cm.
Cabling the GMSL2 Capture Card #
Connect the CSI cables at the MIPI 22-pin port of the capture card. Make sure the correct side is plugged in.
Warning: Inverting the side might damage the carrier board or the capture card.
Cabling the Carrier Board #
Connect the camera #
With the capture card still powered off, connect the female end of the cable to the capture card’s GMSL2 input. Again, a click informs you that the cable is secured.
📌 Note: GMSL2 cameras must be ideally plugged before booting up. If it is not the case, you can restart the zed_x_daemon that will be installed by the driver in the next section.
Setting up the software #
Install the ZED SDK #
