PositionalTrackingParameters Member List
This is the complete list of members for PositionalTrackingParameters, including all inherited members.
area_file_pathPositionalTrackingParameters
depth_min_rangePositionalTrackingParameters
enable_area_memoryPositionalTrackingParameters
enable_imu_fusionPositionalTrackingParameters
enable_pose_smoothingPositionalTrackingParameters
initial_world_transformPositionalTrackingParameters
load(String filename)PositionalTrackingParameters
operator!=(const PositionalTrackingParameters &param1) constPositionalTrackingParameters
operator==(const PositionalTrackingParameters &param1) constPositionalTrackingParameters
PositionalTrackingParameters(Transform init_position_=Transform(), bool enable_memory_=true, bool enable_pose_smoothing_=false, String area_path_=String(), bool set_floor_as_origin_=false, bool enable_imu_fusion_=true, bool set_as_static_=false, float depth_min_range=-1.f, bool set_gravity_as_origin_=true)PositionalTrackingParameters
save(String filename)PositionalTrackingParameters
set_as_staticPositionalTrackingParameters
set_floor_as_originPositionalTrackingParameters
set_gravity_as_originPositionalTrackingParameters
