Create and use Docker images for ZED and ROS 2
We recommend using the Docker image built using this guide as the base image for your custom setup.
Using the ZED ROS2 Wrapper repository resources #
The docker folder of the ZED ROS2 Wrapper GitHub repository contains a list of Dockerfile files to build Docker images ready to start the nodes of the ZED ROS2 Wrapper:
Dockerfile.desktop-humble: development desktop image for ROS2 Humble, running on the specified Ubuntu and CUDA versionsDockerfile.l4t-humble: Jetson™ image for ROS2 Humble, running on the given L4T version
The ZED Wrapper code is copied from the source files of the working branch and compiled inside the Docker image.
📌 Note: in the entrypoint files we set the value of the
ROS_DOMAIN_IDenvironment variable to0that is the default value in ROS 2.If your setup requires a different value you can change it in the
ros_entrypoint_jetson.shandros_entrypoint.shfile before building your image to set it automatically when starting your Docker image, or you can use the CLI commandexport ROS_DOMAIN_ID=<new_value>when each interactive session is started.You can get more details concerning the
ROS_DOMAIN_IDusage on the official ROS 2 documentation.
Cross compilation #
You can easily compile the image for Jetson™ from your usual Desktop PC. For that you just need to run the following line before launching the build command:
docker run --rm --privileged multiarch/qemu-user-static --reset -p yes
Build the Docker images #
We provide scripts to build your image with the right configuration.
- Checkout the branch, tag or commit id of the ROS2 wrapper that you want to use.
git checkout <build_branch>
e.g. use the latest code from the master branch:
git checkout master
- Build the image for Jetson:
./jetson_build_dockerfile_from_sdk_and_l4T_version.sh <l4T version> <ZED SDK version>
- Build the image for Desktop:
./desktop_build_dockerfile_from_sdk_ubuntu_and_cuda_version.sh <Ubuntu version> <CUDA version> <ZED SDK version>
Examples:
# Jetson™ with JP6.0 and ZED SDK v4.2.3
./jetson_build_dockerfile_from_sdk_and_l4T_version.sh l4t-r36.3.0 zedsdk-4.2.3
# Desktop on Ubuntu 22.04m CUDA 12.6.3 and ZED SDK v4.2.3
./desktop_build_dockerfile_from_sdk_ubuntu_and_cuda_version.sh ubuntu-22.04 cuda-12.6.3 zedsdk-4.2.3
⚠️ Some configurations will not work. For example, if a specific ZED SDK does not exist for a given Ubuntu/CUDA/L4T version, or if the given ROS 2 wrapper is not compatible with the selected Ubuntu version.
Run the Docker image #
NVIDIA runtime
NVIDIA drivers must be accessible from the Docker image to run the ZED SDK code on the GPU. You’ll need :
- The
nvidiacontainer runtime installed, following this guide - A specific docker runtime environment with
-gpus allor-e NVIDIA_DRIVER_CAPABILITIES=all - Docker privileged mode with
--privileged
Network
Setup the network configuration to enable the communication between the Docker image, other Docker images, and the host:
--network=host: Remove network isolation between the container and the Docker host--ipc=host: Use the host system’s Inter-Process Communication namespace--pid=host: Use the host system’s namespace for process ID
Display context to use CUDA based applications
Use the same host DISPLAY environment variable in every Docker image to enable CUDA-based applications with -e DISPLAY=$DISPLAY.
📌 NOTE: the shared volume
/tmp/.X11-unix/:/tmp/.X11-unixis also required.
Shared Volumes
A few volumes should also be shared with the host.
/tmp/.X11-unix/:/tmp/.X11-unixis required to enable X11 server communication for CUDA-based applications/usr/local/zed/settings:/usr/local/zed/settingsif you plan to use the robot in an Internet-negated area, and you previously downloaded the camera calibration files by following this guide./usr/local/zed/resources:/usr/local/zed/resourcesif you plan to use the AI module of the ZED SDK (Object Detection, Skeleton Tracking, NEURAL depth) we suggest binding mounting a folder to avoid downloading and optimizing the AI models each time the Docker image is restarted. The first time you use the AI model inside the Docker image, it will be downloaded and optimized in the local bound-mounted folder, and stored there for the next runs.- If you plan to use different SDK versions in different Docker images it’s preferred to use a different
volume on the host for each of them:
/<specific_folder_name>/:/usr/local/zed/resources
/dev:/devto share the video devices- For GMSL2 cameras (ZED X, ZED X One) you’ll also need
/tmp:/tmp/var/nvidia/nvcam/settings/:/var/nvidia/nvcam/settings//etc/systemd/system/zed_x_daemon.service:/etc/systemd/system/zed_x_daemon.service
/dev:/dev: to share the video and other required devices/dev/shm:/dev/shm: to use ROS 2 with shared memory
Start the Docker container #
First of all, allow the container to access EGL display resources (required only once):
sudo xhost +si:localuser:root
then you can start an interactive session:
USB3 cameras
docker run --runtime nvidia -it --privileged --network=host --ipc=host --pid=host \
-e NVIDIA_DRIVER_CAPABILITIES=all -e DISPLAY=$DISPLAY \
-v /tmp/.X11-unix/:/tmp/.X11-unix \
-v /dev:/dev \
-v /dev/shm:/dev/shm \
<docker_image_tag>
GMSL cameras
-v /tmp:/tmp \
-v /dev:/dev \
<docker_image_tag>
