ZED Link Duo on Xavier AGX
This tutorial will help you set up the ZED Link Duo GMSL2 capture card, and use the Stereolabs GMSL2 cameras with the NVIDIA® Jetson™ Xavier AGX Developer Kit.
Prerequisites #
- 1x NVIDIA® Jetson™ AGX Xavier Developer Kit
- 1x ZED Link Duo GMSL2 capture card
- 1x 1-to-4 GMSL2 Fakra Male to Female cable (included in the box)
- 1x NVIDIA® Power supplier to power the DevKit (included with the devkit)
📌 Note: the ZED Link Duo card does not need external power when connected to an NVIDIA® Jetson™ AGX devkit
Plug in the capture card in the ‘Camera connector’ slot and fix it by using the three provided screws, as shown in the following diagrams:
📌 Note: The capture card is powered by the Dev Kit, therefore you do not need to use an additional power supply for the card.
Connect the camera #
Connect the GMSL2 Fakra cable female end to your GMSL2. When you hear a click, the cable is securely connected to the camera.
Now that the Developer Kit has been correctly set up, we can install the associated software and drivers for the ZED X.
Setting up the software #
Install the ZED Link #
After setting up your ZED Link capture card, please follow this guide to Install the ZED Link Driver.
Install the ZED SDK #
