ZED Link Duo on AGX Orin
This tutorial will help you set up the ZED Link Duo GMSL2 capture card, and use the Stereolabs GMSL2 cameras with the NVIDIA® Jetson™ AGX Orin Developer Kit.
Prerequisites #
- 1x NVIDIA® Jetson™ AGX Orin Developer Kit
- 1x ZED Link Duo GMSL2 capture card
- 1x 1-to-4 GMSL2 Fakra Male to Female cable (included in the box)
- 1x NVIDIA® Power supplier to power the DevKit (included with the devkit)
📌 Note: the ZED Link Duo card does not need external power when connected to an NVIDIA® Jetson™ AGX devkit
Plug in the capture card in the ‘Camera connector’ slot and fix it by using the three provided screws, as shown in the following diagrams:
📌 Note: The capture card is powered by the Dev Kit, therefore you do not need to use an additional power supply for the card.
Connect the camera #
Connect the GMSL2 Fakra cable female end to your GMSL2. When you hear a click, the cable is securely connected to the camera.
AGX Orin Developer Kit Enclosure #
If you are using an AGX Orin Developer Kit, we recommend you use the Enclosure for the AGX Orin Developer Kit available for purchase on the Stereolabs store, to securely integrate our GMSL2 Capture Card while keeping the electronics safe. It also allows you to mount the Dev Kit on any surface using VESA 75x75, and gives the possibility to add WiFi antennas to boost your AGX Orin wireless transmissions.
Installing the AGX Orin Enclosure
Setting up the software #
Install the ZED Link Driver #
Install the ZED SDK #
